Mid Atlantic Impreza Club
Old 01-29-2003, 05:16 PM   #1
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Default Does anyone know how to use helicoils or other thread repair?
i am just not meant to work on cars. First I put a hole in my radiator while putting the 16G on my Laser. So I get that taken care of, almost done, last bolt and I am finished. And I mange to strip the threads out on my oil supply line to the turbo!! The oil supply is in the head and the head is aluminum on this car, I must have cross threaded it and killed the threads. I think it is possible to repair this with a helicoil, but I have never used them before and I really don't want to screw my car up even further. Can anyone help me with this? The car is not driveable without the oil line so we would have to do this at my place in Chantilly. I will GLADLY pay anyone who is willing to help me out with this. Also since this is the oil feed line for the turbo, does anyone have any ideas on how to clean all the crap in there from the threads that I stripped?
slim speedy is offline   Reply With Quote
Old 01-29-2003, 05:35 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
Shoulda let me help!
Sorry, not sure how to use a helicoil....
Could you take pics of the stripped part? Is the oil feed line male and the block female? Not sure exactly what is stripped...
rhdude is offline   Reply With Quote
Old 01-29-2003, 05:45 PM   #3
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
Have you tried to use a tap (of the same size and thread pitch) to try to clean out the threads? Sometimes just carefully taping out the hole will repair the threads enough to be usable as long as the hole/threads aren't really badly mangled.
Dale
iceNine is offline   Reply With Quote
Old 01-29-2003, 05:46 PM   #4
rhdude
Member#: 6637
hum, just an idea, if the block was female, you could use a tap to rethread it but with bigger threads, then get an adapter to match up the oil line threads to the newly tapped hole?.. just an idea...
Old 01-29-2003, 05:49 PM   #5
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
I'm ussually pretty careful working on cars, I have no idea how I got so stupid while I was doing this. The head is female, and a banjo bolt goes into the head to supply the oil line. I stripped the threads putting the banjo bolt into the head.
Old 01-29-2003, 05:51 PM   #6
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
the helicoil is basically the same as tapping. you have to remove whatever is in there first, drill out the threads and then insert the helicoil. the helicoil is now your thread.
check this page out for the right size you need
http://www.ersco-mi.com/helicoil3.html#top2
Wheeler Bement is offline   Reply With Quote
Old 01-29-2003, 08:18 PM   #7
TaiChih
Member#: 3467
1998 Dinan3
Bleck
I hope no metal shaving will be going into the engine block when you go to repair this. Helicoil is a thread repair. essentially, if the hole is stripped, the helicoil acts as a sleeve for a larger new hole, but the inteior of the thread will be the same. here...
Drill - Drill out the damaged threads using the drill size specified in the catalog. Drill to sufficient depth to accommodate the insert length and bolt or screw being used.
Tap - Use the Heil-Coil Tap specified in the catalog. Check the size on your shank to make sure you have the right one. Tap the hole to sufficient depth to accommodate the insert length and bolt or screw being used.
Install - Use the specified installation tool. Just wind the insert into the hole until the top coil is 1/4-1/2 turn into the tapped thread.
Note: Remove tang with the appropriate tool specified.
TaiChih is offline   Reply With Quote
Old 01-29-2003, 08:20 PM   #8
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
That's exactly what a helicoil does. You tap a new hole slightly bigger and then thread in the helicoil. A helicoil is basiclly a wire wound really close together.
I've done it several times on bikes, so I could help out...the only problem is that I have no idea the next I'll be home. It may not be until my spring break (second week in Mar)
Jim
Impreza Rider is offline   Reply With Quote
Old 01-29-2003, 11:25 PM   #9
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Ok I think the helicoil idea is a bad one due to all of the metal shavings that are probably going to end up in my motor and/or turbo no matter how careful I am. The other thing I can do is block off the oil fitting in the head completely and get the oil from the oil filter housing. This is a better location for the feed anyway as the oil is coming straight from the filter. The problem now is how do I block off the head? I could retap it and put a bolt in there to block it off... but I have never used a tap before and don't really want to learn on my head. Is there any good way to block it off without retapping? Or is there anyone who wants to help me tap that head... well that doesn't sound right at all.
Old 01-30-2003, 12:20 AM   #10
rhdude
Member#: 6637
BWHAHAHAHAHAHAHAHAHAHAHAHA omg.. BWHAHAHAHAHAHAHA
seriously tho... I know Steve has some taps and dies... ask him to help you "tap that......."
Old 01-30-2003, 06:51 AM   #11
Adrift
Member#: 15528
2006 Aspen White
20G'd STi - Long Gone :^(
It sound like all of these options are gonna require the head coming OFF your engine.
Adrift is offline   Reply With Quote
Old 01-30-2003, 07:07 AM   #12
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
JB Weld.... I've used it to hold in a helicoil for a sparkplug before. it worked for about 250 miles... And that was under the pressure and heat of the cyl. For your application, it could last permanently. I would recomend it as a LAST resort. But you could use if for blocking off the hole. Just put a good bit around the bolt and stick it in.
cavymeister is offline   Reply With Quote
Old 01-30-2003, 12:56 PM   #13
BossGVR4
Member#: 1541
2001 Lexus GS430
Black Onyx
Default DSM mode ON
Ummmmm yeah ......
You should get a $50 oil line kit from roadraceengineering.com or turbotrix.com and feed nice COOL FRESHLY FILTERED oil to your turbo. NOTE getting the bolt out of theoil filter bracket/housing is a PITA and you will need airtools or a LONG breaker bar.
As for keeping shaving out of your motor .. not gonna happen as long as the head is on there and you are tapping it. You can "try" to be careful when doing it but some will inevitably fall inside the head. If your head is fresh then I would pull it do the fix and have it hot tanked and cleaned again. If it hasnever had anyting done to it (valve job, stem seals) then I might just say eh F- IT and do the repair.
Just my .02
DaveC
BossGVR4 is offline   Reply With Quote
Old 01-30-2003, 01:07 PM   #14
TaiChih
Member#: 3467
1998 Dinan3
Bleck
to do it right, your options are
1. pull the head and retap it with helicoil to prevent shavings from entering the cylinders and scratching up the cylinder walls, and get blow by......
OR
2. see option 1.
Of course, you could try jb weld and the likes, but
Old 01-30-2003, 02:14 PM   #15
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Well this isn't good news... I hate this damn car! I just had the head rebuilt maybe 50 miles ago. When it was in the shop the turbo "mysteriosly" goes bad, I sue the shop, shop goes out of business. I replace the turbo, and just about everythine imaginable goes wrong. I really don't want to have the head pulled off the car yet again. I guess I should have just paid curry's there $400 - $600 to replace the turbo... Oh well so much for saving money.
Old 01-30-2003, 02:19 PM   #16
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Wait a minute? The head is aluminum. Know I know getting aluminum shavings into the block isn't exactly good for the motor, but I wouldn't think that aluminum would be able to scar steel, since aluminum is so much softer? Of course I am an idiot lately, so what am I missing?
Old 01-30-2003, 02:32 PM   #17
TaiChih
Member#: 3467
1998 Dinan3
Bleck
sure, aluminum is softer than steel, but what is your piston ring made of? would you want to risk a blown motor, all because you wanted to save money on removing the heads,. Seems, to me, it just gets worse everytime you try and save money. Save money. It's up to you, it's not my motor. tap away
Old 01-30-2003, 02:56 PM   #18
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
The problem is that I don't have a garage or anywhere to work, so I would probably have to take the car to someone. There isn't anyone around here that does decent work for a reasonable price. The last company that rebuilt my head charged me over $1200 and did a ****ty job. I don't really have any more money to put into this car, so I don't know what to do.
Old 01-30-2003, 03:02 PM   #19
TaiChih
Member#: 3467
1998 Dinan3
Bleck
It's not like you have to get the heads rebuilt again, just remove them, tap and reinstall( the hard part about retorquing them in a particular order)but, you will have to pull the motor though. Who was the original co that messed it up to begin with and who rebuilt it recently?
Old 01-30-2003, 03:08 PM   #20
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
This is the laser (inline DOHC) not the subaru, so you don't need to pull the motor to do the head. The guys that rebuilt the head and messed up my turbo and other thinns here and there was ODM in Manassas, they used to specialize in DSM's until they went out of business 5 days after I filed my lawsuit.
Old 01-30-2003, 03:16 PM   #21
TaiChih
Member#: 3467
1998 Dinan3
Bleck
ok, so where is the stripped oil hole located on the motor (exactly, pic would help) and is therea lot of space to work around the area, or is it a tight fit? You could possibly take the valve cover off and catch all the shavings that would fall in and then do a helicoil insert.
Old 01-30-2003, 03:23 PM   #22
BossGVR4
Member#: 1541
2001 Lexus GS430
Black Onyx
Default OFF-Topic ODM
I never heard good things about ODM ... I never heard of or saw a car that could run (at the track or otherwise) come from that shop. The only person working there that was cool was Brad Bauer .... so believe me when i say he probably never touched your car.
I watched them work on a car and put the parts in little ziplock bags and write with a Sharpie what they were. Anyone who claims to be a GOOD DSm mechanic should be able to get by with one of those magnetic tray that hold all your bolts. .... nuf said
I can pull a DSM head in about 1 hour. My Headwork cost me $175 at L&M machine in Woodbridge. New timing belt and accessory belts run about $90.
DSM area PAIN to work on but I have torn down and rebuilt 2 Galant VR4's. I am sick of it and am buying a Forester and some kind of Suby Turbo in the future. MITSU SUCKS
Old 01-30-2003, 03:37 PM   #23
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
So are interested in making some money and working on my car?
Old 01-30-2003, 03:54 PM   #24
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
The last pic on this page shows the location of the oil feed line on the head, this one is already blocked off with a bolt, so the oil feed goes right where that little hex bolt is. I don't remember if you can get to the feed line from the inside by removing the valve cover or not. I am trying to find a picture with the valve cover off.
http://www.vfaq.com/mods/2G-16G.html
Old 01-30-2003, 03:58 PM   #25
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
I don't know how bad you stripped the threads, but before you do ANYTHING further to them, try using a thread chaser first. It's sort of like a tap, but it can't start the threads, there has to already be a little bit of something left to the old threads, you screw it in, and it'll push out any shavings or reform any smashed threads, within reason. Try using one of those first. If you can't get any reasonable help by the weekend, I'll bring my tap sets up from Richmond when I come back on Monday morning, I've got 4 sets.
SubyNewbie is offline   Reply With Quote
does anyone know how to use adobe master collection wrxking108 Mid Atlantic Impreza Club -- MAIC 5 04-14-2010 10:30 PM
Does anyone know how to navigate to single-posts? geedar Newbies & FAQs 4 03-15-2010 11:03 PM
Does anyone know how to get a dog to start jumping? JBravo920 Off-Topic 36 09-03-2009 05:57 PM
Does anyone know how to podercoat or paint stock rimss WRX2fast04 Interior & Exterior Modification 2 08-23-2003 03:58 PM
Message Board Statistics All times are GMT -4. The time now is 01:49 PM.
