Old 05-05-2001, 07:53 PM   #1
dandbest
Member#: 1885
2015 Evo
Question Changed my spark plugs today....
Hey everyone!
Today I changed the plugs on my 01RS, and ofcourse, yet again (I had a 99RS)I found Champions in the motor. First, my car only has 7500 miles, but from everything I've heard on the board, I decided to change them.
So, I looked in the owners manual, and it called for NGK BKR6E-11. So I went and bought them. When I had my 99RS, the owners manual called for NGK BKR5E-11, so thats what I put in it. I still have the old Champion plugs from the 99RS and they are the same part number as those I took out today, out of my 01RS. I'm very curious as to why the 99RS uses the BKR5E-11 and the 01RS uses BKR6E-11. If someone has the answer, please tell me.
Thanks in advance
Danny
dandbest is offline   Reply With Quote
Old 05-05-2001, 08:21 PM   #2
jacktam1
Member#: 1783
2000 2.5RS
Post
coz my98 and my99 use +5(hit range),my00+ uses +6,1 degree different!
jacktam1 is offline   Reply With Quote
Old 05-05-2001, 08:34 PM   #3
dandbest
Member#: 1885
2015 Evo
Post
Ok, but my question is why do they use different heat ranges!
Thanks again
Danny
Old 05-06-2001, 01:07 AM   #4
jacktam1
Member#: 1783
2000 2.5RS
Post
from what I know,MY00+'s ignition timing are more advanced, so it uses colder spark plugs.
Old 05-06-2001, 07:56 AM   #5
dandbest
Member#: 1885
2015 Evo
Post
If that is true, why do both years use the same Champion spark plug to begin with? Same part number, which would suggest that nothing has changed as far as fuel and timing is concerned. Right?
Danny
Old 05-06-2001, 09:38 AM   #6
PunksWRX
Member#: 5504
2004 Impreza WRX STi
Post
Danny,
Did you remember to use anti-seize on the threads?
Punk
PunksWRX is offline   Reply With Quote
Old 05-06-2001, 11:21 AM   #7
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Post
Yep, my car had "Chumpions" also....
ARG
ARG is offline   Reply With Quote
Old 05-06-2001, 04:32 PM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
danny, the colder plugs arrived in MY00 with the 10.0:1 compression ratio. NGK "6" heat range is correct for this model year and newer.
98-99 2.5RS with 9.7:1 CR (dohc or sohc) use an NGK "5" heat range.
I ran an NGK 6 heat range in my cammed '99 RS for about 2 weeks and noted a bit less performance and definitely a poorer idle quality. Back to the 5s now...
ColinL is offline   Reply With Quote
Old 05-06-2001, 06:01 PM   #9
Overtime
Member#: 1346
Post
Doh! I bought the 6s per NGK's reccomendation.
I'd be really torqued off if they were more than $6.50 a set.
Overtime is offline   Reply With Quote
Old 05-06-2001, 06:31 PM   #10
dandbest
Member#: 1885
2015 Evo
Post
PunksWRX- Yes I did remember to put anti-seize on the threads, but couldn't find my torque wrench, so I didn't torque them down right. I just did it first by hand, and then like half a turn with the ratchet. I wonder if that's OK... Should I take them out and redo it?
Colin, thanks for explaining it! Thank YOU.
By the way, why do 99 and 01 use the same part number Champion plug? Colin?
Danny
[This message has been edited by dandbest (edited May 06, 2001).]
Old 05-07-2001, 07:30 AM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I may still have my stock chumpions somewhere, but I don't know what part number they are. It doesn't matter much-- I wouldn't put champion plugs in my lawnmower.
Old 05-07-2001, 01:21 PM   #12
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
well since we are on this topic
what is the gap on the plug did you guys set at?
thanks
michael
[This message has been edited by Michael (edited May 07, 2001).]
Michael is offline   Reply With Quote
Old 05-07-2001, 06:00 PM   #13
dandbest
Member#: 1885
2015 Evo
Post
Mike, the owners manual says to set the gap between .039-.043, so I set it at .042 .
Danny
Old 05-07-2001, 08:44 PM   #14
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Cool
thanks dan
sheesh... that was in the owners manual?
i must have mis it some how....
thanks again dan
michael
So I go to change my spark plugs... clsmooth Vancouver Impreza Club Forum -- VIC 3 05-02-2006 09:03 PM
Changed my spark plugs today Nicklbrso General Community 14 05-21-2004 03:36 PM
Should i change my spark plugs? titanium wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-25-2004 02:12 AM
Can someone help me change my spark plugs ? bigbird Mid Atlantic Impreza Club -- MAIC 3 10-04-2001 03:46 PM
Just changed my spark plugs Fusion Normally Aspirated Powertrain 16 08-15-2001 05:31 AM
