#1 |
Member#: 28284
Vehicle:2003 Impreza WRX Metallic Silver |
Someone help me please.... my Turbo Timer isn't staying on when I turn my car off. The car turns off so does the turbo timer. What should I do? What things should I check for to see if I did it right? Someone help me please....
#2 | |
Member#: 5743
Vehicle:2007 Kia Optima gold brick |
whoever installed it, needs to verify the 12 volt source for the Turbo Timer, it has to be a fused constant 12 volt source such as the battery or the constant 12 volt off the wrx's ignition harness.
probably the installer installed the power source off the Accessory/Ignition wire. Once you turn off the vehicle, there's no power running through those 2 wires. netZ Quote:
#3 |
Member#: 23927
Vehicle:02 WRX WRB |
check the connection to the e-brake. mine did the same thing when i first installed it, retapped the e-brake wire and everything worked fine
#4 |
Member#: 17439
Vehicle:2002 x2 Silver WRX Sedan, White WRX Wagon |
Ditto - if it comes on and acts normally when the car is turned on:
1. MAKE SURE YOU ARE SET TO TIME!! (Make sure you're not on auto timer, and it's setting to 0 seconds or something) Set it to like 5 minutes or something just for kicks 2. Same with me, squier15, I had a bad connection to my e-brake handle. As soon as I rechecked the splice, and connected it all up, I was good to go. |
#5 |
Member#: 13634
Vehicle:2002 WRX WRB |
the HKS ones, almost always the ebrake wire. look under the center console for a pink wire if you have a 2002, i forgot what color for the 2003. open your arm rest, grab where the cup holder is and just pull up hard and it will clip off. it might be under the carpeting but you should be able to see the wire coming from the turbo timer going near the ebrake, just keep on following it and check the connection. i threw away my vampire clip and soldered that down. i've also done the same for a bunch of my friends who ran into the same problem.
| Thread Tools | |
| Display Modes | |
| HKS turbo timer problem | kimo is sleeping | Electrical & Lighting | 0 | 11-13-2008 02:48 AM |
| HKS Turbo Timer Problems!? | Ummm1224 | Electrical & Lighting | 0 | 12-04-2006 02:17 PM |
| HKS turbo timer problems... WTH? | Black-X | Electrical & Lighting | 2 | 03-24-2004 07:39 PM |
| HKS turbo timer problems... ***? | Black-X | Electrical & Lighting | 1 | 03-21-2004 05:05 PM |
