Old 02-08-2003, 02:01 PM   #1
stevesparts
Member#: 29546
02 wrx/impreza
Question electronic gods help!!!
hey guys after swaping in a 6sp from a auto we changed the wiring harness and now we have a big prob. 1st prob. maf senser wont let the car run????? it runs fine in closed loop{cold no sensers} once its warm it DIES! {goes rich} it will run{strong}w/it disconected{blows i/cooler hose off} it runs fine.. tryed other maf. its not the compu. all wires are goin to the right places{volts ok}it just wont run w/ maf plug in we are at a loss WHY?????
onlyother eng mods: mrt fmic w/ short int. no other eng mods... not yet!!! if u think u know PLEASE! let me know i'm very on why it is doin this. as for codes can't get it to run to get em. w/ maf unpluged::0102/// maf low circ power.{dud.. its unpluged} thanxs steve.
stevesparts is offline   Reply With Quote
Old 02-08-2003, 06:18 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
am I the only one who is
could explain this a little more clearly using punctuation and full words?
what does
Did you put a 6spd gearbox in an auto WRX?
and doing this you had to change the engine harness and now the ECU is not seeing the MAF input?
Is the MAF you swapped it with a known good MAF?
Jay
Old 02-08-2003, 11:50 PM   #3
stevesparts
Member#: 29546
02 wrx/impreza
Post yes
sorry!! i hate to write to... 1. i did swap a 6speed into a auto car it ran fine. just had a high idle. so we changed out the wiring harness & ecu so it will be right!!! it ran great on the auto ecu. but when it was swaped out it ran fine till it warmed up it will die!!!
ie:going from closed loop to open{hot/usein sensers}. right now it will run fine without the MAF senser pluged in.but if u plug it in it will go rich and DIE.2.we have tried a MAF senser from another car same problem. traced all wirers they are going to all the right places. can't think of anything that will cause it to be this way. steve. and to answer your ??? 1. yes. 2.no. but we did. and it knows its there.it just makes the car die{runs rich} 3. yes it is good{put on other car and it ran fine.
Old 02-09-2003, 02:47 AM   #4
Avenger
Member#: 1234
Lets clear some thing out.
Close loop is when the engine is warm and open loop is when the engine is cold.
Avenger is offline   Reply With Quote
Old 02-10-2003, 03:08 PM   #5
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
You need more information.
What are the differences between the auto and manual harnesses, sensors and computer?
Are the engines (cars) the same year?
If they are not....you may well be better off with the auto setup, as that computer should run your engine just fine. Figure out what auto signals are different. Sure, there's the interlock for starting, which can easily be defeated, but is there anything else? Speed sensor? If so, it might not be needed. I think your problem is that you swapped out the harness and computer to a setup not matched to your engine.
Another way around....if you don't want to swap back....is to remove ALL the sensors that were on the manual car's engine/tranny and install them into your engine and harness. If there's a difference in sensors, this will take care of that. I've done exactly that on another car (ford)....only a bit more radically, swapping engines/intake system/ computer. Runs fine.
jack
please, for the love of god help me Borky Texas Impreza Club Forum -- TXIC 6 06-14-2002 10:19 AM
Dear god help! I need upolstery cleaning advice now!! BrysImpreza New England Impreza Club Forum -- NESIC 14 06-01-2002 03:46 AM
I am in need of your godly help Hwoodysubaru Normally Aspirated Powertrain 0 05-11-2002 02:59 PM
Please God help me with insulation advice! BrysImpreza Interior & Exterior Modification 9 01-02-2002 01:52 AM
('93-'01) god help me... goose Impreza Forum 6 06-04-2001 07:06 PM
