Old 04-21-2001, 06:15 PM   #1
Jessie James
Member#: 2072
Angry RE730's and Tein Medium springs Rub rub rub!
I just got RE730's in 205/55/16 (stock size) and they rub against the under fender plastic bits.
I removed the front ones, and now there is no problem, but the back ones rub too, so I am going to remove them.
Just thought I would let you all know in case you do the same someday.
Jessie James is offline   Reply With Quote
Old 04-22-2001, 07:48 AM   #2
Jessie James
Member#: 2072
Post
Update - removed the rubber fender lining from the rear and they STILL rub!
So I tried to roll the fenders, which resulted in much paint chipping and falling off from the under-side of the lip, but I still have rubbing.
Anyone have a good technique for rolling fenders? I jammed a lead pipe in there (which is about how much clearance I have between the wheel and fender since it's lowered) which worked so-so.
Old 04-22-2001, 10:27 AM   #3
Aspen
Member#: 145
Banned to
Housework for Summer
Post
Do you have the stock rims? If not, what offset are your wheels?
Aspen is offline   Reply With Quote
Old 04-22-2001, 02:49 PM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I have posted the same thing many times, that the stock wheels with RE730's in 205/55x16 rubbed very slightly - but not enough to either wear out the rubber strip lining the fender or the tire, and they were still 1/8" off the strut.
I removed the rubber strip at the race track when the 15" VW wheels I bought off a guy with BFG-R1 race tires rubbed right through the rubber strip, and the rubbing was completely gone with the RE730's ever since.
How is your alignment? Maybe you don't have enough negative camber in the rear?
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 04-22-2001, 08:12 PM   #5
Jessie James
Member#: 2072
Post
I replaced the springs and have not aligned it. I didn't think you could adjust the camber in the rear, am I wrong? (Probably!)
And yes, they are the stock rims.
But I scored pretty darn well at the AutoX today - I actually kept up with the other Impreza's - not the usual 3-5 seconds slower!
Old 04-23-2001, 07:20 AM   #6
Volvokiller
Member#: 51
1999 Impreza RS
Post
Hey RS25.com,
Which struts are you running? Stock or aftermarket?
Thanks
Chris
Volvokiller is offline   Reply With Quote
Old 04-23-2001, 07:57 AM   #7
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Post
Just for reference they do NOT rub on stock suspension.
Note: I am not arguing just wanted to let other readers know.
skidplatez is offline   Reply With Quote
Old 04-23-2001, 08:39 AM   #8
Jessie James
Member#: 2072
Post
Stock struts. Which ain't the greatest with the Tein springs, but it's better than before. And the tires clear the struts just fine, BTW.
I think I am going to have to order a body hammer from JcWhitney and pound those fenders a bit!
Old 04-23-2001, 10:11 AM   #9
CBLOCK
Member#: 365
00 RS Sedan
Post
I'm running H&R/STI suspension with RE730's in 205/55R16. I get rubbing on the inner plastic cover if I hit a dip in the road during a hard turn. It isn't too bad, though. I don't remember rubbing at all with the RE-92's last year.
In the winter, with my Pilot Alpins (also stock size), I rarely got any rubbing.
The RE730's are definitely wider than the RE92's. I thought that was odd being that they are both Bridgestones...but oh, well! The RE730's grip like hell. I don't mind the occasional rubbing, and if I drive more "reserved", I'd probably never have rubbing.
-- Chris
CBLOCK is offline   Reply With Quote
Old 04-23-2001, 11:51 AM   #10
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post
time to roll,
http://www.overboost.com/story.asp?id=131
<IMG SRC="http://www.overboost.com/images/131/full/p1010102.jpg" border=0>
blkwag is offline   Reply With Quote
Old 04-23-2001, 03:13 PM   #11
Jessie James
Member#: 2072
Post
That is too cool... any one in the North Bay do that?
FS: AGX Adjustable struts and Tein S springs coqui2004miguel AKIC Private Classifieds 3 06-16-2009 04:08 AM
wtb: tein medium or tein soft Chizzow Vancouver Impreza Club Forum -- VIC 6 02-01-2005 09:31 PM
Tein medium springs HKscooby Brakes, Steering & Suspension 14 08-06-2001 06:57 AM
Tein medium springs for cheap!! HKscooby Vancouver Impreza Club Forum -- VIC 3 07-06-2001 12:31 AM
Can anyone compare the 5zigen and Tein soft springs paired with the Ver.5 strut? Robmat Brakes, Steering & Suspension 1 04-02-2001 01:16 PM
