Old 02-08-2003, 11:49 AM   #1
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
Default Fog Lights ..am I missing something??
I bought my 02 RS without fog lights. I pulled the little covers off just to see what was behind there and noticed the wires/harness for the fog lights. I recently got a set of fog lights from a WRX owner, and I bought a fog light switch from the dealer here in town. I put the switch in and the fog lights in.....but the lights don't come on. I bought a new set of bulbs and nothing. When I have my headlights on and I hit the switch the green LED comes on in the switch. What am I missing? The fog light fuse is fine. Thanks for any help guys.
Impulsivegoat23 is offline   Reply With Quote
Old 02-08-2003, 12:02 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Yeah, you need the relay that goes in the panel of relays next to the fuse box by the driver side left leg. It's at your local dealership, shouldn't be too expensive.
supermarkus is offline   Reply With Quote
Old 02-08-2003, 03:22 PM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
And if you want to prove that this is all you need, you can use the relay for the power windows or the airconditioning.
The relay goes in the third spot from the bottom (or 4th from the top) in the relay panel behind the clutch pedal. The power window relay is the one right below it (2nd from the bottom) and the A/C relay is in the engine fuse/relay box. Or you could pull the rear window defogger relay - also in the engine fuse box..
Alan is offline   Reply With Quote
Old 02-08-2003, 07:02 PM   #4
Jony2stones
Member#: 32102
2002 2.5TS
Sorry to interrupt, but is this relay a subie-specific part??
Or can one use the relay that comes with the lamp kit???
Jony2stones is offline   Reply With Quote
Old 02-08-2003, 08:38 PM   #5
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
It is a Nippo-Denso part, but you do need the right one to fit into the stock relay holder. When I went looking for one to use to power the seat heater line, which I used to power an amp under the seat, I looked in lots of junk cars and couldn't find any. Luckily I found a friend gutting a WRX for Pro-Rally, and he gave me his A/C relay which he no longer needed.
Am I missing something? Freeskier Brakes, Steering & Suspension 3 05-10-2002 11:14 AM
Am I missing something... 128d Interior & Exterior Modification 2 08-25-2001 09:14 PM
Intake + exhaust without headers. Am I missing something? Evil-Mastermind Normally Aspirated Powertrain 6 02-28-2001 06:52 AM
Am I missing something? AccidenT Brakes, Steering & Suspension 3 02-27-2001 10:49 PM
Am I missing something? miksmi Mid Atlantic Impreza Club -- MAIC 5 11-04-2000 05:12 PM
