Old 02-01-2003, 11:19 AM   #1
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Default Question about S-AFC installation..
Hi. I was just curious about one part of the S-AFC installation. The two grounding wires, the brown is closer to the ECU and the black is further. The manual says 1 CM apart, does it have to be 1 CM or can it be slightly more than that? I'm just wondering if its "At least 1 CM" or "exactly 1 CM". Thanks.
DeusExMachina is offline   Reply With Quote
Old 02-01-2003, 01:01 PM   #2
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
76 MG Midget Special
on my AVC-R i just put them poth at the same point and haven't had any problems.
wrxtuner02 is offline   Reply With Quote
Old 02-01-2003, 06:40 PM   #3
NotoriousWRX
Member#: 9026
They need to be grounded at separate points as per the instructions. Just ground anywhere from 1 to 3 cm apart.
NotoriousWRX is offline   Reply With Quote
Old 02-01-2003, 06:45 PM   #4
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Thanks, I did that and the rest of the install. However..
When I put the car into accessories mode, the SAFC lights up the buttons (ie has power) but displays nothing on the screen. When I try to turn the car on, the car starts to idle speed, dies, starts to idle speed, dies, throws a CEL, and I assume would repeat the same idle-->die process over and over until I stopped it, which I did after 2-3 cycles. And I still had no display on the AFC. Luckily I had put in a DB9 plug for the purpose of making a dummy plug incase I wanted to remove the AFC, so luckily my car is still functional with the MAP wires reconnected.
Anyone have any idea why its doing this? Probably one wire is not correct..I need the wiring diagram for a 2002 RS incase they changed something from the MY 2001s.
Question about TXS ABC install Electronsmurf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-05-2003 06:34 PM
Question about grounding Mod install... Matty Electrical & Lighting 2 01-01-2003 05:51 PM
Got question about Hella Supertone installation in a GC8 edkwon Mid West Subaru Owners Club Forum -- MWSOC 17 09-10-2002 01:11 AM
Newbie Question about S-AFC computer Mike C Normally Aspirated Powertrain 2 02-22-2001 08:24 AM
Question about impending suspension install... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 14 01-10-2001 09:33 AM
