Old 05-08-2001, 07:11 AM   #1
Sidwindr
Member#: 3347
1999 Impreza 2.5RS-T
Silverthorn Metalic
Question 3.0 H6
anybody out there tried putting the new H-6 in an Impreza? Sport Compact Car thought the 2.5 and new 3.0 were close in size enough, and that the tranny mounting bolts would line up also.
Sidwindr is offline   Reply With Quote
Old 05-08-2001, 07:15 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
That would be nice. I would consider doing that if it actually works.
tmat3 is offline   Reply With Quote
Old 05-08-2001, 07:57 AM   #3
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Post
I wish I had a nickel....
donjuan is offline   Reply With Quote
Old 05-08-2001, 08:29 AM   #4
the_gille
Member#: 2847
'01 4x4 Ranger
'01 RS gone :(
Post
Screw a nickle, I want a million dollars.
Ben
the_gille is offline   Reply With Quote
Old 05-08-2001, 09:37 AM   #5
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Thumbs up
I think that would be a fantastic idea. There are a couple things to worry about though...
One, the 6 only uses automatic trannies. This isn't a problem if you want to put it on an automatic Impreza, but if you have a manual...you'd need a flywheel. However I bet (think, speculate, am not sure) that a Porsche flywheel would probably work. Maybe?
But, I am sure there will be some electronic issues. I have no clue what they might be thought.
Finally, it would be a very good idea to mess with the motor before you put it in. In stock form it really isn't that impressive. But if you could bump the compression ratio, do some head work...it could turn out to be a N/A monster! Thing is...I don't know of anyone in the US who has done any work to that motor.
Go for it!
D. Neil Crawford
Reciprocity is offline   Reply With Quote
Old 05-08-2001, 10:10 AM   #6
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
I thought this had already been talked about and that the H6 would not fit in the impreza engine bay.
remarcable is offline   Reply With Quote
Old 05-08-2001, 11:35 AM   #7
XT6Wagon
Member#: 524
04 STi
Post
Um, a EJ flywheel will work when using a EJ tranny. Nothing new or special about that as the trannies are the same.
Hoever stick to a turbo EJ-25 or a WRX swap unless you have the money to PROPERLY chase this idea down.
XT6Wagon is offline   Reply With Quote
Old 05-08-2001, 08:41 PM   #8
Hashiriya
Member#: 2798
2002 GDA
Midnight Black Pearl
Post
This has been covered numerous times.
Problem with this issue:
Weight= bad handling
Auto= no fun
length= bye bye radiator fans= over heat
height= need fabricated intake (intake is a few inches higher)
and not that fast anyway
and scarce.
So the best thing to do is stick with a turbo. You can probably get more HP out of a turbo EJ20 or EJ25 than a na H6
Hashiriya is offline   Reply With Quote
Old 05-08-2001, 10:57 PM   #9
XT6Wagon
Member#: 524
04 STi
Post
You CAN run the H6 with a Stick, and why not turbo it while you are at it.
3.0 H6 into 95 Impreza begins anders8 Subaru Conversions 45 05-10-2015 11:17 AM
NA 2.5, H4 and 3.0, H6 Alpha1 News & Rumors 19 06-02-2003 04:39 PM
Upgrade parts for 3.0 H6 engine? anders8 Outback Forum 1 05-12-2003 08:09 AM
('93-'01) Differences between 2.7 6cyl and 3.0 H6 engine? Jessie James Impreza Forum 9 06-25-2001 04:09 AM
2001 Outback wagons make 212hp w/ 3.0 H6 cakagan General Forum Archive 6 07-27-2000 10:45 AM
