Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 11-15-2005, 12:41 AM   #251
nate.the.great
Member#: 72031
hmmm, my installer didn't do a good job, and he removed my keyless module... he also didn't hook up my trunk, that's why i did it. interesting though, too bad i already ran the wire. thanks for the heads up. this thread should be a stickie.
nate.the.great is offline   Reply With Quote
Old 12-15-2005, 08:32 AM   #252
Astacun1
Member#: 31326
2002 Impreza WRX
Platinum Silver
I recently got a Python 881 XP car alarm with the optional tilt sensor, field disturbance sensor and a batery backup. My installer followed the instructions on this thread to wire the remote start, but there seems to be a problem with the neutral indicator. The neutral wire does not always send a negative signal when in gear. If I put the car in first it wont send a negative siganl unless I play with the shifter and move it a little while in gear. There are some positions of the shifter while in first that send the negative signal, but if I leave the shifter in first without applying pressure to it with my hand to force it to the position that sends the signal, the neutral wire does not send a negative signal. I have the same problem with second gear. It works beautifully in third. I dont know if any of you have had this problem. I have a short shifter and sti gearset installed, I dont know if this has something to do with it. Any ideas? Thanks in advance.
Eduardo
Astacun1 is offline   Reply With Quote
Old 12-15-2005, 12:36 PM   #253
02SilvaWagon
Member#: 33933
2011 WRX Limited
Eduardo
I'm gonna say these may have caused your problem. Sounds like things aren't lining up correctly in the transmission.
02SilvaWagon is offline   Reply With Quote
Old 02-08-2006, 01:21 AM   #254
veightkiller
Member#: 78967
2011 335i
i follow this thread with the help of netZ and i got everything hook-up correct wire and everything. when i tried to start using the remote the remote start activate but the engine wont turn over and it stay's in on position.am i missing something?i have the clifford RSX 3.5 alarm system..the green and purple wire are in the right place double check it and the tach sensor i tap it into my combination meter..NSS is hook up on the hand brake switch and the brake shut down is hook up on the brake switch underneath the brake pedal which is the black/white wire..the gray wire is hook up to my hoodpin and the grey and black wire from AUX harness is on consistent body ground..any idea or help will be appriciated..
veightkiller is offline   Reply With Quote
Old 02-08-2006, 01:42 AM   #255
02SilvaWagon
Member#: 33933
2011 WRX Limited
You have a few wires switched...
"grey and black wire from AUX harness is on consistent body ground"
You mean the wait to start input? You don't use that wire. Thats your biggest problem.
"NSS is hook up on the hand brake switch"
I have no idea what you mean here
"brake shut down is hook up on the brake switch underneath the brake pedal which is the black/white wire"
Isn't the brake wire in the car white/black?
How did you bypass the clutch?
Old 02-08-2006, 01:49 AM   #256
veightkiller
Member#: 78967
2011 335i
that is what i dont know..on how to bypass the clutch..
if i didn't use the gray/black wire and remote start it..it will activate and die.it wont stay in on position and yes neutral safety switch is hook up on my e-brake handle
brake shut down im going to double check it co'z its a bit crowded in there..the clutch..no idea me..co'z i dont know which wire to hook up on the clutch to bypass it..i dont see it on my installation manual.maybe you can help me out?
Old 02-08-2006, 02:20 AM   #257
veightkiller
Member#: 78967
2011 335i
anyone knows how to bypass the clutch switch on a rsx 3.5 alarm system..and yes it's wite/black wire on the brake shutdown..
Old 02-08-2006, 11:38 AM   #258
02SilvaWagon
Member#: 33933
2011 WRX Limited
veightkiller, I answered your questions in a PM. No need re-posting it here, since all those questions were already answered elsewhere in this thread.
Old 02-08-2006, 08:11 PM   #259
veightkiller
Member#: 78967
2011 335i
i got everything hooked up and everything runs fine..thanks to the help of netz and 02SilvaWagon i couldn't done it without this guys
Old 02-09-2006, 04:17 PM   #260
raoulduke
Member#: 25674
06 WRX Wagon
vf-39'd Silver
Default just wanted to add...
something to quynce awesome post...
just wrapped up a RS intall on my 06 wrx.
You guys may know this, but ALL the 06 turbo cars all have a factory anti-theft system which acan be easily bypassed by losing a key and using a DEI 556u. But don't go to all the AV retailers for it. I got mine at Target (of all places) for $30. Most places sell the EXACT DEI 556U for $55-60. Or you can get it on ebay-I just didn'want to wait. BTW, NO NEED FOR 556uw.
I also wanted to add that my park light wire was ORANGE, and was wrapped deep in the ign harness that comes from the park switch on the column.
Also, everyone having problems with finding/learning the tach wire:
The voltage sense on all the new 05/06 DEI RS modules (except BOA, and python) are now reliable. No need for tach sense. Josh (quynce) may disagree, but he knows I wouldn't said/done that a few years ago when it was a new feature. I used it on this install (after talking to my DEI guys) and it is working perfect.
---> I am wondering, however, if anyone has located a factory arm/disarm wire anywhere.
Thanks
raoulduke is offline   Reply With Quote
Old 02-09-2006, 04:47 PM   #261
quynce
Member#: 15409
Sounds like a Sutton or Bighead move to me...
quynce is offline   Reply With Quote
Old 02-09-2006, 06:09 PM   #262
raoulduke
Member#: 25674
06 WRX Wagon
vf-39'd Silver
yeah I know...but seriously, have you seen the new units? onboard relays-***...I don't like it. What are you gonna do.
The volt sense is better now though-if I have any issues I'll be sure to post.
Did you know Bighead is back at 186? What's the world coming to!
Old 02-09-2006, 06:57 PM   #263
quynce
Member#: 15409
Yeah, the onboard relay thing was just coming when I got out. I don't trust it either. Besides, if one fails you have to replace the brain instead of just one relay.
I can't believe they rehired Bighead. Actually, yes I can. But it's still sad.
Old 02-15-2006, 06:35 PM   #264
Dweller
Member#: 70013
2000 Legacy GT LTD
wire guide for 2000 legacy, trying to intall 791xv. im in westchester NY area.
I cant find wire guide.
Dweller is offline   Reply With Quote
Old 02-15-2006, 08:27 PM   #265
WRXMIL
Member#: 57680
2002 WRX Wagon
WRXMIL is offline   Reply With Quote
Old 02-15-2006, 09:19 PM   #266
AspenTR2006
Member#: 104288
2006 WRX TR w/GT30R
Hmm I personally have the Viper 791 system and love it!!
AspenTR2006 is offline   Reply With Quote
Old 02-15-2006, 09:22 PM   #267
joe r
Member#: 53412
2003 Outback
Black and Gold.
Thanks
Yes I have,they are also at the factory keyless mod to the left of the steering colum.
At this point my memorie is failing me so I will have to take my dash off to get you the wire colors.
I do know that unlock requires a double pulse when using these wires.
With all new alarm/remote starts you can program double pulse unlock or you can go oldschool & build your self a doublepulse unlock system with a few parts from radioshack.
Some one pm me about factory alarm arm & disarm wires please,so I don't forget!
The life of being an installer & smelling to many fumes,lol
joe r
joe r is offline   Reply With Quote
Old 02-28-2006, 05:22 PM   #268
Mystic
Member#: 89826
05 STI
some blue color
for the guys looking for the factory disarm wire its in the kick coming out of the door boot , i have it written down in my notes at my house a fellow installer told me about it i will look for it or ask him tonight and post it up ...
also i been reading and skimming in this thread and have one question if you take the black/white wire from the DEI system and tap it to the NSS wire from ECU shoudlnt it work ? it did not say on first page if it sends a - or + out so i wasnt sure ...i just did a nissan alimta 97 and when you put it in gear and sends a very weak + pulse to the black/white which doesnt let car tunr on but when out of gear sends a - to the wire and lets it start ...just need that answeard thanks
oh and i will post up when i get the wire color .
Mystic is offline   Reply With Quote
Old 02-28-2006, 06:11 PM   #269
02SilvaWagon
Member#: 33933
2011 WRX Limited
Mystic, from 2002-2004 the NSS wire shows (-) when in gear. 2005+ the NSS wire shows (-) when in neutral. If you are doing a 2005+ you can connect the NSS wire to the black/white NSS on a DEI unit. I actually use the (+) signal it gives in gear to trigger the brake shutdown on the remote start (diode isolated from the real brake wire). That frees up the black/white of the DEI unit to be connected to the parking brake wire in the car.
Pre-2005 most people are connecting the cars NSS to the hood pin input of the remote start.
Old 03-01-2006, 01:01 AM   #270
Mystic
Member#: 89826
05 STI
some blue color
aight i see , i am looking at buying a 2004 so just trying to collect some info but i want to do it right and just needed to now where the wire was and what polarity it was ....another real quick question does this wire test at all for voltage or should i just find the pin# and color and i will be all set?
Old 03-10-2006, 10:36 PM   #271
Brtnchild180
Member#: 98410
05 STI
ok all this is confusing, ok i have an 05 sti how do i get my alarm to set during the countdown? I dont want to mess up the engine kill.
Brtnchild180 is offline   Reply With Quote
Old 04-14-2006, 03:09 AM   #272
Cruckman4
Member#: 94544
2002 Impreza WRX
Midnight Black Pearl
I have an '02 WRX with an Autopage RS855 installed on it, well, somewhat installed I guess. I've been having a problem with it remote starting when the car is in gear. I used the NPS, diode isolated to the hoodpin, and for some unknown reason, it will still try to remote start with the car in gear. But when the hood is open, it wouldn't remote start. Any ideas?
Also, just tonight, my alarm started going off showing that my hood was open according to the transmitter. If I'd arm the car, it chirp three times at me saying "hey you idiot, you left your hood open," then a short while later the alarm would go off again thinking the hood was open. I checked to make sure there wasn't some freak chance the hood pin was able to suddenly come up with the hood closed, and it's not. Also with this, I now have no remote start. Wondering if maybe it could be something with the diodes? I really don't know.
I figured after work tomorrow I'd just trace the wires going to my hoodpin and make sure they're all okay and check the connections of the diodes. I can't remember the ratings of the diodes I used as I installed this in my car last year. Everything has been working fine since I installed it except for the remote starting in neutral. Now it just suddenly seems to be all sorts of messed up. I'd really appreciate any help or advice or suggestions. Thanks in advance.
Cruckman4 is offline   Reply With Quote
Old 04-14-2006, 03:37 AM   #273
netZ
Member#: 5743
2007 Kia Optima
gold brick
check your diode installation...
nps wire ----> cathode (diode) anode ----> hood pin wire to hood pin input
check your hood pin installation... it may not be properly adjusted, causing it to false.
thanks!
netZ
netZ is offline   Reply With Quote
Old 05-17-2006, 04:59 AM   #274
mtimmy
Member#: 115163
I am helping my friend to install a remote start in 02 Wrx...
the alarm only has voltage sensing input for alternator/oil pressure input...No tach learning...
can any body help me out on where to locate this wire?
mtimmy is offline   Reply With Quote
Old 05-17-2006, 11:31 AM   #275
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
Using a digital multimeter, check the wires in the harness coming out of the alternator. One will test a lowish voltage at idle and then increase with revving the engine.
-Jason
jay25RS is offline   Reply With Quote
2005 WRX/STI Alarm/Remote Start Wiring Info netZ Car Audio, Video & Security 4 05-05-2004 02:52 PM
Viper 790XV 2-way alarm/remote start, Plus Extras - Ultimate WRX Wagon Setup flames Private 'For Sale' Classifieds 0 01-06-2004 11:11 AM
Alarm, Remote Start, & Defroster... quynce Car Audio, Video & Security 16 01-15-2003 11:22 PM
Alarm/Remote start sale (i club only) action audio Mid West Subaru Owners Club Forum -- MWSOC 22 01-24-2002 03:16 PM
midwest alarm/remote start & install group buy Donnie Mid West Subaru Owners Club Forum -- MWSOC 9 10-19-2000 10:04 PM
