Old 02-08-2003, 03:19 AM   #1
Azjon
Member#: 28284
2003 Impreza WRX
Metallic Silver
Unhappy HKS Turbo Timer Problems
Someone help me please.... my Turbo Timer isn't staying on when I turn my car off. The car turns off so does the turbo timer. What should I do? What things should I check for to see if I did it right? Someone help me please....
Azjon is offline   Reply With Quote
Old 02-08-2003, 10:04 AM   #2
netZ
Member#: 5743
2007 Kia Optima
gold brick
Default Re: HKS Turbo Timer Problems
whoever installed it, needs to verify the 12 volt source for the Turbo Timer, it has to be a fused constant 12 volt source such as the battery or the constant 12 volt off the wrx's ignition harness.
probably the installer installed the power source off the Accessory/Ignition wire. Once you turn off the vehicle, there's no power running through those 2 wires.
netZ
netZ is offline   Reply With Quote
Old 02-09-2003, 04:17 PM   #3
squier15
Member#: 23927
02 WRX
check the connection to the e-brake. mine did the same thing when i first installed it, retapped the e-brake wire and everything worked fine
squier15 is offline   Reply With Quote
Old 02-10-2003, 04:12 PM   #4
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Ditto - if it comes on and acts normally when the car is turned on:
1. MAKE SURE YOU ARE SET TO TIME!! (Make sure you're not on auto timer, and it's setting to 0 seconds or something) Set it to like 5 minutes or something just for kicks
2. Same with me, squier15, I had a bad connection to my e-brake handle. As soon as I rechecked the splice, and connected it all up, I was good to go.
CirrusWRX is offline   Reply With Quote
Old 02-12-2003, 07:19 AM   #5
tdxflex
Member#: 13634
the HKS ones, almost always the ebrake wire. look under the center console for a pink wire if you have a 2002, i forgot what color for the 2003. open your arm rest, grab where the cup holder is and just pull up hard and it will clip off. it might be under the carpeting but you should be able to see the wire coming from the turbo timer going near the ebrake, just keep on following it and check the connection. i threw away my vampire clip and soldered that down. i've also done the same for a bunch of my friends who ran into the same problem.
tdxflex is offline   Reply With Quote
HKS turbo timer problem kimo is sleeping Electrical & Lighting 0 11-13-2008 03:48 AM
HKS Turbo Timer Problems!? Ummm1224 Electrical & Lighting 0 12-04-2006 03:17 PM
HKS turbo timer problems... WTH? Black-X Electrical & Lighting 2 03-24-2004 08:39 PM
HKS turbo timer problems... ***? Black-X Electrical & Lighting 1 03-21-2004 06:05 PM
