Old 01-31-2003, 10:21 AM   #1
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default Installing three Greddy Gauges..
Hey guys,
I did a search but didn't come accross more of what I'm trying to do, if it's even possible.
I will be installing Greddy 52mm Boost, EGT and Oil Pressure Gauges.
My questions is this:
--- Since I will be installing three gauges, can I use one source for
12v, illumination, ground, and 12V Ignition for all three gauges?
Like run three wires from each source to the intended gauges?
I dont' know if I need to install a fuse breaker or whatnot, but I would like an experts opinion.
Makes a cleaner install and one location if this is possible.
Thank you,
kevin
latinskllz is offline   Reply With Quote
Old 01-31-2003, 05:43 PM   #2
tdxflex
Member#: 13634
i used the same sources for all of them behind the radio. i soldered my connections, i don't trust those vampire clips, my blitz sbc-id would turn on and off if i hit a big enough bump on the road
tdxflex is offline   Reply With Quote
Old 02-01-2003, 11:04 AM   #3
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default did you encounter
any signal noise because of that....
I dont think the gauges draw much current but I was just wondering....
would 60/40 rosin core solder work?
observations: autometer 2 gauge bezel install w/greddy egt and boost gauges ctemple Electrical & Lighting 2 09-21-2004 11:29 AM
Defi hood/ Greddy Gauge install? jclick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-21-2001 11:04 AM
Greddy Gauges installed in WRX Pictures skyhigh420 Tri-State Area Forum 7 08-07-2001 07:34 PM
