#1 |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
Can you guys / gals tell me what size allen wrench is used to remove the plug that facilitates piston pin removal? Can you think of any other special tools I need for engine tear-down / building that are Suby-specific? Thanks in adavance!
#2 |
Member#: 18960
South East
Thanks anyway folks....it's a 14mm
#3 |
Moderator Member#: 922
Vehicle:04 FXT Red |
Hey, it's a 14mm.
![]() And the cam gears are 10mm. The really tricky part is getting the *&%$@#*& wrist pin out if you don't have the Subaru tool! |
#4 | |
Member#: 18960
South East
or... (a novel concept) buy the tool from my local dealer. ($$$) |
#5 |
Member#: 18446
Vehicle:2002 WRX wagon psm |
14mm hex socket, not to be found anywhere. Not Napa, Sears, local hardware, Pepboys, Autozone, Lowes....
#6 | |
Member#: 71419
#7 | |
Member#: 49763
Vehicle:2004 WRX Jetzt mit 25% mehr Motor! |
![]() I'm not saying it will be easily, just that it is indeed possible. ![]() |
#8 |
Member#: 110343
TXIC
Vehicle:2005 impreza 2.5RS black |
#9 |
Top Scoob 006
Member#: 14424
South East
Vehicle:BugI w/ 07 STi Swap www.TriStateTuners.com |
just to follow up on this, take a 14mm bolt and put 2 nuts on the other end to lock them together. stick the head of the bolt into the hex you're trying to remove and put a wrench on the inside of the two nuts and crank on it. if the nuts are locked together it'll work perfect.
#10 | |
Member#: 48219
Vehicle:. Always drive the race line . |
#11 |
Member#: 31129
NWIC
Vehicle:02 WRX MPB No TGV + lots of P&P |
After you do that you need to remove the piston pin
You need the special tool 499097700 ![]() How do I get the tool or use of one? |
#13 |
Member#: 111735
South East
Vehicle:96 Legacy2.0GTSOLD Bimmer Tech |
easiest way to get the wrist pin out is with a 2 foot (or around that length) very thin screw driver. If you wanted to take out the driver front pin, you will stand behind the driver rear pin. Rotate crank until the driver front pin is in front of its access cover. Slide thin screw driver in and rest it on the back of the wrist pin. Lightly tap it until it comes out.
#14 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
like turboL said or take 1/4" steel/chromoly rod heat the tip up an smash it flat...then keep hot and put tip in the vice and bend a crook at the tip for grapping the backside o the wristpin...quench it when done
I like metal work ![]() |
#15 |
Member#: 21893
SCIC
Vehicle:2002 WRX w/STi swap PSM |
Other than using a long thin screwdriver, I have also used a simple wire hanger straighten out with last 1/4 inch bent at a 90 degree angle. Just hook the far edge of the wrist pin and pull. This will only work if the pin has not pounded the circlip distorting the piston pin bore. If that has happened it will take some force to get it out.
#16 |
Member#: 147598
Vehicle:95 Impreza 2dr Black |
what i have done in the past is you take two 16 penny nails... framing nails... weld the points together so you have the nails in a straight line with the heads on the ends. (You might have to make the diameter of the head smaller on one nail.) Remove your access covers and the outer wristpin clips. Then insert the head of the nail that you grinded down a little bit until it pops out the other side of the wristpin. Then insert a screwdriver next to the nail so it is offset in the hole and the head will now grip onto the other side of the taper inside the wristpin.. then just pull it right out.. it actually works really well... beats buying a hundred dollar tool
#17 |
Member#: 12811
South East
Vehicle:2002 2.5l Wrx 517whp/516wtq (Stage pi) |
I use a wire clothes hanger.
#18 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
I used a piece of chain link fence wire, had to make 3 of them....they kept bending.
Whenever I do it again, I will buy a $3 screwdriver, heat the end up, and bend the last 1/8''-3/16'' 90 degrees over to make a hook. Screw buying the $100 plus dollar tool, make your own. EDIT: If you go to home depot or lowes, or whatever, try to find a small piece of wooden dowel, looks kind of like a closet coat rack "bar". (the part the hangers hang on) Take your EJ wrist pin with you, works like a charm for re-installing the pins. Sometimes the thumbs get sore. ~Josh~ |
#19 |
Vendor
Member#: 150846
try around $300
no kidding |
#20 |
Member#: 125013
just a long beak pliers suffices
#21 |
Member#: 31129
NWIC
#22 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
rotate the crank until the wrist pin of cyl#1 is in view and remove wrist pin. You may want to rotate it so the rod on cyl#3 is slightly above or below so you can insert a 1/4" rod through service hole #3. Taking the LONG 1/4" rod.....punch out the wrist pin of cyl#1 by running the rod through cyl#3's service hole. The END of your rod will come in contact with the wrist pin of cyl#1. You use a hammer and punch out the wrist pin of cyl#1. Do the oppisite with cyl#3 by inserting the rod through cyl#1's service hole.
all done and said. You're all welcome! |
#23 |
Member#: 136912
SCIC
Vehicle:2006 Sti OBP |
#24 |
Member#: 95492
Vehicle:2003 WRX with STI goodies >:) |
easiest way to go about it, seriously...Go to a local suby dealer with a maintenance department. just ask them to pop it for you. i messed around with mine for atleast 2 days before i said, "well suby mechanics have to have this tool" they opened a brand new wrist pin tool box, popped them out for me and i was on my way. being the nice guy i am i tipped them
#25 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Video I made. This is for ej22 and ej25 only though, because the WRX 2.0 has those funky pins....
http://www.youtube.com/watch?v=TR0Ed6qTIVQ |
| Thread Tools | |
| Display Modes | |
| Piston pin removal tool anyone? | neilschelly | New England Impreza Club Forum -- NESIC | 10 | 01-02-2008 01:32 PM |
| Piston pin tool?'s | AK'S REX | Built Motor Discussion | 11 | 12-18-2007 03:31 PM |
| Piston pin puller tool? | clsmooth | Vancouver Impreza Club Forum -- VIC | 10 | 12-17-2007 12:34 AM |
| Piston Wristpin Removal Tool | Fitz | New England Impreza Club Forum -- NESIC | 22 | 08-21-2007 09:35 PM |
| New in box JE pistons, pins, Ring Set 8:5.1 for EJ25 99-04 | RobertFusco | Private 'For Sale' Classifieds | 10 | 04-04-2004 01:48 PM |
