Old 02-05-2003, 02:50 PM   #1
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
Default Hella 500s doesn't work why?
I have Hella 500s on my car now, and lately, It doesn't work at all. I checked the fuse, relays (hella's), and the bulbs (not blown). All of them have power going to them but it just won't light up. Why is that? How do I solve this problem?
ImprezaTs is offline   Reply With Quote
Old 02-05-2003, 03:00 PM   #2
Rudypoo
Member#: 702
2005 LGT
Are you using the factory wiring or the Hella wiring?
If you're not working today I can come by to check it out.
Rudypoo is offline   Reply With Quote
Old 02-05-2003, 04:54 PM   #3
jeffg
Member#: 2958
2001 WRX (GC8)
you say you have power going to them, but are they grounded? There is a small metal tab on the back of the light that needs to be grounded. I had problems with my grounds coming off the back of the light when I used the stock clips.
J
jeffg is offline   Reply With Quote
Old 02-05-2003, 05:05 PM   #4
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
Rudypoo: using hella's wiring. I am working tonight lets see if you are free tom night or not.
yeah they are grounded. My wirings and relays are the same on the day I got them installed.
Old 02-05-2003, 05:11 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
So they worked and now they dont work?
Sounds odd.
J
Old 02-06-2003, 05:55 AM   #6
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
yeah they worked before and all of a sudden they just don't work anymore..
Old 02-06-2003, 01:34 PM   #7
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Where are you getting your switched +12v power from? Are you going directly from the batter to the switch, or getting it from a wire that goes positive when the lights go on?
If you're pulling from any location in stock wiring, have you checked the fuses for the stock wiring? You might also consider getting a covered relay if yours is located in the engine bay. Radio Shack has 30AMP relays, which is all the Hella one is.
Maybe check the connections as well, maybe a wire pulled loose or is slightly corroded or something.
Just tossing ideas out there.
AJ
AJ711 is offline   Reply With Quote
Old 02-06-2003, 10:16 PM   #8
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
getting the wire that goes on the positive side of battery
I am using the Hella relay. It could be corrosions.
Old 02-07-2003, 02:32 AM   #9
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I had a similar problem with my rallye 4000s... turned out I neglected to reconnect a ground after changing my sparkplugs (relays ground to screw holding washer res to strut tower, removed to do driver's side plugs). <shrug> It's easier to fix if I can get my hands on them. Good luck
CosmoTheCat is offline   Reply With Quote
Old 02-10-2003, 04:42 AM   #10
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
Found the problem. Blown fuse from power wire.
A friend and I checked it out earlier it looked fine. Then tonight Rudypoo and I checked it again, it still look fine. It has the power going through it. All of a sudden, the end cap of the fuse fell off Hence the reason why my fog lights aren't working.
Paypal waiting for you -- who can tell me why part of my site doesn't work in IE? jamesfacts Off-Topic 16 02-23-2010 10:24 PM
Any ideas why my cruise control doesn't work Jncominco2 Electrical & Lighting 8 08-02-2009 02:05 PM
WTT Hella 500 Driving Lights for Hella 500 Fogs XanRules Private 'Wanted' Classifieds 1 02-22-2009 11:22 PM
Figuring out why something doesn't work is the hardest part. 5252 Normally Aspirated with bolt-on Forced Induction Powertrain 17 02-21-2002 08:08 AM
Any idea why the links page doesn't work..?? Aaron'z 2.5RS General Forum Archive 1 02-14-2001 03:11 AM
