Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-31-2003, 12:39 PM   #1
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Default Turning off the AC
Has anyone worked out how to disable the AC when you have the air select knob pointing to de-mist/feet or de-mist only? I have noticed that the AC is enabled in these two positions even if the AC switch is not pressed.
2003 - WRX Wagon
Cheers
Mick
mick_the_ginge is offline   Reply With Quote
Old 01-31-2003, 01:43 PM   #2
wingtipz
Member#: 26697
1999 2.0T-RS
Yes, this is a relatively easy mod as long as you are comfortable taking apart the area housing the stereo and the HVAC controls.
-Remove the trim ring around the stereo and HVAC controls
-Remove the stereo (4 screws)
-Remove screws holding HVAC controls in
With the HVAC controls free, tilt the unit so you can see the underside. On the right side on the bottom of the unit, behind the selector controlling the position of the air there is two small purple wires and a switch mechanism. cut one of these wires and you are good to go. Alternately I have heard of people taking the switch mechanism apart that gets tripped when you turn the selector to the defrost positions. With the mechanism apart you turn it around and reassemble it so that even though the mechanism is working it doesn't trip the switch.
Either method will work, one is just much easier to do. I chose to cut a wire. It's easy enought to splice it back together if I ever feel I need to.
Gabe.
wingtipz is offline   Reply With Quote
Old 01-31-2003, 01:44 PM   #3
wingtipz
Member#: 26697
1999 2.0T-RS
Are you in Portland Oregon or Maine?
Old 01-31-2003, 04:31 PM   #4
Rally1
Member#: 20633
yep there are a number of threads on it. I am planning on doing it too, it drives me nuts the way it is now.
One thread had pics.
Rally1 is offline   Reply With Quote
Old 01-31-2003, 05:35 PM   #5
sonicblue
Member#: 25227
2012 Escape
sonicblue is offline   Reply With Quote
Old 02-01-2003, 04:17 AM   #6
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
And the way to do it was first posted in this thread:
http://forums.nasioc.com/forums/show...hreadid=148118
Alan is offline   Reply With Quote
Old 02-01-2003, 08:51 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The thread to which this forum owes its life
Old 02-01-2003, 03:22 PM   #8
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
As well as several PM and mails to Nick begging him to set it up!
Old 02-03-2003, 01:04 PM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Thanks to all who replied. I'll be doing this mod as soon as I get a free moment.
Mick
Portland Oregon
Old 02-03-2003, 04:42 PM   #10
wingtipz
Member#: 26697
1999 2.0T-RS
Interesting to me the number of people in the Portland Metro area interested in doing this mod. Must be something to do with the constant dampness we have, even when it's sunny.
Yeh Portland!
Old 02-03-2003, 04:50 PM   #11
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
Wait wait wait... I have an 02 RS, bought March 02. My AC doesn't turn on when I put HVAC to defrost. Was this for all 02's?? not like it really matters just curious.
Merdock777 is offline   Reply With Quote
Old 02-03-2003, 05:08 PM   #12
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Yes it does turn on the AC, just not the light. For proof you can turn the heat to cool, and then switch to defrost, you'll feel the AC come on. Or open the hood and you'll hear the fans and the compressor cut in.
Old 02-03-2003, 05:11 PM   #13
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Yeh Portland!
Maybe it has to do with the fact that in Portland we are just cool enough to need defrosters, and unlike the really cold places we don't need them often. And that we have enough moisture that using them wrong causes the windows to fog really quickly.
Old 02-03-2003, 08:47 PM   #14
wingtipz
Member#: 26697
1999 2.0T-RS
Any of you from portland metro read the NW region forum? The weekend after valentines there will be a meet/drive and some of us from up here should show up, meet some people from the Eugene, Corvallis, central valley areas. Do some drivin' too.
Old 02-08-2003, 09:20 PM   #15
Bimmer
Member#: 4116
2002 Impreza TS
I did this. It's been a while, but I don't remember moving any of the HVAC stuff... once the radio's out, you're looking at the guts of the HVAC system, and it's easy to see the mechanism that triggers the AC and the infamous purple wires.
The only hard part is working up the courage to REALLY yank on the trim ring to get it out of the dash. If you look in the FSM, it shows where the clips are, and it comes out a lot easier if you're yanking (with spring hooks or whatever) where the clips are.
Good luck,
Ben
Bimmer is offline   Reply With Quote
grinding noise when i turned on the ac jchin829 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-22-2008 02:06 AM
They decide to turn off the A/C, and turn on the heat 24 Off-Topic 8 11-06-2006 02:00 PM
When I turn on the AC I hear "whirring", belt noise perhaps? Padge Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-04-2006 05:16 PM
Someone turn on the AC (and sighting in PA) veloLexus Bay Area Impreza Club Forum -- BAIC 0 09-02-2002 03:54 AM
Will I encounter problems if I take off the AC belt from the underpulley? Snoopy General Forum Archive 15 02-27-2001 03:55 PM
