Old 02-02-2003, 07:20 PM   #1
Dealer Xing
Member#: 4673
Exclamation My Aftermarket HID ballast failed. HELP
I have had my FOCUZ HID H4 kit installed in my car for a few months. Today one of the lights wouldn't come on, so I swapped the bulbs and the relays from one side to the other, no go. The only possibility left is the Phillips ballast, which I haven't swapped because they are taped under the engine bay. Is there any way I can tell if the Ballast is no good? When I turn on the light there's a clicking noise that lasts for a second at the supposedly bad ballast.
Dealer Xing is offline   Reply With Quote
Old 02-02-2003, 07:49 PM   #2
WRX11
Member#: 26638
When you said "taped" under the engine bay. Does the housing make good ground contact, to the frame? Does your unit have in line fuse, if so, did you check that?
WRX11 is offline   Reply With Quote
Old 02-02-2003, 07:54 PM   #3
Dealer Xing
Member#: 4673
No fuse, the ballast is taped onto the metal. It has worked for a few months that way.
Old 02-02-2003, 08:39 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
OT isn't really the place to post this, it'll probably get moved eventually.
You'll have to swap the ballasts to confirm that is the problem and eliminate anything else such as wiring, although it sounds like the ballast is most likely NG.
If you bought the HIDs new from a vendor try contacting them. Perhaps they would be willing to send you a new ballast so you can replace the bad one and send it back.
Old 02-03-2003, 08:46 AM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default Re: My Aftermarket HID ballast failed. HELP
I can tell you one thing that might have caused it to die - daytime running light circuit. If you have daytime running lights on your car, what happens is the module sends a lower voltage to the headlight assembly and the HID ballast would try to ramp that voltage up to the HID's operating voltage. It would burn it out in a rather untimely manner.
If you don't have DRL's on your car, nevermind.
nhluhr is offline   Reply With Quote
Old 02-03-2003, 03:26 PM   #6
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Do you start your car with the lights on at times? I know that'll kill the ballast and bulbs real quick.
TaiChih is offline   Reply With Quote
Old 02-03-2003, 05:53 PM   #7
Dealer Xing
Member#: 4673
No, the HID kit had never been abused or put away wet.
How much would a replacement ballast cost?
Old 02-03-2003, 10:27 PM   #8
TaiChih
Member#: 3467
1998 Dinan3
Bleck
About the same price as a new kit nowadays. You could sell of the bulbs and single ballast to people who need them. I'll buy the bulbs for $50, provided they still work.
FS: HID Projectors, ballasts, bulbs (OEM stuff, not aftermarket HID kit) xdarkn3ss SCIC Private Classifieds 5 08-16-2009 03:35 PM
1 aftermarket hid ballast,& 1 [05 oem sti] ballast [best offer takes them] jeremywrx15554 Exterior/Styling 13 02-26-2009 10:27 PM
For Sale: 1 JDM STI HID Ballast and two HID bulbs dubluv17 Private 'For Sale' Classifieds 10 08-28-2005 05:37 PM
04 HID Ballast for V7 JDM HIDS dubluv17 Electrical & Lighting 9 08-12-2005 10:25 PM
I fried my HID ballast twice scoobygator Interior & Exterior Modification 13 11-01-2002 01:14 AM
