Old 02-01-2003, 10:46 PM   #1
Black-X
Member#: 31702
2013 WRX
Default HELP! I think somethings F' up now!!!
i installed my gauges today, and had one last wire to connect. it is the purple wire for the autometer A/F gauge. i forgot to disconnect the battery before i did this, so i hook it up, and now the alarm light keeps flashing in groups of 2. i have no idea what to do! i am pretty worried about this now.
also, when i was hooking the power wires into the fuse box earlier today, i put the wires into the correct spots. i did have the battery disconnected then though. but when i put the battery cable back on, the CD player and my radar detector came on! and the key was in my pocket!!!
did i F' something up? am i trying to run too many gauges off the fuse box? i have an autometer monster tach, greddy boost gauge, and the autometer A/F hooked up to the fuse box. i used the clock wiring to hook up the volt meter. these are all grounded to the hood release lever.
please help!!! i have the battery disconnected now hopefully to reset the ECU. what else do i DO?!?!?!?
Black-X is offline   Reply With Quote
Old 02-01-2003, 10:49 PM   #2
Black-X
Member#: 31702
2013 WRX
BTW, i have an 03 WRX 5-speed w/factory security system.
Old 02-01-2003, 11:01 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Resetting the ECU has nothing to do with this, it is a wiring problem.
You may have accidentally cross-connected a switched power circuit with a full-time one. Go back and check all your wiring carefully. If you don't have the factory wiring manual for the car you should get one, it's a must before doing any electrical or wiring work.
As for the security light flashing, that should be no big deal. It sounds like you somehow managed to put the system into valet mode. In the small manual that came with the car for the security system there are instructions for engaging/disengaging valet mode.
I think I messed up bad Mecanic07 Brakes, Steering & Suspension 4 03-26-2007 02:25 AM
Ok I think I messed up somewhere Rockgod Legacy Forum 24 01-31-2007 12:50 AM
i think i messed up w/ this girl RR Off-Topic 74 05-03-2005 07:10 PM
Ran over a parking "block", something's messed up mr_disco Newbies & FAQs 8 01-14-2004 03:38 AM
s-afc 'blue wire mod' on 98 OBS...i think i messed up...help! IMPREZAmike Normally Aspirated Powertrain 3 07-23-2001 06:13 PM
