Old 01-30-2003, 11:31 PM   #1
Storm
Member#: 5218
96L Most Over-
Developed Beater
Question headlight mod?(not paint)
I've done a search for a headlight mod where the high and low beams will light up when I hit the highs. I didn't get any results.
Is there an easy way to do this without totally reworking the lighting harness? Would it be similar to the foglight mod? My 96L doesn't have the fogs anyway....I just want to use both beams when I hit the highbeams.
Thanks,
Jay Storm
www.sourcemotorsports.com
Old 01-31-2003, 12:23 AM   #2
rory-wrx
Member#: 26303
2003 WRB GGA w/ 5MT
I can see clearly now...
If you run both high and low beams at the same time you will have the same problems with the stock wiring harness as other folks have had when running overwattage bulbs.
Read about it here.
rory-wrx is offline   Reply With Quote
Old 01-31-2003, 07:08 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I believe your car uses H4 bulbs for the headlights. These are dual-filament bulbs(high and low beam in the same bulb) and they are not designed for both filaments to be on continuously at the same time. This will burn them out quickly. And yes you will also be drawing too much power through the wiring.
Old 01-31-2003, 10:52 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
I don't have a WRX with the wierd headlight connector problems. I have in the past run 85/100W bulbs with no problems other than the shorter lifespan. I have also installed a set of dual beam lights that are wired up seperately. Dual H7 bulbs on each side. Plus a relay to go into "citylight mode" when the HB is switched on and the main light is turned off. Both beams then light up at half power.
Is there a procedure for making the OEM lowbeam relay stay on when the OEM highbeam relay is triggered?
Thanks again.
Jay Storm
I want both to light up when I do this:
Old 07-15-2004, 06:50 AM   #5
spliffpirate
Member#: 66307
1994 Accord
Seige Green
try searching under HID Convertion Kit, you'll see a car that has HID & the high & low light up, but cant remember were Ill let u know when i see it again. Im doing research on my cars projection headlights, I wanna know if I can use the aftermarket ones with the HID kit.
spliffpirate is offline   Reply With Quote
Old 07-15-2004, 07:22 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This was originally posted a year and a half ago, I think he probably has figured it out by now.
Old 07-16-2004, 01:50 AM   #7
spliffpirate
Member#: 66307
1994 Accord
Seige Green
hahahahaha them thats twice!! well atleast now I know more on how this s h it works now!
WTT: Cleared 04 headlight for not cleared headlight STREETFAME16 Exterior/Styling 0 10-22-2009 03:47 PM
Rogue the game (not the mod, not the squadron, not the WoW) Reciprocity Off-Topic 17 03-06-2009 07:45 PM
03 headlight mod - low beams not working Bundyboyz Electrical & Lighting 1 09-19-2005 02:17 PM
