Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 02-07-2003, 02:53 AM   #1
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
Default A few questions about wheel + tire sizing
Hopefully this hasn't already been covered, I tried searching a little but didn't come up with a definitive answer. I am just getting into auto-x and am looking for a good rim/tire choice. I was thinking about running my stock RS rims, with some 215/45/16 Azenis. First of all will those rub, the other suspension mods I have with it is some STi v.6 springs, and KYB AGX dampers. Second of all why is it that alot of auto-x competitors run 16s but in rally they run 18s on tarmac? I am sure there is an easy answer for this that maybe I am just missing.
-Wes
RebelINS is offline   Reply With Quote
Old 02-07-2003, 03:27 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Those wont rub at all with your suspension.
And they run 16's due to weight, along with the ability to run lower-profile tires which change the rotational diameter of the tires allowing the car to accelerate faster at the cost of high end speed (which is fine for autocrossing due to the fact you dont go very fast) plus you can run some nice sticky tires at that size that work perfect. Also, for stock classes you also have to run 16's due to restrictions If I am not mistaken.
I think your plan there is just perfect, the falkens on a 16" is a very competitive setup for stock classes and ST-S/X.
Old 02-07-2003, 10:07 AM   #3
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
The only reason to run larger wheels is for clearance for larger brakes. You're on the right track using the 16's on stock RS wheels. The 215-45-16's will also reduce your gearing 5% and of course increase the width by 10mm. I run these on my 01RS with no problems or rubbing on the track.
jack
Old 02-07-2003, 12:55 PM   #4
Krelkor
Member#: 6630
2001 GC8
black
i get very marginal rubbing only with 5 people in the car or when the wheel is at lock
i run 225/50/16
Krelkor is offline   Reply With Quote
Old 02-07-2003, 08:47 PM   #5
RebelINS
Member#: 2953
2000 Impreza 2.5RS
All of that stuff is good to know, I am looking to run in STS. Does anyone know how off my speedometer will be off with the 215/45/16s? Stock my speedo says that I am going on average 2mph faster then I actually am.
-Wes
Question about offset, tire size, wheel width... wgr73 Tire & Wheel 7 01-27-2010 04:15 PM
Ot skaters/ex-skaters, A question about wheel size..... Meat Supply Off-Topic 17 06-08-2009 09:03 PM
a few questions about painting wheels? EJ22Boom Interior & Exterior Modification 12 03-04-2005 11:36 PM
noob question about wheel size and weight ScoobyBoy Tire & Wheel 11 11-13-2003 12:11 PM
A few questions about Rota SDR's and tires. *-* Tire & Wheel 6 07-15-2003 04:12 PM
