Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 01-31-2003, 11:24 AM   #1
gbelli
Member#: 2993
95 legacy wagon
red
Question 95 wagon rear washer reservoir location
Ok, stupid question... The dealer didn't give me the owners manual and I tried looking for it. My 91 had it in the cubby, but its not there.
I though it was a seperate line fed from the reservoir up front, but I have fluid up front, just not in the back It has been REAL cold lately, but today was above 30* when I got in the car this morning.
Is there a seperate reservoir like my 91 had? Where is it?
TIA
gbelli is offline   Reply With Quote
Old 01-31-2003, 11:39 AM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
there is only 1 washer bottle in a 95.
same thing happened with my mom when getting a newer wagon
subarurabbit is offline   Reply With Quote
Old 01-31-2003, 11:42 AM   #3
gbelli
Member#: 2993
95 legacy wagon
red
Bah, thats what I was affraid of. Heres hoping some time above freezing will help!
Old 01-31-2003, 03:18 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
yes, something could be frozen...
but...
dont you have a rear/separate motor to run that wiper?
is it running when you turn on the spray?
Jamie
www.subiegalracing.com
Old 01-31-2003, 03:22 PM   #5
gbelli
Member#: 2993
95 legacy wagon
red
but...
Jamie
I can hear it running, just no juice
Old 01-31-2003, 03:23 PM   #6
subarurabbit
Member#: 4083
2011 OB 3.6R
the hole sounds plugged.
push a push pin into the hole
Roger
Old 01-31-2003, 03:38 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
hole plugged, air in the line.... etc...
that's gotta be your issue there...
push that sucker down and hold the spray on for 2-3 MINUTES
see if that helps...
no i'm not joking.
trust me on this
Jamie
Old 01-31-2003, 06:55 PM   #8
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Also,
If you are low on wwf, the rear will not work. Only the front....
Fill it up..
Well, on my 00
aross is offline   Reply With Quote
Old 01-31-2003, 07:01 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Also some weird creatures will feed off washer fluid so it may be gunked up.
I had some crazy looking stuff growing in mine once
Old 01-31-2003, 07:24 PM   #10
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
The pump for the rear is well above the pump for the fronts, so it stops spraying well before the front does. Try topping off the reservoir. If that doesn't work, the lines probably plugged, somewhere.
gavin is offline   Reply With Quote
Old 01-31-2003, 07:26 PM   #11
Mr Cheese
Member#: 1846
the problem is your front still works and your back doesnt is because the pump for the rear is mounted higher than the pump for the front. therfore at certain levels the fluid is below the rear pump yet still above the front pump.
Mr Cheese is offline   Reply With Quote
Old 02-05-2003, 10:30 AM   #12
gbelli
Member#: 2993
95 legacy wagon
red
Ok, for being a 'car guy' and techincally/mechanically inclined I feel real dumb
I didn't know/realize the pickup for the rear was above the front, and a fresh gal of fluid fixed my problem
I'll be back to doing camswaps and other work on my Impala, its easier
08+ wagon....where is the rear windshield reservoir? 09rexwagon Newbies & FAQs 4 09-24-2009 08:02 PM
I'm finally done: stock-location AWIC with rear coolant reservoir scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 5 10-12-2008 09:24 AM
STi I/C switch with wagon rear washer plug? for sedan? Killian Maynard Electrical & Lighting 6 04-04-2005 03:20 PM
Windshield Washer Reservoir cap for '02 WRX gryphon Private 'Wanted' Classifieds 0 11-05-2003 01:46 PM
