Old 02-06-2003, 08:23 PM   #1
Kevex
Member#: 1275
2000 Impreza 2.5RS
silverthorn
Exclamation help!!! CE light flashing!!!
well my alarm brain have been falling off the compartment under steering wheel, so I open the cover, and try to stuck the brain in between some wire. after I did that, I start the engine, and the CE light was flashing. so I turn off the engine, and put the key in "on" position. the CE light still flashes on that position. another weired thing is when the key is on that position, my radiator fan will turn on, and there's a clicking sound coming from the relay right next to the fuse box. BTW, I've done fog light on with park light mod before, now I returned everything to original, would that be part of the problem?is my car gonna die pretty soon? thank you guys. Kevin
Kevex is offline   Reply With Quote
Old 02-06-2003, 08:46 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
By any chance while you were under there did you find a couple of connectors (probably green) that were unplugged and connect them together? If so that explains your situation. Those are factory diagnostic connectors that are meant to be left unplugged and if you connect them the results are exactly what you described.
I know these connectors are present in the '02s and Subaru has probably used them in earlier years as well so chances are your car has them.
Old 02-07-2003, 02:35 AM   #3
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
what he said.
And if not, find somebody local to pull the code. I'd do it but a) I'm 90 miles away and b) you shouldn't drive with a flashing CEL.
If you're still stuck this weekend I might be heading down to Bothell to do some work and I could swing by to pull the code if I do.
Later
CosmoTheCat is offline   Reply With Quote
Old 02-07-2003, 05:32 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Got word from him in another forum, I was right
will the CEL flash when detonation occurs even if the CEL is already lit? x12oyx316x Factory 2.0L Turbo Powertrain 2 05-17-2004 08:02 PM
HELP HELP - CEL Flashing and Fans Cycling GarySheehan Factory 2.0L Turbo Powertrain 5 05-05-2001 10:17 AM
('93-'01) HELP HELP - CEL Flashing and Fans Cycling GarySheehan Impreza Forum 5 05-04-2001 05:03 AM
HELP HELP - CEL Flashing and Fans Cycling GarySheehan Motorsports 1 05-03-2001 09:52 PM
Message Board Statistics All times are GMT -4. The time now is 11:36 PM.
