Old 02-11-2003, 03:29 AM   #1
brchco12
Member#: 22071
2007 Forester
Default question
would stock WRX struts fit on a 96L? and whats a top hat?
thank you for your time
brchco12
brchco12 is offline   Reply With Quote
Old 02-11-2003, 03:31 AM   #2
brchco12
Member#: 22071
2007 Forester
Default question
would stock WRX struts fit on a 96L? and what are top hats?
brchco12
Old 02-11-2003, 09:40 AM   #3
linsavy
Member#: 11620
1997 GF4 -STiV3
Saab 93 TX sportcombi
IIRC, there are differences in the GC vs GD struts. I think the back have different spring perch height. I believe they can be made to work if you correct for camber. There are threads on this in the suspension forum - try a search there.
Top hats are the top piece of the strut assembly between the top of the spring and the chassis. They have a rubber bushing - stock is soft while STi is harder. You can also get them camber and caster adjustable and will pillowball mounts.
linsavy is offline   Reply With Quote
Old 02-11-2003, 10:44 AM   #4
linsavy
Member#: 11620
1997 GF4 -STiV3
Double posting is a no no.
Old 02-11-2003, 02:05 PM   #5
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Try the Suspension, Brakes, Rims, and Tires Forum. I believe it can be done...
Mike~~
N'CTRL is offline   Reply With Quote
Old 02-11-2003, 02:47 PM   #6
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
They'll bolt up but you will have alignment problems.
We've mounted struts made for the 1st gen on 2nd gen cars and IIRC they needed camber bolts to get the alignment right.
CosmoTheCat is offline   Reply With Quote
Old 02-11-2003, 04:23 PM   #7
stentorian
Member#: 12959
2008 Scion xB
Don't think so (but not 100% sure), but 98-01RS struts/springs will. A friend of mine has some for sale w/ only about 10k miles on them.
-Joe
stentorian is offline   Reply With Quote
Old 02-11-2003, 06:52 PM   #8
brchco12
Member#: 22071
2007 Forester
Default really...
who's your friend?... i'd like to e-mail him brianccorrigan@juno.com
thanks
03 RS struts on 96 Brighton Tom MY03 Brakes, Steering & Suspension 0 06-05-2009 01:08 PM
wrx brakes on 96 impreza L? Van'Olinga Subaru Conversions 2 03-14-2009 01:10 AM
02 WRX Wheels on 96/ Lowered/ Need new tires Local_Skater Tire & Wheel 5 10-06-2007 09:06 AM
Photochop: STI and WRX scoops on 96 leg. outback crk4 Interior & Exterior Modification 1 01-13-2004 06:45 PM
older 2.5RS/WRX struts on new WRX IFANTIG Brakes, Steering & Suspension 0 09-09-2002 12:15 PM
Message Board Statistics All times are GMT -4. The time now is 07:01 AM.
