Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 05-05-2001, 03:14 PM   #1
Chin
Member#: 632
'14 Audi RS5
'00 RS Track Car
Have a Nice Day? Help! Clutch is dead
I am looking for a little help. I went to bleed my clutch today because it has not been feeling right as of late. When my buddy pushed in the pedal I opened the valve, fluid rushed out and I closed it. Then my buddy said that the pedal did not return when he let it go. What is going on here? I was able to pull it back to its resting position and it feld like a switch. It would either stay in its normal resting place or if I pushed it in, it popped all of the way to the floor. I noticed that the little pushrod was indeed moving in and out with the pedal, but the lever it was supposed to push against was not returning when the rod did. Anyone know what would cause this? If it is the clutch do you think it would be covered by the powertrain warranty? I've already gone past the regular warranty miles. Thanks much for any help you may provide.
Christian
Chin is offline   Reply With Quote
Old 05-05-2001, 04:01 PM   #2
Chin
Member#: 632
'14 Audi RS5
'00 RS Track Car
Post
Bumpity-Bump. Come on, can someone please help me with this?
Old 05-05-2001, 04:44 PM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
The clutch is just a pump. Push it in and it will stay down if you are bleeding it. You must then pull the clutch back up by hand to pump more fluid. If the actuator rod inside the car is not returning with the clutch pedal, there is likely a missing pin or bolt.
Revision is offline   Reply With Quote
Old 05-06-2001, 08:21 AM   #4
Chin
Member#: 632
'14 Audi RS5
'00 RS Track Car
Thumbs up
Hey, thanks for the reply. I don't think it is the master or secondary cylinder that are causing the problem. The little rod moves in and out with the clutch pedal, it's the lever that goes into the tranny that is not returning leading me to believe the pressure plate is not providing any force to clamp the disk. I will look into it being something else as you mentioned, however. Thanks much. Anyone else have an opinion?
Christian
Old 05-06-2001, 10:31 AM   #5
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Post
its not a problem. it happens in my car and in any rs and GT. its not a cylinder problem.. i am not sure what it is... but dont worry! it does return if you pull it back and works just fine again!
Mike
SubaTubaru is offline   Reply With Quote
Old 05-06-2001, 01:58 PM   #6
Chin
Member#: 632
'14 Audi RS5
'00 RS Track Car
Lightbulb
Update... I looked into Revision's advice and it may be closer than I originally thought. I went and looked at a friend's RS and I noticed that the lever that goes into the tranny case is not in the wrong position. It appears that the piston is not fully extending so the rod extending out of the cylinder does not contact it. If it fully extended it would push on the lever and it would slide back an inch or two. I tried pumping the clutch about 30-40 times but it didn't do much. Now, at the last inch of travel on the pedal you can feel the rod contact the lever and push it just a bit. Why can't I get the hydralic pressure back?
Christian
My clutch is dead at 42K is this normal? Ripper Normally Aspirated Powertrain 9 06-07-2012 07:46 PM
WRX down for 3 months now and the clutch pedal is dead? Si2WRX Transmission (AT/MT) & Driveline 4 07-12-2004 12:11 AM
HELP - Wastegate is dead !!! MyRuRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-09-2003 01:08 PM
Need Help!!!!! Car is Dead!!!!! Mprezive Normally Aspirated Powertrain 17 03-06-2001 12:41 AM
