Old 04-25-2001, 09:35 PM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Post What is the ideal offset for 18x7.5 wheels?
I have posted that my 17s might be recalled and I can order a set of 18x7.5 for more and I can get a custom offset. What is perfect without rubbing etc.
Scootr
scootr is offline   Reply With Quote
Old 04-26-2001, 11:16 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
If you are the guy with the WORK wheels, I still recommend contacting Gunner Heugberger at 719-475-1920 or www.heubergermotors.com since he put those wheels on his RS already.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 04-27-2001, 06:53 AM   #3
25psi
Member#: 3086
2001 2.5 RS
Post
Why will not yuou guys get it?
Offset has NOTHING to do with wheel diameter (Unless some very VERY specific cases. But I bet it aint one of them).
10" rim and 21"rim for same car should carry same offset! PERIOD! No more discussion about this please!
Go to my site http://25psi.topcities.com
and read an articale about wheel sizes.
Eugene
25psi is offline   Reply With Quote
Old 04-27-2001, 06:57 AM   #4
Damon
Member#: 2902
Unhappy
it doesnt have anything to do with diamater, but it does have to do with width. what is the stock RS's width? 6 in? im assuming he has 7 in wide rims now since hes rolling on 17s, and now hes going up to a 7.5 in width. surely the ideal offset would change somewhat..
Damon is offline   Reply With Quote
Old 04-27-2001, 07:24 AM   #5
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
Post
The stock RS wheels are 16x7 ET53. So anything with a width of 7" would have an ideal offset of 53mm however I feel anything between 50-55mm is fine for a 7" wide wheel.
For a 7.5" wide wheel I would suggest somewhere along the lines of 48-50mm.
Here are a few pics of my car with 17x7"ET50 ADR wheels and 215/45R17 Yokohama AVS Sport tires. I also have stock struts and spring so the ride height has not been changed from stock. I have not had any rubbing issues even with about 70 lbs of stereo stuff in the trunk and 5 adult passengers in the car.
front wheel and tire
<IMG SRC="http://albums.photopoint.com/j/View?u=1654202&a=12666180&p=47327176&Sequence=0" border=0>
rear wheel and tire
<IMG SRC="http://albums.photopoint.com/j/View?u=1654202&a=12666180&p=47327189&Sequence=0" border=0>
As you can see, I still room to drop the car approx. 3/4" or so.
Good Luck,
Stefan
Freeskier is offline   Reply With Quote
Old 04-27-2001, 07:49 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
FWIW I think the Oz P1's in 18 x 7.5 are ET50, though I'm sure someone can confirm or deny that.
ANZAC_1915 is offline   Reply With Quote
Old 04-27-2001, 08:41 AM   #7
jeffg
Member#: 2958
2001 WRX (GC8)
Post
25PSI, calm down, and you are correct, wheel diameter has nothing to do with offset. But width does. If you were to get a 7.5" rim with a +53 offset (same as stock), then you would be moving the rim .25 inches closer to the strut and fender. Depending on how much room there is an what width tire you are planning to run, you MAY need to adjust the offset to match this. I am running an 8" wide wheel with a 225 series tire. I had to move my offset out 10mm to get it to clear the factory strut.
This was a valid question. Keep up the good work.
jeffg is offline   Reply With Quote
Old 04-27-2001, 11:17 AM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
You might clear the struts with and 18X7.5" wheels with a +50 offset but your gonna rub the fender wells. If your going to run an 18X7.5 wheels watch out when you lower the car with suspension upgrades. You may be able to get a tire with a section width that is narrow enough to clear that lip that annoyingly sticks out on the inside edge of the outside fender well in the back. Try to go for lower than an 8.5" section width and you should be OK.
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 04-27-2001, 11:53 AM   #9
sanders
Member#: 187
2008 Impreza 2.5i
NBP
Post
okie... here's a picture of my car that a friend of mine took... i took other pictures, but waiting development. this is my car lowered all the way down on a GC/AGX Show Setup, i have 18x7.5" wheels with a 50 offset. (oh yeah, tires are 215/40 p7000). the tire tucks into the rear nicely and my wheel wells aren't rolled. camber appears to be the same... and it looks real nice! no rub really during normal driving. i only experience rubbing when taking corners too hard, or going over those nasty bumps. not too much rub when it happens, but just enough to make you crinch when you hear it. i would drive this low all the time if i could... but dont want to hurt my poor AGXs!
<IMG SRC="http://www.enduserville.com/mastrotampa/PIC00004.JPG" border=0>
[This message has been edited by sanders (edited April 27, 2001).]
sanders is offline   Reply With Quote
Old 04-27-2001, 05:26 PM   #10
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Thumbs up
Holy Crap your car is TIGHT!!
djerickd is offline   Reply With Quote
What is the min offset for a 2001 rs Dawson Tire & Wheel 0 05-01-2008 10:36 PM
what is the correct offset for an 18x8 wheel on an 04 WRX??? VajraTLR Tire & Wheel 4 01-24-2006 02:55 PM
What is the right offset for the 04 2.5RSs ImpreziveRS415 Tire & Wheel 1 05-12-2004 12:57 AM
What is the ideal pressure for RE92? poison Tire & Wheel 4 07-12-2003 12:06 AM
what is the going rate for 2.5 GT wheels/tires? Benjamin Tang Legacy Forum 14 01-19-2003 10:53 AM
