Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 02-03-2003, 09:23 PM   #1
cvalle-sd
Member#: 420
2001 Cr-V
Default UPDATE - Head Gasket? or maybe...
Burst radiator? could a leak cause the same symptoms? (full puke tank, no coolant) I was refilling/checking the radiator, when I realized that the water level was dropping as I was filling - and there was water coming out somwhere where the aluminum section meets the plastic tank at the bottom. So I hope that's it - how much is an Impreza radiator (anybody have a spare)? I pulled the radiator out and with the exit plugged, I blew into the neck (cleaned, of course), and I can hear "Squeeeeeee" from a couple of places. I'm assuming that the radiator is normally airtight. Might I be less screwed?
cvalle-sd is offline   Reply With Quote
Old 02-03-2003, 10:21 PM   #2
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Jeez, I hope so! It's gotta be a lot cheaper than redoing a head gasket.
**fingers crossed**
Coati is offline   Reply With Quote
Old 02-03-2003, 10:37 PM   #3
kaos200
Member#: 2692
if so Im replacing mine with an aluminum replacement so my stock one will be for sale. Let me know if that is the case.
kaos200 is offline   Reply With Quote
Old 02-03-2003, 10:42 PM   #4
cvalle-sd
Member#: 420
2001 Cr-V
I'll buy it - mine is definitely holed
Old 02-04-2003, 11:08 AM   #5
cvalle-sd
Member#: 420
2001 Cr-V
Default Good news so far
I tried Bar's Heavy Duty Stop Leak, and on a regular commute (keep in mind it was as cold as a witch's) I kept a full load of coolant, which was under pressure when I checked it about 20min after getting to work. So I hope that's that. If you ever have radiator probs, vis-a-vis structural integreity, try the Bar's in the bottle. I got the one made for larger leaks, which comes as a liquid with big granules that all gets poured in, the granules dissolve, and do their magic. It's worked for me at least in the short term.
PS if anybody wants to buy 10gal of distiled water, let me know.
Old 02-04-2003, 11:25 AM   #6
Coati
Member#: 9106
2015 FXT - DGM
Default Re: Good news so far
When you're sure you don't need it, have Lisa bring it in and I'll pay you whatever you paid for it.
Got a bunch of houseplants and irons to feed...
Honda/General Automotive Technicial Question: Head Gasket, or Rings?? Help!!! (long) shinsain Off-Topic 12 06-06-2005 06:12 PM
blown head gasket or not? UGC Normally Aspirated Powertrain 1 03-30-2005 09:20 PM
new head gasket time, maybe chip and exhaust as well? cptomes Engine Management & Tuning 0 02-03-2005 05:22 PM
Blown Head Gasket or ... ??? Celine Newbies & FAQs 15 08-30-2004 01:19 AM
Blown head gasket and maybe cracked block NimrodBoz Normally Aspirated Powertrain 8 05-08-2003 02:59 PM
