Old 01-29-2003, 03:53 PM   #1
ImprezedRS
Member#: 2771
2003 BMW Z4
Default Catz Zeta?
I was wondering how does this work, from what I hear is it just boosts the power from like 12v to like 15v. Is that true, also if it is then I could basically make my own for cheap then from parts from Radio Shack. Has any one taken theres a part?
ImprezedRS is offline   Reply With Quote
Old 01-30-2003, 02:42 PM   #2
ImprezedRS
Member#: 2771
2003 BMW Z4
bump, i know somebody has to know
Old 01-30-2003, 06:16 PM   #3
rory-wrx
Member#: 26303
2003 WRB GGA w/ 5MT
I can see clearly now...
This is basically a DC-to-DC converter that steps up the voltage supplied to the headlights from 12 to 15 VDC. The price of this system (~$275) doesn't suprise me as DC-to-DC converters with enough capacity to power the headlights would, by themselves, be quite pricey. I don't think you can get these at Radio Shack.
Besides the price, there is another issue to consider. By boosting the voltage you will indeed boost light output (& color temperature), but you will also dramatically reduce your bulb life. Bulb output at 15VDC will be about 220% of that at 12VDC but bulb life will be only about 7% of what you would get at 12VDC. The only way to get around this is to go with bulbs rated at 15VDC, but then you loose all the brightness advantage.
As Dr. Eldon Tyrell said in Blade Runner, "The light that burns twice as bright, burns half as long." Its actually lots worse than this --- brightness is proportional to the ratio of the applied to design voltage raised to the 3.5 power; bulb life is proportional to the ratio of the design to applied voltage raised to the 12th power!
rory-wrx is offline   Reply With Quote
Old 01-30-2003, 07:39 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Want to do something to improve the light output from your existing bulbs that won't harm them and is cheap? Try adding some relays to switch them to a direct ground rather than the lossy grounding system Subaru uses. On my '02, I measured a 1.5 volt drop on the ground side with stock wattage lights and that is an awful lot. It's probably similar on an '00 since the circuitry is essentially the same. Eliminating this drop to provide full available voltage to the headlights will make a noticeable difference in light output.
For a demonstration, identify the low beam switched ground wire on the connector for your driver side headlight (be sure you have the right wire!). While the low beams are on, take a short jumper wire of decent gauge (12 is good), touch one end to that pin on the headlight connector and touch the other end to the negative terminal on the battery. You will see the light get brighter.
Old 01-31-2003, 03:42 PM   #5
rjones
Member#: 1477
2003 wrx wagon
rory-wrx -
that was the ragest explanation of bulb life I have ever heard. Way to work in the blade runner quote.
rjones is offline   Reply With Quote
Old 01-31-2003, 04:38 PM   #6
ImprezedRS
Member#: 2771
2003 BMW Z4
yeah that was a good explanation. I don't think I will go with this anyways I knew the life of the bulb was going to drop but not by that much though. I went to this webpage that explains a lot of stuff on car headlights and I figure I'm going to try a LED lighting system. I know it will be expensive but ohwell its only money.
Old 07-07-2003, 02:03 PM   #7
exhacker
Member#: 33725
2008 Impreza WRX 5dr
Can someone post some pics and instructions for the headlight grounding mod (or links). thanks
exhacker is offline   Reply With Quote
catz zeta lighting system? bayWRX Interior & Exterior Modification 7 04-23-2001 07:33 AM
How did you mount your HID / Catz Zeta Ballast ? DEVO-2nd GEN Interior & Exterior Modification 9 04-20-2001 12:52 AM
Opinions on Catz Zeta headlamp bulbs? Robmat Interior & Exterior Modification 2 03-27-2001 09:12 PM
Headlamp Question / About Catz Zeta SiriBX General Forum Archive 0 01-31-2001 10:03 PM
Anyone is runnig the CATZ ZETA kits? V6 Interior & Exterior Modification 1 12-28-2000 02:06 AM
