Old 02-03-2003, 09:20 PM   #1
hiwrx
Member#: 28021
Default JDM RHD projector lights w/ Jim Hoyd Harness install revision
Hello everyone! Just thought I'd share a little bit about my install experience with my jdm rhd projectors and the jim hoyd harness. Before I get started, let me say -- Get the harness! It will save you the hassle of making one for yourself. Plus, Jim communicated well throughout the purchase. This should be a no brainer for guys with experience in working with cars a lot, but for a beginner like me, I think this will be helpful to you.
First, take off the grill. Use a flat head screwdriver to push off the 4 tabs that hold it in place. Careful as you do this because the grill is a flimsy-ass plastic!
Next, take off the 2 plastic pieces on each side of the grill. They're held down by 2 plastic tabs on the top and one on the bottom (on the inside). Use flat head to pop them out. Carefully pull the 2 pieces out.
Next, choose a headlight. Undo the 3 bolts that hold the headlight in place. Use 10mm. There are 2 bolts that were covered by that little plastic piece, and 1 more on the top.
Carefully jiggle out the headlight. Disconnect the turn signal connection, and the 9007 bulb from the housing. Then disconnect the bulb assembly from the main oem connection.
Now you have to connect the jim hoyd harness. This is the part that confused me and forced me to write up this install. For those of you that don't know already, Jim Hoyd uses BLACK for POSITIVE, and BLUE for NEGATIVE on his HARNESS. It clearly shows this on the pictures of the website, BUT NOT THE DRAWING! The drawing on his website-instructions actually show black as the negative for the harness. Don't get this mixed up!
The harness is used to separate the low and high beams, by the way.
First, on your rhd lights, there are two wires, black and green, behind the low beam housing. Remember, that for the HEADLIGHT, GREEN is POSITIVE, and BLACK is NEGATIVE. Crimp down hard with pliers, the supplied vampire clips, one on each of those wires. Then, plug the big, blue end of the harness to the main oem connection. Then connect the harness' black wire (remember, positive) to the light's green wire(positive). Then connect the harness blue (remember, negative) to the light's black(negative). Check those 2 low beam harness wires before attaching them to the vampires clips, because I noticed on mine that they slipped out easily from that clear plastic area. I had to soder them down against the metal.
Okay! Once you're done with the low beam connection, simply connect up the 3 pronged high beam connection. Don't forget to plug in the turn signal, which runs separately from the other connections.
Do the other light, put everything back in reverse order, and you're ready to rock! Jim said that he would fix the drawing on his site soon. If you got any questions, give me a holler.
Now about the beam adjustment...
hiwrx is offline   Reply With Quote
Jim Hoyd Harness unite Private 'Wanted' Classifieds 2 04-28-2004 10:29 AM
EDM + jim Hoyd harness norseone Interior & Exterior Modification 37 01-04-2003 07:35 PM
For those who have the Jim Hoyd harness on their STi headlights Karl Interior & Exterior Modification 11 12-28-2002 09:01 PM
Anyone else with this JDM Headlights w/ Jim Hoyd harness problem? krazedant Interior & Exterior Modification 14 10-18-2002 11:48 AM
