![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 6821
Vehicle:2006 Scion TC Mica |
The illustrations for the installation of the rear endlinks are not clear as to the position of the washers on the sway bar interface end of the links. THis is a diagram of how I installed mine. Did I install the washers correctly?
Driver side for example: (LEFT)Bolt | Large washer | bushing | swaybar | small washer | nyloc nut (RIGHT) This has the bushing rotating directly on the bar end. The passenger side is a mirror of this.
#2 |
Techno Sapien
Moderator Member#: 449
Vehicle:2010 Legacy 3.6R Lim Azurite Blue Pearl |
If you look closely at the pics here you may be able to see how I did it:
http://www.scoobymods.com/mods/impreza/endlinks.php Just an FYI - I removed my Whiteline solid links and replaced them with the OEM links and Kartboy insert bushings. The bushings are cheaper, you can get front and rear inserts for less than just purchasing the rear Whiteline links. The solid links and the OEM ones with the stiffer inserts feel the same. Both give quicker steering feel letting the bar come into play faster than the OEM bushings/links. Here is a link to the KB inserts: http://www.scoobymods.com/mods/impreza/droplinks.php Added bonus, the inserts make the links still look G-Stock um I mean stock. (I'm STS anyway) Peaty |
#3 |
Member#: 6821
Peaty: I used that photo as a reference. The front bushings probably dont fit on my 2002 RS. I paid $45 for my endlinks which was less than the $55 price of the rear bushings and didnt require me to go through the process of removing the factory bushings from the plastic. I also wonder if the steel bars are equaly as stiff as the plastic. There may be some value to others in having the OEM links in their original state. I have a pair of OEM links for sale now if you value that OEM look. :-)
[ June 14, 2001: Message edited by: ThinkTank ] |
#4 |
Techno Sapien
I was told that the plastic they use is very stiff and does not flex as much as originally though. Its' the same stuff they make guns out of. What flexes a lot is the bushing. They are pretty soft. Boy the price has gone down on the links. When I got the rear whitelines I paid 80+ shipping.
#5 |
Member#: 5211
Vehicle:1997 Legacy Outback Spruce Pearl green |
I was also a bit confused, but I put the small washer between the bushing and the swaybar. My thinking was that this will prevent the bushing from deforming into the bolt hole in the sway bar when things are tightened down and moving around.
Doug |
#6 |
Member#: 6821
dvancleve: I would change that washer because you may be binding the washer and have more surface area exposed to the bushing. It seems unsafe to configure it in a way the manufacturer didn't test. I am a novice, so I would consult an expert if I were you.
Peaty: The chicks really dig the yellow bushings ![]() [ June 15, 2001: Message edited by: ThinkTank ] |
#7 |
Member#: 5211
ThinkTank,
Thanks for your concern. I think the way I did it IS what is illustrated on the little Whiteline paper that comes with them. It makes more sense to me, and the factory bar/bushing setup just had the nut against the swaybar which is how mine is. I will check everything for tightness sometime soon, but the front link hardware didn't loosen up at all so I doubt the back will either. Doug |
| Thread Tools | |
| Display Modes | |
| Whiteline KLC32 front endlinks installed...take a look. | tuskenraider | Brakes, Steering & Suspension | 17 | 04-13-2006 12:56 AM |
| WTB Whiteline KLC19 rear endlinks | Legacy777 | Texas Impreza Club Forum -- TXIC | 0 | 07-14-2004 09:30 PM |
| WTB Whiteline KLC19 rear endlinks | Legacy777 | Private 'Wanted' Classifieds | 0 | 07-14-2004 09:26 PM |
| FS: Whiteline solid rear endlinks/Hawk HPS pads | Achilles38WRX | Mid West Subaru Owners Club Forum -- MWSOC | 5 | 05-11-2004 12:36 AM |
| Pics of New Style Whiteline Rear Endlinks installed and HD mount kit (RS) | munkis | Brakes, Steering & Suspension | 4 | 09-26-2003 07:46 AM |
