Old 02-05-2003, 08:27 PM   #1
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Default I feel stupid...little Cisco help please
I just got my first 2500 router tonight, and I'm trying to connect to it.
I've got the RJ-45 in the AUX port, and I've got hte adapter to 15-pin serial on the other end, into the computer.
I opened Hyperterminal, and I tried to connect through COM1, and I get nothing. It says connected at the bottom of HT, but I see no text. Any help is appreciated. Thanks.
JGard is online now   Reply With Quote
Old 02-05-2003, 08:33 PM   #2
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
You don't wan to be plugged into the AUX port, you wanna be plugged into a port that either says "Console" or "CON". I don't have a 2500 in front of me, but it should look something vaguely like this. The AUX port is for setting up a dial connection I think
bigdweeb is offline   Reply With Quote
Old 02-05-2003, 08:35 PM   #3
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
well, from what I've read, the AUX and CON ports work the same, except that you have more control, in that you can set up the dial-in settings.
I think it's something with my Telnet settings. I don't really know what they're supposed to be
Old 02-05-2003, 08:42 PM   #4
The real boxman
Member#: 23401
2005 Legacy 2.5GT LT
Platinum Silver
Listen to good advice like that above.
The aux port is not necessarily set up for communications straight out of the box, the console port is...9600baud 8,n,1 for the 25XX IIRC.
And...if you have a 15pin serial connection on your PC that'd be a first. They are either 9 or 25 pin connectors (I hope you have the Cisco factory converter)
boxman
The real boxman is offline   Reply With Quote
Old 02-05-2003, 08:42 PM   #5
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
You aren't telnetting... you're just attaching to the console. You basically setup the COM port and then hit the little connect telephone icon.
I would make sure you are indeed connected to the console port first. Then, verify that you are indeed connected to COM1. Check the port settings: 9600 baud, data bits 8, parity none, stop bits 1, flow control off.
If all that checks out, try disconnecting and reconnecting to the serial port. If that fails, try a [Ctrl]+L (redraw the screen) or hitting return a bunch of times. If that fails, try restarting the router. Also, are you using a flat cisco console RJ-45 cable? I don't think it is the same pinout as a normal patch cable.
From what I recall, Ciscos and Hyperterm don't play well together. You may want to try a different terminal emulator that has console abililty. I know that Cisco makes one, but I'm not sure I have a copy with me at home. I will look though.
Old 02-05-2003, 08:45 PM   #6
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
ok, yeah 9 pin, my mistake.
I do have the Cisco hardware...that flat RJ-45, with their serial converter. I'll try that CTRL-L, I have tried just pressing enter.
I'll also check those connection settings. Thanks guys!
What other options do I have for programs?
Old 02-05-2003, 08:45 PM   #7
MightyWRX02
Member#: 16518
1584 Pirate Ship
Type ARRRRRRR!
MightyWRX02 is offline   Reply With Quote
Old 02-05-2003, 08:46 PM   #8
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Thong th-thong thong thong....!
moogoob is offline   Reply With Quote
Old 02-05-2003, 08:51 PM   #9
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
cool, I got in! It was the flow control that I had set wrong, thanks.
Of course, now there's a password on this stupid thing! Argh!
Anyone have the phone # for Cisco?
Old 02-05-2003, 08:52 PM   #10
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
I actually do have a copy of the Cisco terminal emulator!
Other than that, I really like Vandyke SecureCRT, but it's not free. I think PuTTY may support console connections too... I know it supports telnet/ssh.
Old 02-05-2003, 08:52 PM   #11
cdclark
Member#: 8095
2010 OB: Subie #3
2010 Golf TDI 6sp Manual
I dunno which 2500 you got (you didn't state) but the aux port is a network port. The console port (which is also RJ45) is what you should be plugging into.
I couldn't find my console adapters when I got my machine, so I went to micro center and bought a couple of the make-your-own adapters, the kind that come with the pins not set in the 9-pin side. I found some diagrams on the net and got it right on the second try.
Also, I assume you have a flat (not twisted pair) cable for the connection? It should be blue and flat with Rj45 connectors on both ends if its the original.
AIM or ICQ me if you need more help.
-Cameron
cdclark is offline   Reply With Quote
Old 02-05-2003, 08:54 PM   #12
The real boxman
Member#: 23401
Platinum Silver
Just about any old dial application that supports an ANSI terminal...you know like we used to use back in the BBS days before the intraweb thingy.
Hyperterm should work just fine, it's what I usually use. You've just got to make sure that you're using the right com port.
boxman
Old 02-05-2003, 08:56 PM   #13
The real boxman
Member#: 23401
Platinum Silver
I'm gonna PM you the password recovery info....hang on..
EDIT: The info is too big for PM so I used "send e-mail". Let me know if you got it.
Old 02-05-2003, 08:57 PM   #14
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
sorry, it's a 2501.
i'm in now. I'm currently following Cisco's web site to get past the password in this (I bought it off ebay)
thanks for all the help
Old 02-05-2003, 08:59 PM   #15
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Here are the Cisco Password Recovery processes for all routers. It's good practice!
Old 02-05-2003, 09:01 PM   #16
The real boxman
Member#: 23401
Platinum Silver
I somehow thought that was only available on the private customer site. It makes no sense for it to be public....
Old 02-05-2003, 09:01 PM   #17
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
yep, that's the site I found.
kinda odd that it is up in public, but it's helping me out!
Old 02-05-2003, 09:02 PM   #18
cdclark
Member#: 8095
2010 OB: Subie #3
sorry, it's a 2501.
Cool, if you're ever really in a bind and have no moral qualms, there are a LOT of Cisco texts available on Kazaa in PDF format. I found the CCNA book I bought on there last week, the current Cisco Press one by Wendell Odom. As a broad preparation for the exam it covers lots of things like password recovery, etc.
-Cameron
Old 02-05-2003, 09:05 PM   #19
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
my email is actually sent to my work account. But I have now gotten past it, and I'm currently just erasing the starting config.
Thank you very much for your help so far!
damn, I'm glad to see there are so many helpful people here, even when it's not car related
Old 02-05-2003, 09:06 PM   #20
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Nope... Cisco is pretty cool about making a decent amount of info public. You kinda need to know how to look for it, but it's there. I don't see why they would need to make this info private anyway... you do after all need access to the console port to break in... If you are that concerned about the people who have physical access to the equipment, you should probably either have better security or more trustworthy associates
Old 02-05-2003, 09:08 PM   #21
The real boxman
Member#: 23401
Platinum Silver
We're all geeks of one sort or another as well as being car geeks/freaks.
Good luck and don't hesitate to ask for help. I've been making my living off of Cisco for the better part of a decade.
boxman
Old 02-05-2003, 09:11 PM   #22
The real boxman
Member#: 23401
Platinum Silver
Yeah, I agree that if you have your hot little hands on the box everything else is largely moot... I haven't actually been on the public site in more years than I care to recall so I'm a little out of touch with what is or isn't available there.
boxman
Old 02-05-2003, 09:36 PM   #23
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
since you guys know more about these things than I do...
I've been studying for my CCNA for a while now. I just got this router. Should I purchase another, along with a DCE/DTE cable to interconnect them?
I do have a router sim program, which has like 4 routers and 3 1900 switches in it...it has most of the real router commands, but not quite all, I don't think.
Any advice is very welcome
Old 02-05-2003, 09:41 PM   #24
The real boxman
Member#: 23401
Platinum Silver
Router sim works well enough but isn't nearly as fun as having your own test lab. If you're not spending too much money I'd keep buying the equipment, you can always sell it when you're done.
boxman
Old 02-05-2003, 09:46 PM   #25
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
You could setup some simple circuits just using the two serial ports on the 2501. I believe you would need a DCE cable to do this unless you have an external CSU/DSU for each interface. In that case you would need DTE cables I believe. To setup anything more complicated than 1 T1, you may want to look into getting another router to play with, and maybe a Catalyst switch.
Need a little jerb help, please Mike37 Off-Topic 7 08-27-2008 10:15 PM
A little PHOTOSHOP help please. spoonfedb18a1 Member's Car Gallery 1 01-21-2007 10:19 AM
A little song help please... BigWrecKs Off-Topic 5 05-11-2006 01:51 AM
A little UTEC help, please. StiDreams Engine Management & Tuning 7 07-06-2005 12:41 PM
Little UTEC help please StiDreams Engine Management & Tuning 9 03-24-2005 12:21 PM
