Old 05-05-2001, 08:50 AM   #1
Dirt Man
Member#: 176
2011 Subaru Forester
Talking Warranty's Up, Time for an Intake! Suggestion?
Well, I'm 1000 miles past my warranty, and It's time for MORE POWER. I like the Ralli Spec intake unit alot but I have a 99rs and I'm trying to figure out If I need a SAFC along with the Intake to prevent the car from leaning out. PLEASE HELP!
Note: I realize that the JC Sports intake unit is a good alternative but I've heard a zillion horror stories about the company
Dirt Man is offline   Reply With Quote
Old 05-05-2001, 09:10 AM   #2
AFS Motorsports
Vendor
Member#: 1768
Post
I have the Wepon-R intake on sale, $175 shipped.
Shawn
[email protected]
765.471.4600
AFS Motorsports is offline   Reply With Quote
Old 05-05-2001, 10:59 AM   #3
M a t t 2
Member#: 5503
2000 Impreza 2.5 RS
BRP
Post
get the rallispec. i have it and love it! its soo loud and the sound is awsome. power is very very good too. no more lag at 4500rpm.. in other words you'll gain some nice high end power!
M a t t 2 is offline   Reply With Quote
Old 05-05-2001, 01:29 PM   #4
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
Post
Does changing the intake to anything like a Ganzflow style affect the warranty? I thought it did not.
This is my intake, should I change it back everytime I go get the car serviced to avoid problems???
<IMG SRC="http://albums.photopoint.com/j/View?u=1654202&a=12666180&p=47327171&Sequence=0" border=0>
Thanks,
Stefan
Freeskier is offline   Reply With Quote
Old 05-05-2001, 02:14 PM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
He's got a 99 cant do that one.
<IMG SRC="http://albums.photopoint.com/j/View?u=1471714&a=11073907&p=47912239" border=0>
That's what I did.
Peaty is offline   Reply With Quote
Old 05-05-2001, 02:52 PM   #6
Eric Gagnon
Member#: 46
2001 Jetta 1.8T
Post
I would recomend the Rallispec. It is very sturdy, great quality, works well, and top craftsmanship.
<IMG SRC="http://albums.photopoint.com/j/View?u=1666394&a=12773770&p=47919395" border=0>
Any ?'s e-mail me.
Eric
Eric Gagnon is offline   Reply With Quote
Old 05-05-2001, 04:52 PM   #7
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
First things first. Install an a/f guage and drive around with that for a while.
Install an intake, take your pick they all have pros and cons. Stay away from those that require oiling, MY99 MAFs are notoriously sensitive to oil and vibration..
Watch the a/f guage at part-throttle all the way through the rev curve. Then watch the a/f guage at full-throttle all the way through the rev curve. You will notice that the car only runs lean at 5500 rpm only at WOT.
Your options at that point:
Install an SAFC.
Install a FPR.
Install a WBUGP.
SAFC=Super Air Flow Converter
FPR=Fuel Pressure Riser
WBUGP=Wooden Block Under Gas Pedal
Just for the record. I'm now 11 months 18,000 miles on the RalliSpec intake with no MAF faiure.
Eric you may want to oil that breather filter. The crank case breaths both out AND in on a continuous basis.
[This message has been edited by Revision (edited May 05, 2001).]
Revision is offline   Reply With Quote
Old 05-05-2001, 07:16 PM   #8
scottsubarus
Member#: 5336
1992 SVX
Post
Just had to reply, I installed a JCSports intake on my wife's 97 Legacy GT. We got the intake 6 days after it was ordered, except the support bracket, which after 2 calls we recieved. Didn't seem to loose much low end (low end's crappy on this car anyway) The first thing we noticed is when it hit's 4,000 on the tach it just plain takes off! (it's an automatic) even with beating the car it got 1-2 more MPG, plus my wife loves the sound! good luck!
scottsubarus is offline   Reply With Quote
Old 05-05-2001, 07:52 PM   #9
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Post
I love my rallispec intake, on my 99, the AFC isn't totally necessary but I would recommend it!
Anthony C
Bobalouy is offline   Reply With Quote
Old 05-05-2001, 08:10 PM   #10
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
Post
As I asked earlier, does the intake affect the warranty. I searched everywhere for warranty & intake info but found nothing.
Thanks,
Stefan
Old 05-05-2001, 10:28 PM   #11
Julian
Member#: 1182
MY00 RS
BRP
Post
It CAN affect the warranty. It all depends. What went wrong, how much of a bastard your dealer is, etc. But, my dealer happens to sell intakes in the parts department, so...
Julian is offline   Reply With Quote
Old 05-05-2001, 11:36 PM   #12
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
A intake should not under any normal circumstance void your warrenty. Few exceptions... you know if a piece of your intake broke off and shot into the enigne or something really strange like that. But just the presence of one of the car may make some dealers behave like bastards, but otherwise thats about it.
-B
Midwayman is offline   Reply With Quote
Old 05-06-2001, 08:24 AM   #13
aphleung
Guest
Member#:
Post
I don't think it will affect the warranty on your car, because you are not changing any engine internal components. I had an Acura 1.6EL before, I had an ARC air intake/chamber installed. I blew my stock header at about 18 month, the dealer was going to replaced it, but I had an aftermarket one installed instead. Then 2 months later, I blew the engine head (cam bearing die, then the cam shaft went off-center, which leads to broken valves and damaged piston head), the dealer replaced it with a new engine. They dealer says they'll cover everything as long as I don't touch the engine internals.
Old 05-06-2001, 08:29 AM   #14
Dirt Man
Member#: 176
Post
Thanks everyone! Keep the responses coming!
My dealer has been awesome, so I dont forsee any conflicts with them. However an issue was brought to my attention that If you auto-X (which I intend to do) an Intake will bump you out of class (G-stock or STS). So at this point I'm thinking of just the K&N and taking out the fender plastic
Old 05-07-2001, 12:59 AM   #15
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Taking out the fender plastic will bump you out of GS as well.
Frankly the RS isnt real competitive in GS. you'll have more fun and be able to do more in STS/STR
-B
Old 05-07-2001, 11:33 AM   #16
T-WReX 2.5RS
Member#: 5105
2000 Impreza
Post
JCSports intake and exhaust is a great package.
tony.
T-WReX 2.5RS is offline   Reply With Quote
Old 05-07-2001, 02:02 PM   #17
BHONE78
Member#: 6397
2001 R.S.
BLUE
Thumbs up
www.cobbtuning.com THE BEST BY FAR in my opinion, great design, dyno tested sube owner approved.<FONT COLOR="Blue">Text</FONT c>
BHONE78 is offline   Reply With Quote
Old 05-07-2001, 05:52 PM   #18
Eric Gagnon
Member#: 46
2001 Jetta 1.8T
Post
Bhone78 - he has a 99 and Cobbs intake doesn;t work with a 99. We have our own issues to contend with the 99 RS.
Eric
Old 05-07-2001, 10:08 PM   #19
rbehny
Member#: 1908
Post
i'm not sure but did cobb release the dyno tests on his intake? Let me go check
rbehny is offline   Reply With Quote
Old 05-07-2001, 10:09 PM   #20
rbehny
Member#: 1908
Post
unless i missed it they aren't there. Can some one send them to me if you do find them..? [email protected]
Time for new tires... suggestions? Sentinal North West Impreza Club Forum -- NWIC 10 12-15-2008 01:55 AM
Time for an up/dp install....north ga Swine South East Region Forum 6 05-25-2004 04:18 PM
('93-'01) What's the 0-60 time for an automatic WRX? G4 RSX Impreza Forum 13 06-02-2001 09:02 AM
Time for an intake.... GooseMan Normally Aspirated Powertrain 14 03-30-2001 12:12 AM
Time for brakes...any suggestions? Aaron'z 2.5RS Technical Forum Archive 10 08-18-2000 12:51 AM
