Old 01-31-2003, 03:35 PM   #1
freeze
Member#: 26061
2007 Forester XT
UGM
Default daytime running lights
Is there a way to not have my lights on during the day when I release the parking brake? Is there a wire to cut or something? Thanks
freeze is offline   Reply With Quote
Old 01-31-2003, 04:27 PM   #2
sonicblue
Member#: 25227
2012 Escape
You should really try this:
before the "n00b" cries hit the fan.....
Anyways.......there's a harness behind the glove box that you unplug. Blue, I think. Maybe white. Try both.
sonicblue is offline   Reply With Quote
Old 01-31-2003, 04:28 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Do a search for daytime running lights or DRL. There's a control module under/behind the glove box, and a resistor pack on the passenger side of the engine compartment. You can also raise the emergency brake handle just one click.
Old 01-31-2003, 04:30 PM   #4
sonicblue
Member#: 25227
2012 Escape
Go behind the glove box - it's super-easy. Can do the one in the engine but it's pretty hard to get to and you have to worry about the plug corroding. Please tell me you wouldn't even consider the e-brake thing - that's ghetto fix.
Old 02-01-2003, 05:01 AM   #5
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
I added a switch in one of the blanks on the console so I could choose. I usually leave them on - given the weather in the "sunny" NW, but if I want to be inconspicuous at night I like the option of offing them.
If you pull the top center panel off the console you can find the wire leading to the switch on the parking brake. (May be easier if you pull the upper panel too.) I added a 3-terminal switch ; one terminal is common, the other 2 are switched. (It's supposed to be a lighted switch, but using the 3rd terminal for this operation negated that.) Bought the switch at NAPA; small, and fits into a hole I cut in the center of the existing console plug.
Cut the wire leading to the parking brake switch. But plan first! you want both cut ends to be able to reach the switch, or you'll have to splice on an extension if one doesn't reach. Add terminals to the cut ends that are the right size for the switch you're using.
Attach the cut end coming from the dash to the common terminal. Attach the cut end from the parking brake to one of the other terminals. Now add a ground wire; there're a couple of bolts available to use as the grounding point. Attach the ground wire to the last terminal on the switch.
Voila! Now you have a choice. You may have to swap wires on the last 2 terminals around to get the on/off switch positions to match the lights.
GravelRash is offline   Reply With Quote
Old 02-01-2003, 07:50 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Using the e-brake switch to control the DRLs is a bad idea. When the switch is closed it will also turn on the 'Brake" warning light on the dash. Driving around with this light on constantly is not only annoying, but somewhat unsafe since the warning light will no longer be able to do its job and alert you to problems with the brake system such as a loss of brake fluid.
If you want to install a switch for the DRLs that's fine, but use a wire that will interrupt DRL function only with no effect on anything else, such as one of the connections to the DRL control module by the glovebox. You could also add a relay in series with the load resistor in the engine compartment.
Or, you could still use the wire from the parking brake, but install a diode in series with this wire in the harness to the DRL module, and connect your switch between the diode and the module. That way you could control the DRLs the way you want without affecting the brake warning light system.
daytime running light uninstall with jdm lights? bren wrx Electrical & Lighting 1 09-20-2005 09:08 AM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
('93-'01) How to remove daytime running lights on 2002 Imprezas Dr. Spud Funk Impreza Forum 9 05-08-2001 05:43 PM
Disabling Daytime Running Lights on a 2000 Legacy GT? rao Legacy Forum 16 05-04-2001 12:35 AM
daytime running light 2kGT Bay Area Impreza Club Forum -- BAIC 1 06-05-2000 05:13 PM
