#1 |
Member#: 12851
South East
Discussing it with a friend of mine. Basically I'm wanting to find out if the cylinders fire one at a time or two at a time?
#2 |
Member#: 22218
South East
It would be easy to assume that cylinders would fire in a diagonal pattern to cancel vibration, but he could be wrong.
Full_Clip is a single stroke guy. |
#3 |
Member#: 5893
E. Canada
Vehicle:1997 Black GC4 1995 White BK6 |
Firing order: 1-3-2-4
#4 |
you can't fire 2 cylinders at a time. that's why they have a firing order.
jeremy |
#5 | |
Member#: 5893
E. Canada
#6 | |
Member#: 12851
South East
#7 |
Member#: 19851
Vehicle:02 WRX Aspen White/12.75@105.67 |
The motor would shake the car apart. Ever ride a Harley?
#8 |
Member#: 13025
RMIC
Vehicle:1998 RS-T Rally Blue |
USJDM, According to my understanding of the 4 stroke cycle. Internal Combustion Engines never fire during the exhaust stroke. They just push spent gas out in preparation for the intake stroke so they can close the valves and compress the new mixture and THEN fire, starting the power stroke. Which brings us back to the Exhaust stroke, ad infinitum. Or till you turn the key off. The pistons probably move in opposition diagonally to cancel vibration but while two pistons are extended at the same time one would be at the end of Compression while the other would be at the end of the Exhaust stroke.
Disclaimer: I could be wrong!!! Just thinking. |
#9 |
Member#: 437
NESIC
Vehicle:'91 Miata MX5 (Red) '09 Impreza OBS (Blk/Gry) |
I've actually heard of what US2jdm is talking about, but I don't know first hand, and am still new to the "boxer" engines.
These Subaru engines sure are stange. When I found out you could drive around with blown head gaskets as long as you didn't run the car hard, I new something was up. ![]() Paul G. |
#10 |
Member#: 491
NESIC
Vehicle:1995 Legacy race car Pan Am Blue |
US2JDM is correct: On the 2.5RS Subaru used only two ignition coils and alternates firing them. One coil serves the front two cylinders and the other fires the rear two. With this pattern a useless spark gets fired on the exhaust cycle of the opposite cylinder. This ignition strategy is used by many manufacturers and is commonly known as a "waste spark" system.
A "waste spark" ignition system has no benefit other than lower cost and simplicity. The layout allows Subaru to use 2 coils instead of 4 (cheaper) and a two-channel control circuit (simpler) from the ECU. This of course only applies to Subarus with the coil pack mounted on the intake. The newest Subaru engines (like the WRX) have four individual coils, one mounted on each spark plug and controlled individually by the ECU. Last edited by Jude DeMeis; 02-02-2003 at 08:43 PM. |
#11 |
Member#: 12851
South East
So the EJ's don't have 2 chambers explode instead they have a waste spark.
Has there been an engine before that has 2 chambers fire at once? It would seem to be an advantage... |
#12 |
Member#: 491
NESIC
Four cylinder four stroke engines never have two cylinders firing at once. The engine runs the same with a waste-spark, the only difference is that some electricity is wasted by firing an extra spark plug with no benefit.
#13 |
Member#: 437
NESIC
Thanks Jude. I didn't realize my WRX was different than my pervious car (2.5RS).
Paul G. |
#14 | |
Member#: 12851
South East
#15 |
Member#: 19851
Honda used that dual-firing theory on it's "Big Bang" series of engines. I believe they were used in motorcycle racing. I bet Google would have something to say about it.
#16 |
Member#: 23894
Vehicle:'02 2.5 WRX WR Blue |
What is the location of cyl 1 and 3?
#17 | |
Member#: 5893
E. Canada
As Jude pointed out, I was talking about the 'waste spark' system. Other cars use this, I believe the Mazda wankels did this (keeps things cheap and easy). I believe some radial airplane engines do fire multiple cylinders simultaneously. As for the cylinder numbering: 3 - 4 1 - 2 ____ (as seen from above w/ the line being the front of the car) Word.™ -Milan P.S. don't blow up your motors experimenting ![]() |
#18 |
theres a difference between a wasted spark on and exhaust stroke and firing 2 cylinders at the same time.
#19 |
Member#: 19851
Those motors may fire 2 SPARK PLUGS at the same time, but they're not firing 2 cylinders containing ready-to-combust a/f mixture at the same time...
#20 |
Member#: 22127
South East
Vehicle:2002 WRB WRX 12.5:1 @ 24psi w/ W.I. |
I believe that in the manual for the wrx, the firing order is simply 1-2-3-4. May sound strange, but the boxer arrangement makes this possible. Check your manual, its in there i promise
#21 | |||
Member#: 5893
E. Canada
#22 | |
Member#: 23717
NESIC
Vehicle:2005 Big red |
#23 | |
Member#: 19851
#24 | |
jeremy |
#25 | |
Member#: 491
NESIC
Lotus and Ferrari do this on some of their 8 cylinder street cars as well. It's called a "flat plane crankshaft" and unlike a normal V8 is more like having two four cylinder cranks in a row. The "flat" design can take advantage of the exhaust pulse to extract more air from the engine. Flat plane motors make better power but are rougher than a traditional V8 with "cross plane" crank. They also don't sound the same as a normal V8- the exhaust note is more like an inline four cylinder. Last edited by Jude DeMeis; 02-04-2003 at 10:10 AM. |
