Old 02-02-2003, 11:15 AM   #1
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Talking Mirror Swapping (heated/non)
okay guys... many of u know...
i have the heated mirrors on my rally wrx wagon project car.
one of the mirrors was severly damaged in a fire...
and a new heated mirror cost 3x what the USA non heated mirror cost... so... i got the USA spec mirror... and pal Mike and I swapped it onto the car...
the harnesses are very different:
basically what we did was remove all of the wiring from the harness connector attached to the canadian mirror -
stripped the USA spec harness adapter off of the wires
then fit the canadian harness end to the USA mirror, and plugged it in... worked perfectly!!
in order to reverse this process...you would swap the connectors as shown and then additionally you'd want to tap into the defrost as that's what controls the "heated" bit of the mirror, run a ground wire - and you're done.
all the pix (more of them) are on www.subiegalracing.com
follow link from the photo update table to "wagon progresses" link....
hope this helps.
Jamie
www.subiegalracing.com||#215 SCCA Pro/Club Rally
Two questions relating to heated mirrors and heated seats Civ2Sub311 Newbies & FAQs 7 10-01-2009 04:05 PM
09 STi Side Mirrors - Want Heated Mirrors esiuda Interior & Exterior Modification 6 08-08-2009 01:20 AM
How to: swap heated pads to non heated seats? 11rex06 Interior & Exterior Modification 7 05-18-2009 12:02 PM
Heated Side Mirror Swap project_skyline Interior & Exterior Modification 1 12-04-2007 12:11 PM
heated side mirror swap Sgt Stenner Baja Forum 16 03-12-2007 11:13 PM
