#1 |
Member#: 32603
im a big guy, 6'9" 270lbs, I have a Boxster S and I fit "OK". I use that as my track car so comfort isnt a big deal. But I am thinking about the new WRX STi as a daily driver. However, will I fit behind the wheel? Ive never been in a SCooby before so im asking. Are there any other tall guys out there that fit? If so, did you have to modify the seat /rails or anything to be comfy?
TIA
#2 |
Member#: 3960
Go sit in a WRX. Should be a good test.
#3 |
Member#: 5796
Vehicle:2007 11 F150, 2004 WRX-dont get married! |
pm lo-buck, hes your same height!
-mikey |
#4 |
Member#: 1197
Vehicle:1997 Impreza Wagon Mystic Blue Pearl |
I'm 6'10", but you outweigh me by over 50 lbs, so my experiences might not be accurate. Assuming the standard WRX fits the same as an STi, my experience has been that they're pretty roomy, assuming you don't have a sunroof. Headroom is pretty good, although I confess that I'd probably take the seat out and remove a little foam from underneath to get an extra half inch or so. Legroom isn't exactly stellar. It'd be nice if the tracks went back an extra inch or so, but then they'd need to make the steering column fore-and-aft adjustable or it'd be too far away. I already wish it were a tad closer. There's pretty decent room in the footwell for large feet, though you may not have that problem.
Hope that helps some Jeff |
#5 |
Member#: 6120
Vehicle:BE5B AVOed B4-RSK Sorta White |
I'm not nearly as tall as that, but I can say that one way of getting around the "high-ish" seating positions of Subes (I just like to sit lower) is to just yank the std pew out and replace it with a good driver's seat - Recaro or whatever works for you.
You can get lots more headroom from that, just make sure the seat rail is not a cheapo one (not good for safety, and sometimes not rigid enough = flexy). HTH |
#6 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
I'm 6'5" 250lb and have no trouble but you might have issues wearing a helmet.
#7 |
Member#: 4374
Vehicle:06 Titan,99,94 SM 06 nasa spec miata champ |
and dont forget the option of removing the sliding brackets and replacing them with fixed brackets. (like what race buckets use)
This will drop the seat height by several inches, and give you much more headroom, as well as allow you to move the seat back as far as you need for legroom. |
#8 |
Member#: 16803
International
I'm 6'5" and I sit with my seat about halfway up. I guess I'm just weird, but I feel much more in control closer up. I hate it when people drive my car and first thing they do is put the seat ALL THE WAY BACK. And most of 'em are shorter than me.
| Thread Tools | |
| Display Modes | |
| Will 05 STi frnt & rear seats fit in 03 wrx wagon? | sc00bywagon | Interior & Exterior Modification | 3 | 09-13-2005 04:00 PM |
| Will STI Version 6 seats fit in 02 wrx? | wrathfirex | Interior & Exterior Modification | 10 | 05-27-2004 05:00 PM |
| Will this fit in my WRX ?? | Torch | Texas Impreza Club Forum -- TXIC | 11 | 12-06-2002 07:59 PM |
| Diamond Audio components. Will they fit in a WRX? | Code-7 | Car Audio, Video & Security | 0 | 04-13-2001 02:32 AM |
