Old 02-04-2003, 10:53 AM   #1
Dealer Xing
Member#: 4673
Default I think I flat-spotted my Brand new S-03
I have a set of Bstone S-03 on my 91 MR2(NO ABS). I had an emergency situation on a very smooth highway and I accidentally locked up my left front tire at 80mph(for a brief moment, say 1/2 sec or less). Ever since then my car makes a thumping noise from the tire depending on the speed.
Question is: I bought my tires from tirerack 10 days ago, is there anyway I can complain to either tirerack or Bridgestone? Will the flat spot go away on its own? Any prior experience from fellow members?
BTW, I lost the receipt of the tire installer.
Dealer Xing is offline   Reply With Quote
Old 02-04-2003, 11:49 AM   #2
Frederf
Member#: 15622
2002 WRX SW
You're kinda on one leg in terms of trying to get Tire Rack to help.
If it's really bothering you you could get all 4 tires shaved down to a diameter that removes the imperfection and kiss off the associated treadwear.
Perhaps if you get that tire rebalanced then it'll wear back into round and you won't have the offbalanace wheel in the meantime.
I'm really just winging this one. Anyone else have ideas?
Edit: Wow, I spelled "associated" "accotiated."
Frederf is offline   Reply With Quote
Old 02-04-2003, 12:08 PM   #3
DannyGT
Member#: 6281
2002 Impreza WRX
Graphite Pearl - SOLD :(
wow, I literally just did this a few days ago with my rex....left tire looked up for about 2-3 seconds....and now I get a shacky sterring wheel....what can be done to fix this ?
DannyGT is offline   Reply With Quote
Old 02-04-2003, 04:16 PM   #4
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Are you thinking that you will get the tires warrantied or something like that?
You flatspotted a tire. It will wear itself round again, but thats not the manufacturers or tire racks fault!!!!
-Tom
trhoppe is offline   Reply With Quote
Old 02-04-2003, 04:19 PM   #5
robmarch
Member#: 18713
06 CRV
04 STi
ABS should prevent flatspotting, no?
robmarch is offline   Reply With Quote
Old 02-04-2003, 04:56 PM   #6
Dealer Xing
Member#: 4673
-Tom
My point is for a ULTRA HIGH PERFORMANCE tire a.k.a S-03, it shouldn't flat spot that easily. I'm not trying to blame anyone, I only locked up my tire for a brief moment.
Old 02-04-2003, 04:58 PM   #7
RidinLow
Member#: 329
1995 325i
Arctic Gray
Actually, it should flatspot easier because it's got a softer tread compound than your run of the mill/lasts 100000 mile tire.
S03's don't hold up very well to abuse, judging from those who've tracked them. At least not compared to S02's or AVS Sports.
RidinLow is offline   Reply With Quote
Old 02-04-2003, 05:01 PM   #8
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
AT 80mph, yes it will.
You can flatspot a infinite life firestone if you lockem up at 80mph
-Tom
Old 02-04-2003, 05:28 PM   #9
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
-Tom
he knows too!
nhluhr is offline   Reply With Quote
Old 02-04-2003, 05:55 PM   #10
Frederf
Member#: 15622
2002 WRX SW
I've made an airplane tire square before. They call it the $100 short field landing. They're pretty cheap bias ply retreadable tires 'cause they go through them like socks.
To the original poster: Was your ABS disabled at the time?
Old 02-04-2003, 08:40 PM   #11
IXLR8
Member#: 14570
'02 WRX
that isn't going to happen...
but your shaving idea isn't a bad one, as long as the flat spot isn't too deep (wouldn't count on it, as the others have pointed out, all too easy to square up a tire down to the cord).
IXLR8 is offline   Reply With Quote
Old 02-04-2003, 11:33 PM   #12
Dealer Xing
Member#: 4673
My car doesn't have ABS and there maybe problems with the rear calipers, resulting in more front brake bias.
Old 02-05-2003, 12:30 AM   #13
grumbly
Member#: 8938
2002 A Black Wagon
Most places I know wonít shave a tire once itís been on the road. The dust and dirt will nick up the blade.
grumbly is offline   Reply With Quote
Old 02-05-2003, 12:35 AM   #14
kenchan
Member#: 15106
you may have knocked off a wheel weight instead of flat spotting the tire.
kenchan is offline   Reply With Quote
Old 02-05-2003, 06:20 AM   #15
IXLR8
Member#: 14570
'02 WRX
Good point...
some groveling might be worth a try though before biting the bullet and just buying a replacement, although, in the long run, it probably makes a lot more sense to match a single new tire to your other 3 almost new ones, than give up many thousands of miles of wear by shaving the good ones to match the "bad".
Old 02-05-2003, 06:58 AM   #16
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Exactly...the trade-off for a sticky tire is the softer compound will wear quickly and flat-spot a LOT easier. Good luck w/ the warranty claim.
US2JDM is offline   Reply With Quote
Old 02-18-2003, 12:31 PM   #17
Dealer Xing
Member#: 4673
Problem is solved, tirerack sent me one replacement tire. The tireshop guy was able to use his hand to feel which part of the tire is flatspotted. Thumbs up for Tirerack.
Old 02-18-2003, 02:45 PM   #18
Tire Rack Moderator
Member#: 1215
ext. 4362
we aim to please ...
Old 02-18-2003, 03:51 PM   #19
RawCode
Member#: 3115
2002 Impreza 2.5RS
Wow that is really good of Tire Rack!
RawCode
RawCode is offline   Reply With Quote
Old 02-18-2003, 05:15 PM   #20
David03WRX
Member#: 28546
00 BMW M Coupe
Default WOW
On what basis did they replace it? Kudos to them for being so generous!!!
But what if you hit a curb and popped an almost-brand-new tire? What then? To me it's more or less the same.
You are blessed by Tirerack's generosity for SURE!!!
David03WRX is offline   Reply With Quote
Old 02-18-2003, 06:14 PM   #21
Retro
Member#: 19733
BLOOO
TireRack has always been nice about freebie help. My next set will definitely come from them.
Retro is offline   Reply With Quote
Old 02-18-2003, 07:26 PM   #22
Dealer Xing
Member#: 4673
Well, I still have to ship the tire back to them though. I guess they did this for me since Bridgestone offers 30 day test drive program and the fact that it's the fourth set of tires I bought from TR.com
Old 02-18-2003, 11:55 PM   #23
BIGSKYWRX
Member#: 7958
09 GH B+
No ABS = very easy to flat spot tires. I've seen lots of expensive tires give off the infamous puff, w/ the resultant flat spot. Tarmac- ABS on, gravel- ABS off.
Kudos to tirerack (if only they carried Toyo)
Big Sky
FS: NJ brand new rim/brand new RE92, 03 wrxbert Tri-State Area Private Classifieds 3 02-22-2006 05:01 PM
Free to a good home: brand new 02/03 STi replica mesh fog covers North Ursalia New England Impreza Club Forum -- NESIC 13 08-12-2004 11:28 AM
FS: Brand New 02-03 rear top strut mount smootth Private 'For Sale' Classifieds 0 05-17-2004 05:53 PM
Minnesota Brand New 02-03 Gt spec Carbon fiber hood $299 local pick up RallySport Direct Mid West Subaru Owners Club Forum -- MWSOC 1 05-05-2004 06:00 PM
Cobb AccessPort Brand New 02-03 WRX jcdeng Private 'For Sale' Classifieds 6 04-18-2004 01:15 PM
