Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 06-12-2001, 11:15 PM   #1
The Wraith
Member#: 7252
Post 18" wheels, will they fit?
Will the Prodrive O.Z. P1 18x7.5 fit my car with a stock body, someone told me it wouldn't i haven't done anything to the exterior of the car or anything to drop it and i want the 18" wheels. I hope it fits. i will be running 215 40ZR18 Yokahama Paradas. It's a 2000 Impreza coupe RS.
The Wraith is offline   Reply With Quote
Old 06-13-2001, 05:28 AM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Post
I've seen 18x7's +50 fit on a lowered RS, but don't know if that extra half inch in width will make a difference. I think you should be fine as they are an option on the UK P1 which does sit lower than the US Impreza RS.
Jon
omahasubaru is offline   Reply With Quote
Old 06-13-2001, 06:49 AM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
If you are worried go with a 225/35/18, they should fit ok w/o rubbing
GTBGUY is offline   Reply With Quote
Old 06-13-2001, 08:08 AM   #4
rkkwan
Member#: 5596
2010 Honda Fit Sport
Post
I have the exact same setup, but on a 02 WRX sedan. The overall diameter is actually slightly less than stock, so it's the width that might be a problem, which is rubbing against the strut tower. I hope someone with a RS will have a definite answer. You're always welcome to drive up to RI to swap on mine, if you want to be 100% sure.
rkkwan is offline   Reply With Quote
Old 06-13-2001, 11:33 AM   #5
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Post
The 18" Prodrives rub on a WRX? I thought Tirerack said they fit without problems??
Conduit is offline   Reply With Quote
Old 06-13-2001, 01:30 PM   #6
dead-eye
Member#: 43
1999 2.5RS no T
RBP
Post
flipguy80,
What kind of Impreza do you drive? I have a MY99 2.5RS and was considering the 18" P1's with Kumho 712 in 225/40/R18 (after the wedding expenses are taken care of ). My friend has the setup I just mentioned and he's had some rubbing with the left rear wheel but not the others. Have you had similar problems?
dead-eye is offline   Reply With Quote
Old 06-13-2001, 10:01 PM   #7
The Wraith
Member#: 7252
Talking
thank you for your help guys
Old 06-14-2001, 12:05 AM   #8
flipguy80
Member#: 5987
Platinum Silver Metallic
Post
The 18's should fit fine. I run 225/40/18s and no rubbing problems.
flipguy80 is offline   Reply With Quote
Old 06-14-2001, 12:21 AM   #9
rkkwan
Member#: 5596
Post
Conduit - of course the 18" P1 don't rub on a WRX, but I was referring to the original poster who has a 2000 RS.
Old 06-14-2001, 12:25 AM   #10
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
Don't go with the Paradas the section width(8.9) is a little wide and I have heard they are great rain tires but not very good for stickiness.
Check out the Falken FK451(GRB) in size 215 40 18. Section width is 8.6" and a diameter of 24.7. They would be $149 shipped to my door from www.vulcantire.com. These are a much higher performance tire.
Roll that fender lip. You won't be able to avoid it in the future when you put performance suspension on there. You'll thank me when you do.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 06-14-2001, 06:32 AM   #11
flipguy80
Member#: 5987
Post
I have a 02WRX Sedan and no problems rubbing at all
-David
[ June 14, 2001: Message edited by: flipguy80 ]
Old 06-14-2001, 07:15 AM   #12
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
I 2nd the motion for the Falkens, I've used them before and they are a great tire!
Old 06-14-2001, 07:57 AM   #13
sanders
Member#: 187
Jade 05 b0x
Black Cherry Pearl
Post
go for it... it'll fit... i run p7000 215/40/18 rim in a 50 offset... i only have minor rubbing when lowered all the way... none when raised!
sanders is offline   Reply With Quote
235/55/17 on stock BBS wheel WILL THEY FIT? full of dents Tire & Wheel 42 05-13-2010 04:45 PM
5zigen FN01R-C 18" will they fit? anthony c. Interior & Exterior Modification 3 10-04-2005 12:15 AM
Forester Wheels, Will they fit? urabus97 Legacy Forum 4 06-19-2004 01:20 AM
18" M3 rims...will they fit? WReX N Effect Tire & Wheel 13 11-27-2003 12:14 PM
15" oem wheels, will they fit? GRNMTNRS Legacy Forum 1 10-24-2002 08:47 PM
