Old 02-11-2003, 07:35 PM   #1
hairband
Member#: 21088
Default 18 inch wheel question?
Need expert advice. I am looking to install 18x8.75 wheels
with the recommended tire fitting. Now the offset is 50mm.
I also have the front lowered 1.5 inch and the rear 1 inch and I have sti 4-pots on front. The million dollar question is,
should there be any issues with these wheels.
Any expert advice would be greatly appreciated.
Rob
hairband is offline   Reply With Quote
Old 02-11-2003, 07:53 PM   #2
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
do you have a sedan or wagon? what tire size do you plan on using
David Glasscock is offline   Reply With Quote
Old 02-11-2003, 08:08 PM   #3
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I would think the recommended size would be 235/40/18... But I think 225/40/18 would work, being the minimum you can get on them. I could be wrong though... there's a chart that tells you... search for "miata wheel chart" It was posted on here at one time.
I think this size wheel would be tight, but I think it'll be ok with that offset... Let us know.
dj_noose is offline   Reply With Quote
Old 02-11-2003, 08:48 PM   #4
hairband
Member#: 21088
Sorry,
It is sedan. Recommended tire size is 225/40.
Thank You
Old 02-11-2003, 09:45 PM   #5
rsr911
Member#: 3813
2002 AMG CLK55
Thumbs up
I am running Speedline GT 1 in 18 x 7.5 with a 48 mm offset. 225/40/18, on my sedan. The offset may not be enough at 50. Since your new wheels are 8.75 inches wide the center of the rim now needs to be offset less to center properly and therfore you may need to look at 48mm offset. With luck 2mm hopefully wont make a difference.
The question of clearing the brakes may not be a question of offset but the angle of the spokes of the wheel. Example is ROTA subzeros in 17" clear bigger brakes but the 18s may not.
What is the wheel you are going to use?
I would recomend a test fit first if you can before you buy them.
Owen
Food for thought.
rsr911 is offline   Reply With Quote
Old 02-11-2003, 10:07 PM   #6
dj_noose
Member#: 17302
2002 Impreza WRX
Originally posted by hairband
Sorry,
Thank You
Yeah 225 is recommended for the sedan and that's with 18x8
I was saying that 235 would probably be the recommendation for the 18x8.75" rim...
Old 02-11-2003, 11:14 PM   #7
rsr911
Member#: 3813
2002 AMG CLK55
Thumbs up
I forgot to mention my car is lowered 1.5" front and 1" rear. No rubbing issues. I track my car. I am adding the Stoptech big brake kit this spring. I know they will fit my Speedline GT1s which will be set up with R compound tires for track and they clear ROTA Subzeros which I will use for everyday and for winter.
Owen
Old 02-11-2003, 11:19 PM   #8
hairband
Member#: 21088
I was looking into BBS RG-R.
Thanks for all the responses.
keep them coming.
Old 02-11-2003, 11:21 PM   #9
hairband
Member#: 21088
I made a misprint.
the bbs are 18x7.5
Old 02-12-2003, 08:26 AM   #10
hairband
Member#: 21088
more expert advise please.
17 inch tires on 18 inch wheels??? godforbid67 Tire & Wheel 44 09-21-2009 06:35 PM
WTT my 18 inch wheels for stock wheels/winter tires emsmap MAIC Private Classifieds 6 01-14-2008 10:43 PM
Super 18 inch wheel and tire sale (black wheel w/polished lip) Look inside! EdgeRacing Vendor 'For Sale' Classifieds 6 09-18-2003 02:21 PM
BBS RGR 18 Inch Wheel - Questions Dot.Com Cowboy Tire & Wheel 14 06-07-2003 04:37 PM
18 inch wheels Jasno999 Interior & Exterior Modification 6 08-15-2001 10:20 PM
