Old 12-26-2004, 02:35 PM   #176
Richard Schaefer
Member#: 76631
Default Neutral Wire
Can somebody tell me how exactly how to tie in the neutal wire in the hood pin circuit
I don't want to get wrong ground to the ECU.
Where do I find the connection for Voltage sensing? ( may be under the dash board)
Thanks Rs
Richard Schaefer is offline   Reply With Quote
Old 12-26-2004, 07:32 PM   #177
brunetmj
Member#: 8023
2004 2.5 RS
Year and model of the car? The neutral wire as well as the tach wire are found on connectors going into the ECU. Regarding the neutral wire: Once it is located on the connector a wire is spliced to it and then this wire is run into the engine compartment. Splice another wire on to the end of this wire you just ran through with a diode on one end and long enough to connect to the wire that goes to the hood pin.The stripe on the diode should face the ECU.
Here is a thread which may answer other questions concerning this.
http://forums.nasioc.com/forums/showthread.php?t=682417
brunetmj is offline   Reply With Quote
Old 12-26-2004, 10:27 PM   #178
Richard Schaefer
Member#: 76631
Default year, model
Hi
Thanks very much,
Subaru Imprezza Outback Sport 2001,
I'm just installing a Performance Teknique 7071 Alarm
I don't like to get into trouble starting the car when it is in gear
I' m getting older, and may be Alzheimer is standing soon in front of my door
My other problem is the Voltage sensing.
Can it be connected to the Tach sensing. It works without
RS
Old 12-26-2004, 11:56 PM   #179
valmiki
Member#: 52175
2003 wrx sport wagon
wr blue
Ok I got a question.
So you have the Neutral wire from the ECU. It kicks out -ve when its in a gear, 0v when in neutral
You have the hood pin switch, which kicks out -ve when the hood is open
, and 0v when its closed.
Then we're integrating the neutral out form teh ECU to the hook pin (with a diode of course)
So say I leave my car in 1st gear when I park it, I get out and arm the car...
Its gonna see a -ve on teh hood sense wire and think I left the hood open and bypass that zone when its armed right?
Is there away around this? Or do I have to park my car in neutral to get the hood armed?
Some help / explanations would be nice
Thanks
Valmiki
valmiki is offline   Reply With Quote
Old 12-27-2004, 09:50 AM   #180
netZ
Member#: 5743
2007 Kia Optima
gold brick
you answered it... if you can find a low voltage inverter, you could invert the transmissions neutral position switch signal from ground to 12 volts and tap it to the brake input. the inverter could be a miniature relay etc, the power source for this device would be off the 2nd ignition output off the starter relay pack which isn't used.
otherwise, if you leave the vehicle in gear your hood will not be monitored by the alarm/remote start system.
netZ
Thanks
Valmiki
netZ is offline   Reply With Quote
Old 12-27-2004, 09:22 PM   #181
Richard Schaefer
Member#: 76631
Default Neutral wire
Do I have to go with the wire up to the hood pin switch or can I also connect it direct bto the port for the hood pin switch on the main unit.
Thanks RS
Old 12-28-2004, 11:49 AM   #182
Richard Schaefer
Member#: 76631
Default Neutal wire conection to hood pin
What happens if I my hood is open and Start my car manual with the key
and the car is in gear? I'm sending 12volt+ from the ECU to the ground of the
hood pin switch! Is this right?
Does it make sense to put also a fuse in the Neutral wire connection to the hood pin
Thanks RS
Old 12-28-2004, 11:57 AM   #183
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
If your hood is open, and your in gear, the car should not start.
tooocool49723 is offline   Reply With Quote
Old 12-28-2004, 07:00 PM   #184
kb2spn
Member#: 28897
2004 STOLEN WRX STI
Blue/Gold
Thanks
Valmiki
I do my installations this way but I always arm the alarm manually,this way I am positive the alarm is armed and it will give an extra chirp if something is left open.Leaving the car in gear overides the hood pin.Use the e-brake for a second shutdown.
kb2spn is offline   Reply With Quote
Old 12-29-2004, 02:00 AM   #185
Richard Schaefer
Member#: 76631
My car kicks out 12 Volt while in gear and Ground in neutral
regarding B135 pin 26
RS
Old 12-31-2004, 05:04 PM   #186
valmiki
Member#: 52175
wr blue
Ok you'll remote start/alarm gurus... After contemplating lots while tidying up the wiring on the driver's side (I finishe out a roll of electrical tap I came to this.
Ok so we have the relay .. We connect the negative side to the ebrake (so it's only can be activated when its engaged)
We connect the positive to the 2nd ignition wire (so it's only getting +12v when we're in ignition... and since we drive with the ebrake disengaged all the time it'll not get negative)
then we have the NC, NO and the common part of the relay.
We connect NC to ground, so that if somehow the relay breaks it'll see ground.
We connect the NO to the ECU NPS wire.
We connect the common part to the input of the neutral sensing wire..
so with ebrake up and ignition... on it'll pass whatever the NPS is sending out. Otherwise its going to send ground...
Don't think we need a low voltage trigger anymore tell me if someone sees this not working.
Thanks
Valmiki
Old 12-31-2004, 05:51 PM   #187
kb2spn
Member#: 28897
2004 STOLEN WRX STI
Blue/Gold
re-think this one,the neutral safety wire will always be grounded,it should see a ground only when the car is in neutral.
Old 01-01-2005, 03:15 AM   #188
valmiki
Member#: 52175
wr blue
no it wouldn't..
the relay could only operate when the ebrake is engaged...
the relay will only operate when the ignition wire has power
having the output of the of the ecu hooked up to the NO connector, when the remote start is activated, the relay will close, and whaterve is on the NO connector will flow through to the common , which is connected to the neutral safety wire of the alarm.
of course putting a -12v on the NC connector of the relay couldn't hurt just to keep things safe if something related to the relay failed.
valmiki
edit: the reason the NC is grounded is if the ebrake is down, the relay will get no power, therfore you don't want it to start
ground = -12v
0v = 0v
don't ever confuse ground and 0v, never the same thing
Old 01-01-2005, 11:07 AM   #189
valmiki
Member#: 52175
wr blue
It should see 0v when its in neutral. When its in gear it sees ground which is -12v
Old 01-01-2005, 06:36 PM   #190
netZ
Member#: 5743
2007 Kia Optima
gold brick
this may not work with the dei alarm/remote start systems since the 'neutral safey sense' wire requires ground in order for remote start and/or valet take over mode to occur.
using your method will allow remote start to occur if the vehicle was in gear and the parking brake is engaged.
a low voltage trigger relay will detect the nps signal and if configured properly send 12 volts to the brake input. this method will allow the alarm/remote start system to properly monitor the hood pin input that would have been typically used in conjunction of the nps/ecu wire.
the best approach so far is wiring the transmission nps switch with diode to the hood pin and the ebrake wire to the neutral safety sense input of the dei system. yes, the hood isn't protected but the rest of the sensors should detect a break in (ie. vibrations etc).
netZ
no it wouldn't..
valmiki
ground = -12v
0v = 0v
Old 01-01-2005, 09:18 PM   #191
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
netZ
I can confirm it does NOT work with DEI/Viper I have tryed it today. Netz's way worked out good.
Hayaboosted is offline   Reply With Quote
Old 01-01-2005, 09:20 PM   #192
Hayaboosted
Member#: 60042
2004 WRX STI
Anyone know the way to bypass the factory alarm when the remote start turns on?? Step by step would help a lot. This is my last part and I will be done!!
BTW.. Yes I do still want my OEM alarm to work
Old 01-01-2005, 10:28 PM   #193
netZ
Member#: 5743
2007 Kia Optima
gold brick
i don't have my wiring schematics handy... so you'll need to do some more research on your particular year model.
but, wiring is simple... the blue status output will be used. if this wire is also used to bypass the clutch you will need to install diode from the blue status output to the clutch switch.
2 relays will be required, bosch type etc.
pin 85 on both relays to the blue status output between the diode and the blue status output of the alarm/remote start unit
pin 86 to ign2 or fused 12 volt source
cut the ignition sensing wire off the subaru security module, make sure you have enough length to work with.
pin 87 to ignition sensing wire subaru security module side
pin 30 to ignition sensing wire ignition side
cut the starter kill relay ouput off the subaru security module, make sure you have enough length to work wiith.
pin 87 to starter kill relay output subaru security module side
pin 30 to starter kill relay starter kill relay side
that's it...
netZ
Old 01-01-2005, 10:33 PM   #194
Hayaboosted
Member#: 60042
2004 WRX STI
Where is that Starter Kill wire from? also do you know what color the wire is?
Old 01-01-2005, 10:52 PM   #195
netZ
Member#: 5743
2007 Kia Optima
gold brick
http://techinfo.subaru.com
$20 will go a long way!
netZ
Old 01-01-2005, 11:04 PM   #196
Hayaboosted
Member#: 60042
2004 WRX STI
also what diode will I use?
Old 01-01-2005, 11:08 PM   #197
netZ
Member#: 5743
2007 Kia Optima
gold brick
radio shack 1n4001 or any 1n400x series. make sure the diode is installed in the correct orientation which prevents the clutch from sending ground back to the alarm/remote start system. the diode silver ring (cathode) side facing the alarm/remote start.
wire the 2 relays' pin 85 anywhere between the diode and the blue status output of the dei alarm/remote start system. diode isn't necessary since the blue status outputs ground only during remote start and valet take over mode. the diode on the clutch switch will prevent the clutch from triggering these relays.
http://www.radioshack.com/product.as...%5Fid=276-1101
netZ
Old 01-01-2005, 11:16 PM   #198
Hayaboosted
Member#: 60042
2004 WRX STI
netZ
20.00 a poor brother doesnt got right now! hehe
is it the same as this -> HERE
Old 01-01-2005, 11:24 PM   #199
netZ
Member#: 5743
2007 Kia Optima
gold brick
probably, go check the wiring section for the subaru security diagrams.
netZ
Old 01-01-2005, 11:30 PM   #200
Hayaboosted
Member#: 60042
2004 WRX STI
Yeah I have searched and I am unable to find the match.
2005 WRX/STI Alarm/Remote Start Wiring Info netZ Car Audio, Video & Security 4 05-05-2004 01:52 PM
Viper 790XV 2-way alarm/remote start, Plus Extras - Ultimate WRX Wagon Setup flames Private 'For Sale' Classifieds 0 01-06-2004 10:11 AM
Alarm, Remote Start, & Defroster... quynce Car Audio, Video & Security 16 01-15-2003 10:22 PM
Alarm/Remote start sale (i club only) action audio Mid West Subaru Owners Club Forum -- MWSOC 22 01-24-2002 02:16 PM
midwest alarm/remote start & install group buy Donnie Mid West Subaru Owners Club Forum -- MWSOC 9 10-19-2000 09:04 PM
