Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 03-22-2001, 08:28 AM   #1
swaun
Member#: 5051
Question What's the deal with 225/55R16 Kuhmo V700's?? AutoX tire help please!
I'm an AutoXer that is stuck in a region where I'm the only 2.5RS that regularly competes. Therefore, good 2.5RS Auto-X info is hard to come by. All last season, I used my RE92s and did pretty well with them. I need new tires for this year, and I really want to go with the Kuhmo Victoracer V700's. As everyone knows, they are not available in our 205/55 size (since I want to stay in GS, going to 15" is not an option). I know that some people out there have gotten the 225/55's with a stock suspension. How did it work out?? What problems did you encounter? Would you get them again?
If you have had a good experience with another AutoX-only tire in GS, please comment as well.
Thanks
swaun is offline   Reply With Quote
Old 03-22-2001, 09:00 AM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
Actually the closest V700 is 225/50 16 (same sidewall height as 205/55 stock tires.
I have tried them.
They rub (badly) on the rear suspension.
I did purchase some H&R 10mm spacers, but never used them.
The only other choice is 205/55 BFG gForce, though the V700 is prob a better tire.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 03-22-2001, 10:12 AM   #3
Darshu
Member#: 1676
98RS w/ EJ207/Hydra
2002 BMW M5
Post
I've been running 225/50 16 Pirelli P7000 SS for about 20k miles and they only rub if put someone fat in the back seat and hit a big seam (Boston roads are really bad, for those who've never witnessed them) Otherwise, they're fine. Just my experience though.
-Kurt.
Darshu is offline   Reply With Quote
Old 03-22-2001, 12:35 PM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I would highly recommend the 205/45-16 Hoosier R3S03. Like all Hoosiers it runs big for its size, but it really is very short compared to stock.
Sticks better than a Kumho, too bad they don't offer it in the autocross compound for that size.
If you use the 225/50-16 Kumho V700 better be in a class that allows light fender mods (STR) or wholesale flaring (SP and above) or you'll be sorry.
[This message has been edited by ColinL (edited March 22, 2001).]
ColinL is offline   Reply With Quote
Old 03-23-2001, 11:16 PM   #5
webkris
Member#: 70
I sold WRX to buy
Dodge Neon Rally Car
Post
Ahhh! Crap! Back to the drawing board.
Kumho V700 225/50/16's
They rub on the suspension side??
These were the tires I was going to mount on the stock rims of my WRX for this years autocross season...
Hrrrmmm. I an use small spacers and still remain in G Stock. I also have the fender flares to work with... Not looking good for KC and the wagon.
Oh - I just remembered!!! I have 6.5" width rims! Not the 7" wide RS rims...
There may be hope for me yet!
webkris is offline   Reply With Quote
Old 03-23-2001, 11:21 PM   #6
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
I remember reading somewhere that BFG has a 215/50/16? I think those were the KDW's...
I'd personally go with the 205/50/16's the extra sidewall strength is worth the ~4% less on the speedo
GTBGUY is offline   Reply With Quote
Old 03-23-2001, 11:22 PM   #7
RidinLow
Member#: 329
1999 C5
Post
Yes, but the 6.5" wide rims have an even greater offset of 55mm so you still may be rubbing.
RidinLow is offline   Reply With Quote
Old 03-23-2001, 11:54 PM   #8
webkris
Member#: 70
I sold WRX to buy
Post
Kumho only sells the V700's in the 225/50/16 (the closest size we could find. I have my heart set on Kumho rubber.) Now on there spec sheet they say that the tires will fit a witdh of 6" - 8". Seeing as I'm at 6.5" - I thought "cool - these will work."
Greater offset?? On a less wide tire? I don't think so. I believe it's a 51mm vs the 53 of the 7". The wider the rim, the "deeper" the offset would have to be.
I've been wrong before...
- Kris
Old 03-24-2001, 08:04 AM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
The WRX rear suspension is slightly different --- the 225/50 Kumhos might not rub on the WRX.
The 225/50 V700's have a wider section width compared to other 225/50 tires for some reason.
Also, when I said H&R 10mm spacer before I was smoking crack, I think it is a 5mm spacer per side which they call the 10mm kit.
Glenn
Old 03-24-2001, 09:02 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Kris (who only has 18mm and isn't afraid to admit it ) - Yes, the 6.5" wide rims have a +55mm offset. That's what your old GT rims had, and there's a post on this Forum somewhere (I think) that a guy found the "+55" stamped on the inside of the rim. I'm not sure I understand why the wheels are spaced that way, but they are. I know from looking inside the rear wheel wells of my 2.5GT that it's nearly as tight a fit between the tires and the struts as it is on an RS.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 03-24-2001, 05:23 PM   #11
webkris
Member#: 70
I sold WRX to buy
Cool
Like this?!
<IMG SRC="http://24.147.94.96/misc/threewheel.jpg" border=0>
This is a pic of KC with BFG slicks, three wheeling it into a corner. Very nice!
Old 03-24-2001, 05:57 PM   #12
bill harvey
Member#: 10
1998 2.5RS
Brilliant Red
Post
i know they aren't as sticky as a auto-x tire but yoko a032r come in 205-55r16
bill harvey is offline   Reply With Quote
Old 03-25-2001, 01:10 AM   #13
webkris
Member#: 70
I sold WRX to buy
Post
Pat - Leave the size of my bar out of this!
Well, I hope they don't rub, I think I'm going to try it. I need to inspect clearences, etc. beforehand - then we'll see if it's a go.
Glenn - It too just dawned on me that 10mm is a little less then an inch . We're damn Americans without the metric system. - Kris
Old 03-25-2001, 01:29 AM   #14
Gambit
Member#: 102
Post
I wouldn't use an R compound on a stock suspensioned car. At the limit something has to break lose and those sticky R compounds aren't gonna break lose. So your car will tip over.
Gambit is offline   Reply With Quote
Old 03-29-2001, 11:34 AM   #15
D-WRX
Member#: 4672
Post
webkris: Did you ever end up trying the 225/50s on your WRX? I'm curious to know how they worked out if you did or if any other WRX owners have tried out the size on their cars.
D-WRX
D-WRX is offline   Reply With Quote
Old 03-29-2001, 07:55 PM   #16
priebe
Member#: 1761
Post
You can fit the Kumhos on the car. With stock alignment I got the Kumhos on. You need a spacer in the rear. I think I used a 3/16" spacer. You also have to roll the fenders a little, and take the rubber fender lip strip off. The car did work well with the Kumhos.
Brian Priebe
priebe is offline   Reply With Quote
Old 03-30-2001, 05:48 AM   #17
ConeMasher
Member#: 2135
Post
Methinks Gambit doesn't want any competition in G-Stock!
How about... if you run any tires other than the no-grip RE92s, your car might tip over
-- ConeMasher
ConeMasher is offline   Reply With Quote
Old 03-30-2001, 07:44 AM   #18
rjones
Member#: 1477
2003 wrx wagon
Post
Sorry for the OT, but kris' pic is totally redunkuous. Reminds me of FWD IT cars that lock and lift their inside rear wheel in turn one at limerock....too much
Back OT, I was real close to ordering 225/45/16's (yoko AVS-I) They also make this size in the kumho 712's. These will not rub on the RS, but they do have a shorter diameter....almost identical to 205/50/16. I ultimately decided I didn't want that short of a tire, an stuck with the stock size.
rjones is offline   Reply With Quote
Old 04-17-2001, 09:05 PM   #19
ConeMasher
Member#: 2135
Post
Just to clarify, has anyone run 225/50-16 Kumho V700's on the WRX yet?
A lot of conjecture seems to think that it MIGHT be ok, as the RS only rubbed slightly, and the WRX seems to have more room.
Does anyone have a definitive answer?
-- ConeMasher (afraid to be guineapig)
Old 04-17-2001, 09:38 PM   #20
ScoobyDriver
Member#: 195
1974 VW Type I
Porsche Stone Gray
Arrow
Not Kumho, but quite fat Dunlop's (8.25" cross section.)
<IMG SRC="http://www.thebestisp.com/~squadra/tire1.gif" border=0>
<IMG SRC="http://www.thebestisp.com/~squadra/tire2.gif" border=0>
Pinky worth of room at the rear strut. First Auto-X this weekend (22nd)
Shane Kullman
'02 WRX Blue
[This message has been edited by ScoobyDriver (edited April 17, 2001).]
ScoobyDriver is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 09:52 PM.
