Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-01-2003, 04:15 PM   #1
ElDuderino
Member#: 5980
Wingless Wonder
Default Problems with Morettes
I just bought these used (w/ PNP wiring) and put them on my car, but they're not working correctly. When I turn on the low beams, the outside lights turn on (I don't know whether those are the low beams or not). When I turn on the high beams, the indicator comes on but nothing happens. Weird thing is, the indicator stays on when I turn the car off, and when I turn it back on, I can't get the lights to work at all. The only way to turn the indicator off is to pull the negative off the battery. Also, I've yet to see the inside lights turn on at all aside from that little bulb in the corner of the light.
About the wiring - I connected the headlight adapters together. Then I connected the right headlight to the left via the longest wire, attaching the 4 plugs the only way they fit. Then I led the brown connector to the positive and the black to the negative.
I'm at a loss. A search thru NASIOC shows that my connections are correct, yet the lights are acting up. Any advice?
ElDuderino is offline   Reply With Quote
Old 02-01-2003, 05:06 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Oops-
The black wire, the one with the inline fuse, should be connected to the positive battery terminal. The brown wire is connected to the negative. Switch them around, and as long as everything else is correct your lights should work. Also check to be sure that the fuse isn't blown.
The outside lights are indeed the low beams, and the inside are the highs. The small bulb in the high beam housing is a "city light" that comes on with the parking lights.
Old 02-01-2003, 05:15 PM   #3
ElDuderino
Member#: 5980
Wingless Wonder
OK, fixed.
You'd figure they'd color code the damn things.
Old 02-01-2003, 05:19 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Remember, these are made by the French
Old 02-01-2003, 05:38 PM   #5
ElDuderino
Member#: 5980
Wingless Wonder
LOL, figures.
Old 02-01-2003, 11:54 PM   #6
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
They do color code them....
.... just not in a normal fashion
CirrusWRX is offline   Reply With Quote
Old 02-02-2003, 12:30 PM   #7
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Originally posted by mulder
Oops-
So for DRL the outsides should be lit? LOL, if so I think I have had mine backwards for a while.
DoctorNick is offline   Reply With Quote
Old 02-02-2003, 05:02 PM   #8
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
I thought I remember, (might've been even Mulder who mentioned it) that the DRLs and morettes in general don't always work well together, hence people recommending to disable them. Anyway, the outside ones should be lit as those would technically be the low beams, but again, it's low-wattage, and I'm not sure those standard bulbs are designed to take the low-wattage - I know for a fact that the HIDs should CERTAINLY never experience the low-wattage of DRLs.
Old 02-04-2003, 12:36 AM   #9
cwb124
Member#: 15571
2006 06 Forester XT
I have a problem with my Morettes. I installed them last summer and had no problems with them until recently. Just like the original poster, I have low beams, and when I switch them to high beams, nothing changes except my fog lights get turned off, which is normal operation. What should I look for since they used to work? It's dark right now and didn't get around to checking plugs, but it looks like I'm going to remove them soon and take a look. Any ideas?
CB
cwb124 is offline   Reply With Quote
Old 02-04-2003, 12:43 AM   #10
supermarkus
Member#: 6971
2008 WRX STi
SSM
MY DRLs work just fine, had mine for over a year now. Yeah, the wire colors are messed. Mulder's right as rain.
supermarkus is offline   Reply With Quote
Old 02-04-2003, 12:49 AM   #11
ElDuderino
Member#: 5980
Wingless Wonder
This is how my lights function:
DRL - Outer housing lit dimly
Low beam - Outer housing lit brightly, fogs optional
High beam - Outer housing lit brightly, inner housing lit, fogs off
Right?
Old 02-04-2003, 01:41 AM   #12
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Right?
Oh man, this sucks. Because if your right this is how mine is.
DRL: inner
Low beam: innner lit brightly
High
Old 02-04-2003, 07:40 AM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Dr Nick-
Check the wiring to your lights, the low and high beam connections to the factory harnesses are probably reversed. If you have plug-in harnesses that came with the lights they may have been made incorrectly, this is somewhat common and I have seen it happen before.
cwb- first thing to check is the fuse by the battery that goes to the Morettes, this is the power for the high beams. If it is blown that is your problem. Not sure why it would blow since it's a 15A fuse, unless you are using high-wattage bulbs.
Weird problem with morettes and HID help Porkchop-WRX Electrical & Lighting 7 03-13-2007 05:57 PM
Lowbeam problems with morettes neurotic Electrical & Lighting 2 03-26-2004 12:04 AM
problem w/ morette installtion chobits Interior & Exterior Modification 9 02-08-2003 01:03 AM
Got a problem with my morettes rochyrex Interior & Exterior Modification 2 08-23-2002 11:23 PM
White 2002 WRX with Morettes WRX02 Interior & Exterior Modification 2 08-12-2001 06:08 PM
