Old 02-10-2003, 06:13 PM   #1
waezsn
Member#: 22722
Default where is my ECU
where is my ECU located??????
waezsn is offline   Reply With Quote
Old 02-10-2003, 06:51 PM   #2
SubbyRS
Member#: 17193
1991 Legacy RS
what car you got?
SubbyRS is offline   Reply With Quote
Old 02-10-2003, 06:52 PM   #3
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
In a WRX it is under the carpet under a steel plate in the pasengers foot well...
1st - pop the gromet by the door hinge & pull the plastic thresh-hold up...
2nd - unscrew & remove 2 big flat plastic trim nuts holding the top of the carpet... pull the carpet back.
3rd - get a 10mm socket & remove the 3 bolts & 1 nut at the top...
it should be there... if you have a WRX
GLwagon is online now   Reply With Quote
Old 02-10-2003, 07:09 PM   #4
waezsn
Member#: 22722
I am currently installing me apex turbo timer right now... I have plugged in the TT into the harness and the harness into the blue plugs and my turbo Timer wont even turn on.. Is this supposed to happen?.. And how/where do i ground the black wire?... and what part of my ECU does the white wire go?...
Sorry i'm only 16 and im trying to install all this complicated stuff.. have some sympathy and help me!..
Bummer: Where is my ECU located? ('05 STi) Ozer Engine Management & Tuning 2 12-02-2005 05:50 AM
Where is my ECU??? jeeps1998 Newbies & FAQs 8 11-17-2005 10:32 AM
where is my ecu+maf wire White 2.5rs Normally Aspirated Powertrain 4 09-08-2003 01:13 PM
where is my ecu? Z1 Performance Legacy Forum 5 09-29-2002 10:46 PM
Message Board Statistics All times are GMT -4. The time now is 11:01 PM.
