Old 02-05-2003, 11:39 AM   #1
jeffg
Member#: 2958
2001 WRX (GC8)
Default Heater only works on 4(high)
I recently noticed that my heater is kind of broken. I only really use it to defrost the windows. The last couple of days I defrosted the car using the heater on 4. As I drove to work, I would turn the heater down to 2, and the windows would begin to fog up again. If I move the switch to 4 I can actually feel the air flow and the windows clear.
There is very little or NO air flow on any other setting by 4. Does anyone know a set of tests, or things I can look at to try and fix this. I know I could take it to the dealer for a fix, but since I removed my AC, I think they would try and charge me for the repair.
Any help?
J
jeffg is offline   Reply With Quote
Old 02-05-2003, 12:12 PM   #2
avk
Member#: 17252
'06 WX8
59E
Likely an open circuit in the resistor pack. With switch in "4", the resistors are bypassed and the blower still works.
avk is offline   Reply With Quote
Old 02-05-2003, 12:53 PM   #3
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Simple fix, the A/C Fan Relay has gone bad. It's somewhat common. The relay costs about $35 from the dealer, it's located behind the glovebox. Replace it and all 4 fan settings will work again!
Opie is offline   Reply With Quote
Old 02-05-2003, 03:23 PM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
Opie,
You say it is the AC fan relay. Would removing the underhood portion of my AC system have any effect on this? I have not touched anything under the dash, but I did remove the compressor, condensor and all of the underhood lines.
Is there anyway to test the AC fan relay? I assume it is like a normal relay and I can supply voltage to one pin and it will switch it to somewhere else.
Anyone have details testing instructions for this?
Thanks
J
Old 02-05-2003, 03:50 PM   #5
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Hmmm, removing parts under the hood shouldn't have affected it. I doubt you could've caused a surge or voltage spike that might of damaged it.
I had the relay go out twice on the '95 Impreza I used to have. Same symptom, fan would work only on the highest setting (4). Part number for all '93-'01 Impreza's is 72024AA000. I don't know if there is any way to test it...maybe you could take yours out and test it in a friends Impreza and vice-versa.
Old 02-05-2003, 04:06 PM   #6
avk
Member#: 17252
'06 WX8
59E
That p/n is for the resistor pack:
http://www.subaruparts.com/cart/?pn=72024AA000
My Heater Fan only works on full blast. Why? tbcboo Service & Maintenance 7 05-06-2009 03:57 AM
Heater Fan only works on Full Blast. Help! tbcboo Service & Maintenance 3 05-06-2009 02:07 AM
02 wrx driver side headlight dont work,only works on high beam>>help! password:ej20 Electrical & Lighting 10 08-07-2008 02:33 PM
Heater blower fan only works on High? dg_performance Service & Maintenance 4 01-29-2008 09:46 PM
Power window switch only works on driver side? newsman Car Audio, Video & Security 2 06-23-2003 06:48 PM
