Old 02-05-2003, 09:43 PM   #1
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
Default piaa bulbs went out!!
went to start the car tonight and turned the lights on to see both low beams blew. i pulled every fuse relay to check but its the bulbs. so $65 down the drain. i done with these bulbs im just going to put basic bulbs in the car they seem to last longer.
aj's25rs is offline   Reply With Quote
Old 02-06-2003, 05:55 PM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
PIAAs are under a one year warranty. i had a low beam go out and took them back to where i got them and they replaced them for free. what u'll actually have to do is send them back to PIAA and they will send u new ones. where i bought them, i just gave them cash to ship them back and they gave me new ones.
Brent
scoobyimprza is offline   Reply With Quote
Old 02-06-2003, 06:02 PM   #3
kenchan
Member#: 15106
hummmm... im not saying that you made an error during
installation, but mine are lasting longer than 16months.
its always best to turn off your lights before firing up or
shutting off your engine.
kenchan is offline   Reply With Quote
Old 02-06-2003, 06:10 PM   #4
JOHN16V
Member#: 21491
2000 Subaru Impreza
2.5RS BRP Sedan
So, what's new?? ( I give up on those $80.00 bulb long time ago......when money stop coming out of the ATM)
Just go with the GE Cool Blue, they are much bighter than the stock .....I install a pair 2 year ago and it still burning!!
JOHN16V is offline   Reply With Quote
Old 02-06-2003, 06:20 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
hmm, thats not a bad idea, i leave my lights on when i turn my car off. u also wanna be careful not to touch the bulb, that might have happened since they both went out at the same time. u can also get cheap bulbs off ebay.
Brent
Old 02-07-2003, 02:40 AM   #6
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I'm going to take a stab in the dark (rim-shot please?)
Did you by any chance buy higher wattage bulbs than stock/legal (ie 80/100, and I'm not talking about the 55=80 xtra technology crap).
I buy Hella H4 80/100s and they last a month or three then burn out. When one goes the other usually follows. They burn out fast because they're a lot hotter than the headlight assembly was designed for, therefore they're overheating. I accept this with my Hellas, but at $12 a piece I can live with it.
CosmoTheCat is offline   Reply With Quote
Old 02-07-2003, 08:19 AM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
mine are the 125/135w and when my one low beam went out, i changed back to the stock bulbs like 2 days later and the other bulb hadn't burned out.
Brent
Old 02-07-2003, 01:57 PM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I had PIAA extreme whites on my car... They lasted about 10k mi or so, but I do that distance in ~3-4 months. Instead of paying $50 per set and replacing them every couple months, I bought a set of HID's instead. They're much much brighter and last a lot longer
-vic
cRayZee is offline   Reply With Quote
Old 02-08-2003, 02:51 AM   #9
Basshead
Member#: 112
2011 Jetta TDI
ditto, after paying over $400 over the past few years for PIAA's it's time to spring for HID's....coulda bought em already!!..
Basshead is offline   Reply With Quote
Old 02-08-2003, 09:21 AM   #10
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
mine were the stock wattage. they werent touched or anything and both went oput the same time. i put stockers in since they dont go out as fast. im tired of driving places and people telling me i have a light out.
Old 02-17-2003, 10:15 PM   #11
wrxracer
Member#: 5275
2002 impreza WRX
WR BLUE
Default piaa's
knock on wood.. i have the extreme whites also. now for right at a year and no probs... i have good luck with all my PIAA bulbs..wife's dodge has them also 3years+....good luck either way, replace or HID's..
wrxracer is offline   Reply With Quote
both High beam and Fog light bulb went out at the same time :( Mike7 Electrical & Lighting 1 09-28-2009 11:30 AM
bulb went out again :( Osram Nightbreaker +90 MyScoobie28 Electrical & Lighting 10 07-11-2009 03:01 PM
PIAA bulbs vs Philips.. Whats a good bulb? ThreeSheets2116 Electrical & Lighting 7 10-31-2008 09:50 AM
My 1st and 2nd gear went out! Need help went taking out tranny? Kavaoski_08 Transmission (AT/MT) & Driveline 4 09-29-2007 10:16 PM
morette bulbs, mine went out teamslow wrx Electrical & Lighting 1 08-13-2003 08:02 AM
