Old 01-30-2003, 01:13 AM   #1
smjkxsnoopy
Member#: 25199
2003 wrx
platinum silver
Default can someone plz help~!!~(foglights)
hi..... i installed some new headlights the other day and after the install, my foglights arnt working for some reason. I didnt even fidle with the foglight area....what did i do wrong??? I checked the fuses and nothing was wrong with them....is there a wire below the steering wheel column that connects to them thats mayb loose or something????can someone help plz?~!? thanks a lot
smjkxsnoopy is offline   Reply With Quote
Old 01-30-2003, 06:36 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What headlights did you install? Did you use an adapter harness?
If there is a problem with how the new lights are wired to the factory connections it could cause the fogs to stop working. This is because the fogs are wired to work only with the low beams, and if the lights are mis-wired in such a way that the high beam circuit is being energized when the low beams are selected it will prevent the fogs from operating.
If you used supplied plug-and-play harnesses with your new lights it is possible that they were not wired correctly. This is unfortunately a common problem.
Old 01-30-2003, 04:40 PM   #3
smjkxsnoopy
Member#: 25199
2003 wrx
platinum silver
well there was a harness coming from both high beam and low beam....i juss took out my stock headlights.....and pluggged the harness to the wire......
Old 01-30-2003, 04:54 PM   #4
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Plugged the harness to what wire?
Narcisse91 is offline   Reply With Quote
Old 01-30-2003, 04:59 PM   #5
rory-wrx
Member#: 26303
2003 WRB GGA w/ 5MT
I can see clearly now...
Unless that harness was designed for a ground switched control system you could have problems. Subaru switches the ground side of the circuit, not the hot like many others.
rory-wrx is offline   Reply With Quote
Old 01-30-2003, 06:20 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
But which headlights did you install?
By any chance are these the $150 ones, if so there is a known problem with the harnesses not being wired correctly.
Old 01-30-2003, 06:43 PM   #7
smjkxsnoopy
Member#: 25199
2003 wrx
platinum silver
yea it was the cheap ones....i got them for a present.....so what is it that i need to do now tat u kno wat lights i have??
Old 01-30-2003, 06:59 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, I helped someone with these a while back. The problem was that the black and red wires in the harnesses that plug into the car are reversed. If you swap these wires on both headlights everything should work correctly.
Old 01-31-2003, 12:32 AM   #9
smjkxsnoopy
Member#: 25199
2003 wrx
platinum silver
ok so take the wires out of the harness coming from the headlights.....and switch the black and red around....than click the harness back.....and put it back??? o yea btw....thx u are a great help
Old 01-31-2003, 09:56 PM   #10
smjkxsnoopy
Member#: 25199
2003 wrx
platinum silver
well i realized that each time i took out the plug off my headlights, the foglights worked.....but whenver i puit in the plug form the headlights, the foglights would stop working again....i think theres something wrong with my harness connection or something.....hmmm anyone kno how to fix it???? or where they selll the proper harnesses?? plz help....
Old 01-31-2003, 10:40 PM   #11
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Someone just told you the wires on the harness are backwards... Seems you should try swapping them.
Can someone help me out... Plz! (need stock WRX wheels) PacmanGSX Mid Atlantic Impreza Club -- MAIC 2 01-17-2008 08:53 PM
Knock correction Can someone plz explain Mr.Krinkle Engine Management & Tuning 4 09-07-2007 06:42 PM
Can someone plz post this article? I can't read it here at work EnforcerPSU Off-Topic 4 04-28-2006 09:51 AM
Can Someone HELP me PLZ!!! Jchan27 Mid West Subaru Owners Club Forum -- MWSOC 16 12-30-2003 10:11 PM
Austin: Can someone clear out my CEL plz? treybomb Texas Impreza Club Forum -- TXIC 10 03-04-2003 11:32 PM
