Old 01-30-2003, 12:24 PM   #1
rally25
Member#: 32056
2003 Impreza RS
Blue Ridge Pearl
Default Adding Driving Lights to 2003 RS
I want to add some Hella Driving Lights to my 2003 RS. I beleive the wiring is already in place since lights are standard on the WRX. I know I need a switch. Are there any other parts required such as a relay? Anyone tired this yet? Anyone have any wiring information?
Thanks
rally25 is offline   Reply With Quote
Old 01-30-2003, 02:31 PM   #2
rory-wrx
Member#: 26303
2003 WRB GGA w/ 5MT
I can see clearly now...
The in-place wiring is likely for foglights. While this is a good place to start, it is not sufficient. The fog lights are activated by a dash switch and are wired to come on only with the low beams. You'll find a mod on this board (and others) to make the foglights activate whenever any lights (high, low, parking) are on.
Driving lights should activate only with the high beams. This will require a relay driven by the positive signal from the fog light switch (in the dash) and the negative (switched ground) signal from your high beams.
rory-wrx is offline   Reply With Quote
Old 02-02-2003, 03:39 AM   #3
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
The car is prewired for factory foglights. If you do go with the stock foglight wiring, you will need the foglight switch and the foglight relay. Your driving lights will only come on with the low beams though and they will shut off when you hit the brights. Not very useful for driving lights.
Khail
khail19 is offline   Reply With Quote
Old 02-03-2003, 04:33 PM   #4
tdxflex
Member#: 13634
either do the foglight mod and use the stock wiring, or do new wiring with a relay. i have my driving lights come on automatically when i have my high beams on without a switch
tdxflex is offline   Reply With Quote
Those who added WRX hoods to your RS suzuki4life Normally Aspirated Powertrain 19 09-17-2007 06:51 PM
wire driving lights to city light switch USAF_Pignose Electrical & Lighting 3 12-06-2006 10:58 AM
adding daytime running lights to 2000 RS polaris Electrical & Lighting 7 12-11-2004 06:04 PM
Adding intermittent wipers to '00 RS? Siper2 Electrical & Lighting 21 02-11-2004 02:13 AM
Adding fog lights to '99 OBS Ski4Ever Electrical & Lighting 5 01-02-2004 06:23 PM
