Old 01-29-2003, 06:41 PM   #1
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
Default I'm actually an engineer, but... I crippled my fuse box. Help.
Okay, so first I'm not an idiot, but right about now I feel like one. I was testing circuits in the fuse box to see what was on the "accessory" switch and what was on the "on" switch. Where I went wrong is I was pressing the positive needle from my multi-meter in the fuse holders, and of course grounding the other. Problem is the needles are thicker than the fuse contacts and I bent the contacts inside the fuse box. Now my fog light fuse will not stick and a couple others may be damaged. I didn't test any vital circuits thankfully. Anyway, can I pull the cover off of the fuse box and get at all the contacts so that I can bend them back into shape? I REALLY don't want to have to replace the entire fuse box. Any advise as to taking off the cover would be greatly appreciated!
Thank you
fastfood is offline   Reply With Quote
Old 01-29-2003, 07:04 PM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Which fuse box, the one under the dash, or the one in the engine compartment?
Either way you should be able to get at the contacts and rebend them. It might even be possible from the "front" by using some dental type tools. But as you need to bend them so they grip fairly tightly, it will probably neccessitate getting to the back.
Oh, and I hope I don't have to mention the obvious, but I will - DISCONNECT the battery!!
Alan is offline   Reply With Quote
Old 01-29-2003, 07:07 PM   #3
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
Thanks.. and yes I will disconnect the battery. It is the interior fuse box.
Old 01-30-2003, 11:10 AM   #4
rory-wrx
Member#: 26303
2003 WRB GGA w/ 5MT
I can see clearly now...
If bending the contacts back doesn't work:
wrap each of the blades of the fuse with something (cut up soda can w/ coating sanded off or heavy duty aluminum foil) that increases the width of the blades enough to get a tight fit in the fuse holder. The soda can is probably the better approach because it will be easier to get it out if (when) you need to change the fuse. Just be sure that the shim material is long enough to extend out the fuse slot (so you have something to grab if it stays behind when removing the fuse).
rory-wrx is offline   Reply With Quote
Old 01-30-2003, 11:42 AM   #5
bemani
Member#: 5673
02 bug eye, 05 LGT
You can just solder new fuse holder into the fuse box. 5 minute job.
bemani is offline   Reply With Quote
Old 01-30-2003, 11:49 AM   #6
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
Yeah Iwas thinking of just adding some solder to the terminals on the fuse to add thickness. Should be easy enough.
Old 01-30-2003, 01:03 PM   #7
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
Default Fixed!
Well, it's not back to original condition, but it's working safely. I just bent the end of the fuse so there is a kink in them. Sort of a spring. Anyway, the contact is good, and my fog lights are running safely!
Thanks for all the advise. I new I could count on i-club!
Old 01-30-2003, 03:48 PM   #8
Rally1
Member#: 20633
most fuses have a contact on the top of them too, so you could just leave them in (next time ) and still test.
Not sure if the ones in our cars do but, i would think so.
see:
Rally1 is offline   Reply With Quote
engine dress up stuff - carbon fuse box, carbon solenoid, beatrush, and more! anthonyrb98 Exterior/Styling 38 03-04-2007 11:48 PM
That's it, I've decided, I'm doing an engine swap. Siper2 Mid Atlantic Impreza Club -- MAIC 27 08-02-2006 02:08 PM
i'm not a drinker, but it was my birthday hitman912 Off-Topic 19 07-21-2005 03:20 PM
I'm so an engineer.... Legacy777 Texas Impreza Club Forum -- TXIC 27 06-12-2005 02:02 PM
I'm actually an engineer but... I crippled my fuse box! fastfood New England Impreza Club Forum -- NESIC 8 01-30-2003 06:09 PM
