Old 02-02-2003, 07:49 AM   #1
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default will lower wheel offset push wheels out giving wider stance?
I was wondering if I got a wheel offset smaller then the recommended 48+ if it woudl actually set the whees farther apart safely making the tire track wider? I do understand that the fenders would have to be modified. are there are others ways to widen track width other then wheel spacers? thanks
John
Cusco is offline   Reply With Quote
Old 02-02-2003, 09:48 AM   #2
MNbiker
Member#: 18148
'08 WRX
Dark Gray
John,
A lower offset will, indeed move the tires further out. As you mention, wheel spacers do the same thing. There are some practical limits how far you can go with this: 1) fender clearance. 2) increased wear & tear on the drivetrain. Not sure there's an absolute limit on 2, but as you push the wheels out, your wheel bearings will suffer.
FYI - If you want to run really wide wheels/tires, you need to run a lower offset, just to gain clearance on the inside of the wheels.
Here's a good description of offset.
http://www.tirerack.com/wheels/tech/offset.htm
-Steve
MNbiker is offline   Reply With Quote
Old 02-02-2003, 09:55 AM   #3
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
also the problem is that when if you push the offset out to far and don't have wider wheels to keep the centers in roughly the same place as stock, you don't get as much car yaw per angle of steering wheel turn.
So really, it's best to keep the center of the wheel in roughly the same location if possible
ellisnc is offline   Reply With Quote
Old 02-02-2003, 10:54 AM   #4
wlelandj
Member#: 15127
I echo what's been said. Here's a link that's fun to play with and that I've found usefull.
-Leland
wlelandj is offline   Reply With Quote
Old 02-02-2003, 04:39 PM   #5
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
In other words, cars with the wrong offset steer funny, requiring more "tending" than a car with the proper offset.
Kevin
gtguy is offline   Reply With Quote
Old 02-02-2003, 05:17 PM   #6
BillJC
Member#: 31002
You basically want to keep the king pin axis centeded in then contact patch of the tire or slightly ahead of it for better tracking.
BillJC is offline   Reply With Quote
Old 02-02-2003, 06:57 PM   #7
ellisnc
Member#: 4229
2003 S2000
or at least where it was designed to be
Old 02-02-2003, 08:29 PM   #8
BillJC
Member#: 31002
exactly.
Old 02-03-2003, 02:20 AM   #9
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default thanks
I was just thikning getting a 7.5" tire with a very small offset maybe +40 or so, so I can fit a wider wheel in the fronts and not neccessarily the back so I have better (supposedly) traction for sterring. thanks for all the help and the links.
John
What Offset and Wheel Size gives me more room? Kaymin Tire & Wheel 0 05-26-2006 10:54 PM
Will UD pullies offset the affect of heavier wheels? fueledbymetal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-01-2002 09:43 PM
lowering and wheel offset?? ANW Brakes, Steering & Suspension 1 10-01-2001 06:37 PM
What Wheel Offset is right for a lowered Legacy? MY99 2.5GT Legacy Forum 15 04-14-2001 12:17 AM
will a +45 offset work on an 18X7.5 wheel? scootr Brakes, Steering & Suspension 13 03-17-2001 07:37 AM
