Old 01-31-2003, 09:30 AM   #1
Blue Goutist
Member#: 16294
02 wrx
Default legacy newby needs advice
just recieved 2000 L. Needs brake rotors, good ones. Also when I turn there is a clunk, need a fix for this. not sure if its suspension related or steering knuckle ect. Can someone tell me who the good legacy venders are. Thanks
Blue Goutist is offline   Reply With Quote
Old 01-31-2003, 09:51 AM   #2
cardin555
Member#: 9972
2007 Jetta
grey
For the brakes, DBA make excellent rotors. Have not had the chance to use them myself but come highly recomended. Perhaps subysouth can help here.
As for the clunk in the suspension, check the front stabilizer links. They are often the first thing to go in the front suspension.
cardin555 is offline   Reply With Quote
Old 01-31-2003, 10:43 AM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
lets see.
Rotors on 2000 L Legacy.
Fronts = 277x24mm [DBA 648]
Rears = 290x10mm [DBA 657]
For the fronts, plain rotors are available from Brembo and Mountain, et al. If you were considering slotted, go with the DBAs. I personally dont like the cross-drilled rotors, but other guys/gals here use them without probs.
As far as vendors, I will leave that to others to suggest. Nino in the vendor classifieds has carried DBA products at better prices than others, but he seems to have inventory probs. Do searches under (brembo and rotors) and (mountain and rotors) as well.
As far as the clunking goes when youre turning, not having heard it, it could also be a cv axle. Is it coming from a discernable side, if so visually inspect the boot on that side. The boot doesnt have to be compromised for the axle to be bad, but a lot of times it is.
HTH
ss
edit: Thought of some other stuff to add.
[Just FYI, I am currently using plain Subaru OEM rotors.]
I usually suggest to people with the 277mm or smaller front rotors to upgrade to the 294x24mm WRX sized front rotors. This is a great and inexpensive upgrade for the front brakes, in your case only requiring new caliper brackets and rotors.
However your case presents a circumstance I think I have not been presented with yet and deserves some discussion.
Your car is equipped with the largest diameter rear rotor(the only rotor larger in DIAMETER is the STi Brembo rear rotor) available on non-STi Subarus. Many other USDM Subaru owners upgrade to this rear rotor. Which means Subaru has factored that higher rear braking force into the system and still has a significant front brake bias assuming worst case scenarios. Meaning upgrading the front rotors is going to push an already heavily front-biased system to an even more front-biased condition. In your case, you might actually see less effective braking by going to a larger front rotor.
subysouth is offline   Reply With Quote
Old 01-31-2003, 12:57 PM   #4
cardin555
Member#: 9972
2007 Jetta
grey
Question Hmmmm...
I am sorry. I do not see how getting a larger rotor in front would give worse braking performance. The increase in size of the rotor would help in disipating heat and helping to reduce fade. I always thought getting a bigger rotor was a win/win situation with the exception of a slight increase in unsprung weight.
If this (and my understanding of the larger rotor) is incorrect, then I stand corrected.
Old 01-31-2003, 01:25 PM   #5
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Add to the fact that Subaru realized their problem on the GT's and all the aggressive drivers and for 01 upgraded the front rotor size.
and 02, 03, GT gets a larger rotor - cheap L's the the smaller one..
So, if you are an aggressive braker - get the larger rotor - as you are getting them now....
aross is offline   Reply With Quote
Old 01-31-2003, 04:56 PM   #6
Blue Goutist
Member#: 16294
02 wrx
well I replaced the rotors 4,000 miles ago, went to pep boys and bought the raybestos (should of went oem, how are they $ value vs DBA). One rotor is already warped. My girlfriend drives the car so there is no need to get crazy with the brakes ie:lots of money, probley go with oem. The clunk noise is not the suspension, It's in the steering collum. I did a search a while back and quite a few my00 legacy owners were having this problem. It does it up driveways. Took the car to the dealer and they said most legacys have this noise and its no problem. very annoying. Thanks again
Old 01-31-2003, 05:39 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
cardin555: better mechanical advantage with the larger front rotors plus the already front favoring bias in your car will cause the fronts to have considerably more power than the rears. Your fronts would lock up sooner than the rears causing your braking distance to increase.
Old 01-31-2003, 06:29 PM   #8
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Aha,
The illusive Legacy Clunk.
Mine was fixed by the dealer replacing the rack
Another member's clunk went away when he replaced his crossmember.
You choose.... If under warrantee push the issue - if not - go turbo and replace the crossmember..
Good luck
Old 02-01-2003, 11:49 AM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Re: Hmmmm...
A larger rotor is always better relative to heat dissipation but as ciper said if the front bias is to severe essentially at the front limit the rear tires are not effectively pulling their load in the process.
I have to admit being a little lucky in the stock setup on my GT. My upgrades are taking the fronts from a 277mm to a 294mm(+17mm) and the rears from a 266mm to a 290mm(+24mm.) All of the caliper piston diameters are equal in number and size. So effectively I have moved the overall bias slightly rearward. This is exactly where you want to be on the Subarus.
For instance, the Stoptech brake kit(a WRX exclusive product BTW) uses a significantly larger rotor but has a 10% drop in brake torque vs the stock WRX 2pots. It was Stoptechs intent to move some of the braking rsponsibility back to the rears to provide optimal performance braking. Subaru assumes a lone driver, an empty fuel tank and then adds some additional front bias when they set the cars up. Thats why people when they upgrade the rear brakes claim the car brakes flatter, its a genuine result.
Its a complicated subject. but thats the jist of it.
ss
Old 02-01-2003, 08:45 PM   #10
cardin555
Member#: 9972
2007 Jetta
grey
Thumbs up Thanks
That makes more sense Subysouth and ciper.
The clunk in the rack. Our dealer has replace the rack and pump on about 50 or 60 cars. Not dangerous, but just very noisy. I think Subaru is aware of this problem but has decided against a recall thinking warranty work will be cheaper. Our wharehouse always seem to have lots of these racks in stock (anticipating lots of orders, are we?).
Old 02-02-2003, 06:24 AM   #11
balyndraks
Member#: 28678
2003 Legacy L-SE Wgn
Mystic Blue Pearl
alright, regarding the brakes. i have a '03 Legacy L-SE wagon. the front rotors are the small 10.7" units. yes, the rear rotors are the big ones you mentioned. i was going to order the cobb stage 2 brake package which includes cryo treated wrx rotors, which are bigger...as mentioned. are you saying that i should just upgrade the pads and maybe go with braided brake lines, etc...leaving the stock rotors in? if so, i guess i could save about $300. thanks.
jay
balyndraks is offline   Reply With Quote
Old 02-02-2003, 11:17 AM   #12
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Thumbs up
go dba-stylee!
Word.
-Milan
US2JDM is offline   Reply With Quote
Old 02-02-2003, 11:35 AM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
jay
Yep, thats basically it. I really like upgrading the brakes. But in the 2000+ Legacy(with rear discs) you have kinda a less than ideal situation.
When youre upgrading you want to, at a minimum, maintain the stock f to r bias. Ideally, you want to move the bias a bit rearward to take up some of that built-in excess front bias. So, IMO, if you can upgrade front and rear rotors, as I said above, with the rear upgrade being slightly larger, youre ok. If you have a WRX with the 294 fronts already, you should be able to upgrade the rears to the 290mm rotors also with good results.
IMO the above rotor upgrade will not help to reduce your braking distances. I do agree with upgrading pads, fluids and lines tho. Tho these parts can be had from other sources.
ss
edit: On a side note you should be able to make this upgrade if you can adjust f to r line pressure with a different or adjustable proportioning valve. I believe Legacy777 has done a great deal of work on this problem. You might do a search under his name and proportioning valve.
Old 02-02-2003, 11:49 AM   #14
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default I should also note
you can adjust f to r bias by using different coefficient of friction pads as well. I personally like to get as close as possible to the correct bias in the system itself and assume identical pads. But this is a viable practice.
ss
Old 02-02-2003, 11:55 AM   #15
balyndraks
Member#: 28678
Mystic Blue Pearl
so i could get the bigger rotors and use a less aggressive pad in the front/more aggressive pads in the rear? the thing is i have 17" wheels (prodrive P7) and the rotors are looking awfully small. not that cosmetics is my main concern, mind you. thanks for the input.
jay
Old 02-02-2003, 03:42 PM   #16
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
jay
To answer your question quickly, I think it would be possible, but you would need to do some research on pad coefficients.
I reference to the cosmetics, I admit to there being a cosmetic component to my choices as well. Fortunately usually a bigger rotor looks better and performs better as well.
ss
Newbie needs advice tayres North West Impreza Club Forum -- NWIC 3 02-03-2009 04:04 AM
newbie needs advice for project SubieNewbie18 Subaru Conversions 2 02-24-2005 04:10 PM
Newbie Need Advice On Screen Monitor Ronaldo Car Audio, Video & Security 0 09-22-2004 02:17 AM
Found legacy turbo, need advice!! nd4spd Legacy Forum 2 09-16-2000 01:22 PM
Found Legacy Turbo!!, need advice on whether to buy!? nd4spd Legacy Forum 6 07-31-2000 04:43 PM
