Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 01-31-2003, 05:55 PM   #1
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Unhappy which wire?
I've tried searching, but this question is so general I wasn't even sure what to look for
I'm trying to find a line that has 12v running through it, under the dash, but only hot when the ignition is turned on. AND, its got to be something that can handle some amperage, as I'll be wiring my wideband to it.
I was told the yellow with red stripe (runs the length of the drivers side dash, but that seems to be constant power. Any other suggestions?
DarthChicken is offline   Reply With Quote
Old 01-31-2003, 10:08 PM   #2
Member#: 8023
2004 2.5 RS
There are several places to tap into ignition power. They are red wires. One is to the clock another to the head unit and i believe there is one to the dome light.
brunetmj is offline   Reply With Quote
Old 02-01-2003, 03:08 AM   #3
Member#: 3601
2006 WRX Wagon
Why not the power to the accessory socket (cigarette lighter) which is hot whenever the key is in accessory or on? It's a yellow with red stripe I believe. It'll handle 10+ amps.
Alan is offline   Reply With Quote
Old 02-08-2003, 08:25 PM   #4
Member#: 4116
2002 Impreza TS
I just tapped into the power windows line to install an oil temp gauge... it's the fat green/black line in the driver's side door cord, easy to find, and you don't have to take anything apart to get at it.
Bimmer is offline   Reply With Quote
Which wire to the ECU id the MAP wire? renhoek Pre-2002 Factory Turbo Powertrain 2 12-08-2008 01:10 AM
which wire is which question STINOMORMONEY Newbies & FAQs 5 07-06-2008 09:38 PM
Which wire is which? FatCatTurbo Electrical & Lighting 2 06-23-2004 11:22 AM
Which wires are which on the MAF jsavage Normally Aspirated Powertrain 1 12-26-2003 11:44 PM
Which wire is my airflow wire? Chocobo Engine Management & Tuning 6 11-07-2002 08:50 PM
