Old 02-04-2003, 09:06 PM   #1
sir_aspen_white
Member#: 32358
2000 2.5 RS
"Stormtrooper"
Default how come my LED turn signal bulbs are barfing on my '00 RS?
Just bought two LED 1156 bulbs for my front bumper turn signals. It just won't work. It works fine on my friend's car, so I don't know what's wrong with my car. The regular bulbs work fine...
Can anyone help?
sir_aspen_white is offline   Reply With Quote
Old 02-04-2003, 09:33 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
do you mean you put your bulbs in your friends car and they work? Does he also have an RS?
Jay
Old 02-04-2003, 09:37 PM   #3
sir_aspen_white
Member#: 32358
2000 2.5 RS
"Stormtrooper"
my friend has a Mazda, and he also uses 1156 bulbs. I first thought I confused a 1157 with a 1156, but the 1157 bulb won't fit into a 1156 socket. When the bulb is put into the Mazda, it works fine.
Old 02-05-2003, 01:48 AM   #4
Basshead
Member#: 112
2011 Jetta TDI
i just ordered the same thing..i hope mine work...i'll keep all posted...
Basshead is offline   Reply With Quote
Old 02-05-2003, 02:33 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
because there is not enough amperage(their resistance is too high) to fire them. get rid of them they are junk.
jeremy
Old 02-05-2003, 02:53 AM   #6
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
I think it has something to do with Subaru using a switched ground setup. LED's can only work with proper polarity, and if you send power through them the wrong way it burns them up eventually. I tried these in my sidemarkers, which I have wired as blinkers, and the bulbs only worked for a week or so before they started to go. Mulder will know for sure, if he reads this.
Khail
khail19 is offline   Reply With Quote
Old 02-05-2003, 03:31 AM   #7
Basshead
Member#: 112
2011 Jetta TDI
well the new 168/194 bulbs out have a diode that doesn't allow them to work if polarity is reversed...hence you have to flip them around for those to work...but it's impossible for the front bulbs to get reversed...
Old 02-05-2003, 03:44 AM   #8
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
All LED's have(are) a diode (LED = Light Emitting Diode). I believe the reason the polarity gets reversed in the turn signal bulbs is not cause you put the bulb in the wrong way, but because the switched negative ground setup that Subaru uses sends power through the circuit in both directions, which will fry the LEDs over time.
Khail
Old 02-05-2003, 03:49 AM   #9
Basshead
Member#: 112
2011 Jetta TDI
anyway to change the polarity of the system to an un-switched system? anyone know if they have always used this type of system?
Old 02-05-2003, 04:00 AM   #10
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
I'm sure there is, but it would involve a lot of intensive rewiring, you could forget about any warranty on your electrical system, and it really doesn't seem worth it just to have LED turn signal bulbs. I put the Philips Silvervision bulbs in my car and removed the orange cover in the headlight assembly. They are silver when off, but still blink orange when on. They work fine for me and look better than having an orange bulb.
Khail
Old 02-05-2003, 04:02 AM   #11
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
I'm not sure how long Subaru has used this setup, and I don't know why they do. Other car manufacturers seem to be doing fine with regular positive switched circuits.
Khail
Old 02-05-2003, 04:20 AM   #12
Basshead
Member#: 112
2011 Jetta TDI
cause it sure would be nice if it's just a new(02+) thing since i have a 99..
Old 02-05-2003, 09:16 AM   #13
avk
Member#: 17252
'06 WX8
59E
It seems only the headlight circuit has switched ground connections, although if that changed for '02, it may answer my question about the side marker mod in another thread (and the mod does reverse the polarity for the side markers depending on whether the light switch is on or off).
Add: switched ground only for headlights.
avk is offline   Reply With Quote
Old 02-05-2003, 05:35 PM   #14
sir_aspen_white
Member#: 32358
2000 2.5 RS
"Stormtrooper"
Unhappy
... so no hope?...
Old 02-05-2003, 06:19 PM   #15
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
jeremy
:nods head:
DoctorNick is offline   Reply With Quote
Old 03-10-2003, 06:39 PM   #16
sir_aspen_white
Member#: 32358
2000 2.5 RS
"Stormtrooper"
Just an update. I switched polarities on the front turn signals and they are working fine right now. I'll update again should the LED's fail.
Old 03-11-2003, 02:21 AM   #17
Basshead
Member#: 112
2011 Jetta TDI
glad to see someone else isn't a skeptic willing to toss their bulbs...just got done with mine this weekend
http://forums.nasioc.com/forums/show...95#post3498795
FS: Fastwrx Color Changing LED Turn Signal Bulbs for 08+ Subirex09 Exterior/Styling 5 05-12-2010 03:43 PM
1999 RS w/ LED turn signals Basshead Electrical & Lighting 6 03-11-2003 02:20 AM
What size are the rear turn signal bulbs for the WRX? KillerRex Interior & Exterior Modification 3 07-08-2002 11:59 AM
Anyone using LED turn signal bulbs... Norb Interior & Exterior Modification 18 11-01-2001 10:14 PM
