Old 05-17-2001, 02:56 PM   #1
Tats
Member#: 5692
WTF? YES! I am
better than you!
Post Acceptable offset. (Did search!!)
Okay...just sat for an hour or so rooting through old posts and damnit, I want a definate answer!
Okay.....no brainer says that regardless of whether the rim is 16, 17, 18 inchs the proper offset is +53 for a 7" wide rim and +48 for a 7.5" wide rim.
My question is how much leeway do we have either way. For example; I found this sweet set of wheels I want. The bolt patter will fit and it is 17x7.5 with and offset of +45. Okay, to me 3mm is tiny. Will this make a big difference? I know rubbing is also caused by different brands of tires too. (But lets forget about that for now.)
Also..what is rolling your fenders?
Tats.
Tats is offline   Reply With Quote
Old 05-17-2001, 03:47 PM   #2
RS2001
Member#: 3210
01 RS Coupe
05 WRX Wagon
Post
I'm no expert, but that sounds like it's gonna rub pretty bad, unless you roll your fenders.
Rolling fenders = bending the inside lip of the fender so that it's more of a "U" shape and not an "L" (if you're not sure what I'm talking about, stick your finger along the lip of your fender, you'll feel it). This stops the fender from chewing up the tire and gives you a couple extra mm's to work with. Some people just cut the fender instead of bending it. Either way, if it's not done carefully, your paint can crack and chip off.
Someone else can probably explain this better, but I hope you get the idea.
Good luck!
-DAN
RS2001 is offline   Reply With Quote
Old 05-17-2001, 08:18 PM   #3
Julian
Member#: 1182
MY00 RS
BRP
Post
You have to take the tires into account. That's what rubs! What size/brand of tire, what's the width? 45+ is really discouraged. I'd only go with that if you can test fit them BEFORE you pay. If you can do that, go for it. If you can't, and especially if you can't return them once tires have been mounted....
Julian
Julian is offline   Reply With Quote
Old 05-17-2001, 08:26 PM   #4
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Post
Don't try it! I had some Enkei's that were 40+ as I came to find out and what a pain in the ever livin butt that was! Every millimeter is as good as a mile!!
subymamma is offline   Reply With Quote
Old 05-17-2001, 10:17 PM   #5
vividracing
Member#: 6270
Only At
www.vividracing.com
Post
I have a WRX and have 17x7 with a 48mm offset, no problem. Lots of these people are crazy and don't know. I would agree that 40 is to low, but 45 should be fine. Let me know if I can help you access some wheels fairly inexpensive. www.vividwireless.com
vividracing is offline   Reply With Quote
Old 05-17-2001, 10:41 PM   #6
CP
Member#: 3522
1997 A4 1.8TQMS
Pearl White
Post
I'm trying figure out what offset is needed for a 7.5"x17" rim with a 225/45/17 tire on it. AVS Sports on a WRX wagon...from my A4. I don't get why people are going with a 215/45/17, as it has a much smaller circumfrence than the stock 205/55/16. Their odometers will rack up miles much faster, and the gearing will seem shorter(good for autoX, I guess).
Who's got a 225/45/17 on a 7.5" wide rim?
Thanks,
-Cy
CP is offline   Reply With Quote
Old 05-18-2001, 01:08 AM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post
AFAIK, the reason Subaru suggests the 215 width is that wider tires have a good chance of rubbing the fenders on previous models (which had tighter fenders).
It's the standard 17" tire size for Subarus.
No guarantees, but my guess.
Concillian is offline   Reply With Quote
Old 05-18-2001, 08:10 AM   #8
goose
Member#: 3578
Post
some food for thought: I recently slapped on some 16" VW Golf steel rims to put on my car to use while I was getting my rims powdercoated, and they fit fine, I'm not positive of the exact offset of the steelies, but VW rims are 39mm aren't they?
Didn't have any rubbing problems or squirrely steering at speed- even did a couple of tests near my work, took a couple of hard turns with them just to test too-
goose is offline   Reply With Quote
Old 05-18-2001, 08:36 AM   #9
Tats
Member#: 5692
WTF? YES! I am
better than you!
Post
Damn....why does every thing have to be too difficult? I don't want to blow the money on these wheels if they will rub. It's only 3mm but I guess that may be enough. Too many conflicting opinions. Of course the guy selling them says they'll fit, he wants the sale.
Tats.
Old 05-18-2001, 02:08 PM   #10
megatron
Member#: 4212
2002 Impreza WRX
Post
From what I've heard, the actual proper offset for a 17.7.5 rim is 50mm not 48mm. So stock 16x6.5 = 55mm offset, 17x7 = 53mm, and 17x7.5 = 50mm. Not 48. The SSR Competitions (17x7.5) are going to be available in a fitment made precisely for Subaru and it will have a 50mm offset, so this further suggests this. I'm not saying a certain offset will or will not fit, I'm just trying to clear up the actual preferred offsets.
Also, 215/45/17 is not that much of a difference from stock: less than 1%. So you won't be 'racking up miles much faster' and I doubt they will seem much shorter.
megatron is offline   Reply With Quote
Old 05-18-2001, 04:54 PM   #11
Tats
Member#: 5692
WTF? YES! I am
better than you!
Post
Yeah 215/45/17 is my choice for tire size. I just dont want to spend too much for rims. Oh we'll I guess I'm gonna have to go with the superlegs I guess. Any hints on decent looking wheels in the smae price range?
Tats.
Wide wheel acceptable offset blahhblahh Tire & Wheel 2 11-09-2007 10:57 AM
Acceptable offset range for '00 Outback BrokenCrank Tire & Wheel 1 09-04-2003 10:30 AM
Acceptable offset for a race only rim DaveK Brakes, Steering & Suspension 3 06-26-2001 02:18 PM
Doing brakes..need help..did search..got nothing Aaron'z 2.5RS Brakes, Steering & Suspension 8 06-03-2001 10:31 PM
help? already did search john seput General Forum Archive 9 01-08-2001 07:28 AM
